Old 09-01-2015, 09:59 AM   #29
troek
troek's Avatar
Drives: 2012 Toyota 86
i think i remember seeing an install guide on these and they were cutting the subframe to get it even closer to the frame.
EDIT: Here it is http://www.partsshopmax.com/e107_plu...opic.php?19215
Old 09-01-2015, 04:32 PM   #30
Crazypinoy9
Drives: FR-S TRD RS1#1488
Anyone sell these here in the US?
Crazypinoy9 is offline   Reply With Quote
Old 09-07-2015, 03:55 AM   #31
Zer0
Drives: 2015 frs
I bought mine from parts by max website. They shipped from SoCal. I installed them last week. I don't mind the noise but your going to hear your rearend gear whine and clunking when you shift.
Zer0 is offline   Reply With Quote
Old 04-06-2016, 07:56 AM   #32
Lakai
Drives: Argento
Where did you get them installed at? And how much did it run you? Thinking about getting these since my car is sitting fairly low.
Lakai is offline   Reply With Quote
Old 06-17-2016, 09:42 PM   #33
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
So just for my own info, how extreme does the lowering have to be to require this treatment?
I was under the impression, hopefully not wrong impression, that anything up to 50mm (2") was fine with the axles and tail/drive shaft of these cars.
I'm lowering my 86 25mm on coil-overs and if this is best practise or even advisable, when lowering a pissy 1", forget it!!!
Also;
Forgive me if this is a stupid question but how does this affect the front end of the car, specifically the the rake, braking, anti dive, geometry, weight balance, etc?
Isn't there going to be nose up effect, even minor, when this is done to the rear and not the front?
Is the difference so minimal it has no effect? Doesn't every action have an equal and opposite reaction?
Again apologies if this has been mentioned or explained and I've missed it.
Bodalenko is offline   Reply With Quote
Old 06-18-2016, 07:58 AM   #34
Zer0
Drives: 2015 frs
I installed mine myself. Its not that hard. Im only 30mm or so lowered. I didn't use the top spacers I used an angle grinder with a flap wheel to get the top of the sub-frame bushing hole flush with the solid sub frame bushings/risers, and used high quality epoxy on all new bushings the fit was very tight on two and just dropped in on the other two, so I just bonded them all in. They did increase the noise in the car you can hear the ring and pinion gear spinning. Sounds like a supercharger in your trunk.
They are shipped from SoCal location if i remember right.
If you are on coilovers they are adjustable you can set up your stance however you want. They make the rear feel more planted, you get more feedback, they help reduce axle angle, they keep the rear sub frame in a locked position for consistent handling. the stock rubber bushings are soft and flex under load which I didn't like.
Old 08-29-2016, 06:57 AM   #35
PeterFRS
PeterFRS's Avatar
Drives: FRS
i was looking at these to compensate for even lower ride height i was going to achieve with PBM LCA's. but not too fond of the "solid" and after what I read that it increases NVH.
Is there alternative solution to raising the Diffs and Sub-frame to correct the angle of the axles?
Thanks!
- Peter
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 08-29-2016, 07:12 AM   #36
Zer0
Drives: 2015 frs
Not that I'm aware of. Turn up the radio a little. What noise?
Old 08-29-2016, 09:55 PM   #37
PeterFRS
PeterFRS's Avatar
Drives: FRS
@Zer0 it's a shame other suppliers don't.. i suppose radio can get louder..
but that was my solution to dailying my civic..mod after mod radio getting louder and louder
which is another reason why I haven't gone with a aftermarket exhaust either..
'14 Scion FRS
Tein Flex
TE37
Old 08-29-2016, 10:34 PM   #38
Zer0
Drives: 2015 frs
I know I was half way joking. My car is going to be far from comfortable. If you want a daily comfortable car I can see not wanting this. I don't mind the extra noise so I went for it. Definitely build it for you and your goals don't compromise what you want from your car. I wouldn't.
The Following User Says Thank You to Zer0 For This Useful Post:
PeterFRS (08-30-2016)
Old 08-30-2016, 01:03 AM   #39
PeterFRS
PeterFRS's Avatar
Drives: FRS
haha yeah.. but in this game I can't seem to get my ways without any some sort of compromise.. don't want a busted axle on the side of the highway ...
might still look cool hella slammed while doing it but..
'14 Scion FRS
Tein Flex
TE37
Old 09-30-2016, 10:28 AM   #40
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Does the actual complex upgrade require BOTH subframe and diff risers?
Trying to understand which one I need to lower the axles stress due to the angle since dropped (-35mm / 1,5 in)
MSTiFK8R is offline   Reply With Quote
Old 09-30-2016, 01:36 PM   #41
Zer0
Drives: 2015 frs
I did the subframe and diff risers you might as well do them both and get the max benefits all at once.
MSTiFK8R (10-03-2016)
Old 10-05-2016, 09:13 PM   #42
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Also;
25mm would be nothing for it, 50mm should still be fine, the lower you go and harder you drive the more chance of breaking an axle.
Same as more power + lowered = more chance.
Hasn't seemed to have affected the handling on mine, still sits flat, had to adjust the coilovers to keep it that way though.
If anything, the car handles better now I have done it.
But the car handles way better now than stock anyway.
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Parts Shop MAX USA prototyping philstar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-04-2014 01:14 PM
Need a Shop for Aftermarket Parts Installation in Portland - Suggestions? Ammunition Northwest 11 12-23-2013 03:19 AM
RallySportDirect 2011 STi Shop Car for Sale. Over 50K in Parts, under 3500 Miles! RallySport Direct Cars for Sale/Trade 14 06-21-2013 12:52 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
