#29 |
Drives: 2015 Mustang GT (on order)
I think I seem to have found the pattern. Around 3400RPM @ .9 engine load during cruise conditions (driving up a hill in this case). I'll dial back timing a tad and see how it goes.
#30 |
so any drop in the IAM below 1 is a sign of knock and the engine will pull timing to compensate?
#31 |
Trust me, I'm the Doctor
Yes. Any multiplier (DAM) below 1 reduces the timing.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#32 |
Drives: FRS(sold), AP2, R35, FJC, ED9
still trying to understand what the KC learned value is and what it should be.
KC = knock correction? |
#33 | |
Jamesm explained it to me You need to look at the Engine RPM Vs Load table in tunepro/romraider ect and look at the value in the table for the given RPM vs Load. If that value is say 6 and your KC Learned is say 2 then it means its pulled 4 degrees of timing at that RPM/load point. If the value in the RPM vs Load table equals the KC Learned then their is no knock retard at that rpm/load. Hopefully I got it right. |
#34 |
Codename: Stitch
so I did another run today on a full tank of 91, with similar results.
http://www.datazap.me/u/pmok/stage-1...og=0&data=1-12 Adv. Multiplier was around 0.52 when I started the car. As you can see it went back up a little during the run, but still nowhere near 1.00 at all. Thoughts/recommendations? Assume that I have no tuning skills at all and very little inclination to get too involved into it. Should I be worried enough to switch back to stock tune, or find a way to get higher octane gas?
#35 | |
Try recording some runs on the stock tune to see if u still have similar results.
| The Following User Says Thank You to garfull For This Useful Post: | PMok (01-30-2014) |
#36 | |
Drives: #1553 10 Series FRS
#37 | |
+1 Be interesting to see if it was happening on standard tune Pmok are you at significant altitude above sea level ? PMok you could Source some higher octane fuel add octane booster to current fuel Pull some timing in the problem area's (although you stated you don't want to get involved in doing that) Run E85 and E85 tune |
#38 | |
Codename: Stitch
Yeah I will try logging at stock tune and see if I get similar results. Was wondering if anyone would say to let it keep learning a little more or what. I live in the hills about 1200ft above sea level but the logging and most driving is done pretty close to sea level. Thanks guys! Sent from my iPad using Tapatalk
#39 |
yeah, long time ago. same username.
#40 |
i've fought tip-in knock with this thing since i started tuning it. I've tried all sorts of stuff, from the regular timing adjustments to throttle mapping and cam timing. Nothing so far has worked. Not even E85 lol. You can make it happen less often, and you can make it less severe (where you may see up to -2.1's you can get it to only ever pull -1), but I haven't found a way to eliminate it entirely. I've got it down to one or two instances in a 20-30 minute log at best.
My next plan is a custom map that'll pull timing based on throttle delta. If that doesn't work, i'll try the same thing with MAP delta. The hack around the IAM dropping is just to make sure the value in the advance map where it happens is less than 3.9 (while keeping the same total timing). |
#42 | |
Drives: UK GT86
Basically, most of the 2nd half of that log the ECU isn't even trying to increase timing, that may not be due to it seeing knock etc. Its not ideal that its starting at 0.52. Its hard to tell if its pulling timing during the WOT pulls as you've not repeated them so there's nothing to compare.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | PMok (01-31-2014) |
| K&N Air Filter installed, MPG dropping? | HATED1 | Engine, Exhaust, Transmission | 35 | 05-09-2018 11:13 PM |
| Santa keeps dropping the BRZS off | HeubergerMotors | BRZ First-Gen (2012+) — General Topics | 11 | 12-19-2013 07:26 PM |
| Displaying the Adv Multiplier | sw20kosh | Software Tuning | 12 | 12-09-2013 11:42 PM |
| Multiplier and offset for OMNI 2.5 bar map sensor? | ATSAaron | Forced Induction | 2 | 10-28-2013 12:16 PM |
| Dropping car off Friday for TSB service.. some questions | pgeist | Issues | Warranty | Recalls / TSB | 6 | 07-15-2013 03:45 PM |
