Old 07-24-2012, 04:08 PM   #29
kanundrum
Drives: 2013 Whiteout FR-S
Stainless steel mesh brake hose from the lineup has been ENDLESS. The Company sponsors cars because that can only be set and is referred to as · Why is not you are using one of ENDLESS?
Rather than a · · ·
If the brake hose at the same time moving off the steering wheel to pretend like the front neck, may be damaged from the base case, if the shape is quite the burden of work in the swivel hose per Fitten'ngu that has become the swivel is reduced.
I cut off in the fatigue of our competition in the vehicle, I've tried a few things actually, after the change is no longer entirely be damaged to ENDLESS.
I have never so much any problem if you are using normally
Hose body is coated with resin also, has been hit by stone measures.
Car 16 inches, the configuration for both car and 17-inch.
Is only fitting setting of current steel, stainless steel also comes out in the future.
The Following User Says Thank You to kanundrum For This Useful Post:
ill86 (11-22-2012)
Old 07-24-2012, 04:09 PM   #30
kanundrum
BRZ & 86 users are involved in more or less not very lightweight · Dry carbon roof is an introduction.
There is no lack of strength compared to steel roof for 6.9kg, and ultra-lightweight 2.3kg, so you finished in the very high rigidity is genuine.
Weight of the roof in the highest position will contribute much to footwork,
Rigidity can be obtained more than pure fixed so firmly in the panel bond.
Was somewhat higher for was involved in purely domestic, so excellent finish
Please try.
It is good looking no matter how you look at it I
Since the product will be made to order, the longer it will take us a little.
Old 07-24-2012, 04:10 PM   #31
kanundrum
I introduced the color of the front of Def Def cloak the other day.
This time, developing a rear side still important!
Why should not you put the rear destination important? Is it true that I!
The reception is only because it was easy · · · · The image of the rear rigid Kokai def cloak, which is currently in development.
It looks like this. . . Tell me, am I perhaps understand
Should be a good thing at the same time they can also reinforce some of the members.
In this specific judder rid of this car also? ? ? Innovation may I become!
Mounting bolt plans, we aim Easy installation.
Completion of the mount is purposely enhanced, Lower suspension member in this, without having to change out of the mount.
Please expect not everyone! Please come at the same time I bought Innovation o (__) o Peko~tsu
Old 08-17-2012, 12:04 PM   #32
kanundrum
GT supercharger kit for the 86 will be released finally from HKS. In fact, although it is planned from October delivery, it may be placed in the user's situation fairly strong interest, not quite too late!
The rack is more modest in as Early Booking, ordered by the end of September, the four will get a racing plug HKS.
FA20 is a pattern of one 170PS engine will be measured to over 230PS.
What does not at once eliminate a lot of dissatisfaction with this lack of power also somewhat to our BRZ · 86
GT supercharger to achieve acceleration feel to dispel the notion of superchargers.
Is feeling very flat torque in the acceleration feel as if you were to increase the amount of exhaust unlike say, a traditional supercharger.
Heavy feel is not exactly up to speed on high rotation not at all tend to be traditional supercharger yet.
This linear ride street feel, of course, is easy to ride is also effective in sports driving.
Included in the kit so that all engine management is controlled by the F-CON, is nearly bolt mounting.
Superchargers body so there is a margin to the amount of wind, but supercharged 400PS aim to strengthen the engine.
Everyone is to become a car that makes a clear distinction is not so definitely it!
Considering how GT supercharger, so before the radiator is mounted intercooler, oil cooler to select, please be careful.
Super GT tea jar kit price ¥ 504.000
The price is still undecided, GT supercharger kits for the 2GR engine fire of Alphard & Vel will be released first.
The minivan is like what you hear you can pick up ridiculously early
I do not reckoned 彡 Dakaratoitte minivan (* ^ ω ^ *) Roh
ill86 (11-22-2012)
Old 08-17-2012, 12:06 PM   #33
kanundrum
The initial rod kit BILSTEIN BSS for 86 finally has arrived. Seems the first time only 50 minutes, I waited for about two months
Although manufacturers are out for 86, also can be fitted if BRZ course so as not to care.
Manufacturer's setting is so different to be issued in the future for BRZ
It is also not for 86 I also like a tailor-made for the BRZ was when elSPORT.
From private vehicles are involved in, I'll is to be selected according to the driving situation (o ^ - ^ o)
But man I feel so good because they only managed to say 彡 (* ^ ω ^ *) Roh
Humans came to spend less time we part, I - It was a natural diversion models regardless of manufacturer
We are also available from street circuit only type I replace the spring and of course it's possible to change settings in the future, even if overhaul BILSTEIN · · ·
It also overhaul a day if over-the-counter rack!
Old 08-17-2012, 12:06 PM   #34
kanundrum
I'll not overlap is the same car for some reason · What to pit three temporary 86 before going to bed.
Is a stand here, who then promptly seated BSS kit BILSTEIN be entrusted to future production vehicles gymkhana
Is 86.
The state of the vehicle height to fit the criteria so as to pass through security of course.
Sugin not a black car on the high and low? · What it looks
That is, the safety requirements in this mechanism
Although I think everyone is the same or ·
Parts is not just this pretty high
This car, RECARO other from side to side, and of course set before and after VIP is a feature called ENDLESS MONO4 I installed another stretch in this specification · a truck so I will buy is Suggoi (o El sport damper V2-DFA ^ - ^ o)
But so till the fat lady sings? ? ?
I was allowed to exchange tires and wheels.
Entrusted to one in 86 today, is also entrusted one from this weekend (* ^ - ^)
This year's Bon Bon is often staying in, Lancer Copen · 86 · GT-R
Accommodation is in a lot of car etc.
Old 08-17-2012, 09:15 PM   #35
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
I'm a native English/Japanese speaker, this translation is so confusing!
ZC6BRZ is offline   Reply With Quote
The Following User Says Thank You to ZC6BRZ For This Useful Post:
QFry (08-18-2012)
Old 09-20-2012, 10:47 AM   #36
kanundrum
Blamge Google for the translations
Inquiry supercharger kit HKS 86 & BRZ is as a manufacturer of minutes this year has become a very much sold out. I will contact the frame as well because it is a single company.
Delivery is scheduled for November.
I look forward to seeing it by all means possible BRZ but also has become a matching of only 86 in the current HKS.
※ If the car AT guess please wait!
I will be completed in a little later.
Old 09-20-2012, 10:48 AM   #37
kanundrum
Guest I got to let me socializing than FACEBOOK
We have installed the aero parts to 86. I have realized that the more I wish it fun to use parts that spread well even if you use FACEBOOK.
The you've let seated this time, but Aero that FiveAxis American San Kyarosse deep relationship began importing Our company also, I can be fitted perfectly well fitting finish that does not seem to be goods outside made from a material PP .
I'm sorry man ... (* __) is not often forgive a little picture because I had finished the evening
This item is recommended as it seemed to comment on FACEBOOK and there is also very effective owners who let me also mounted door TRD stabilizer of others.
We gotta image was the image of the owners
This part is a breakthrough that has been developed for conventional door Innovation I'll increase the rigidity in the door parts had nothing to do in the body rigidity.
Old 09-20-2012, 10:49 AM   #38
kanundrum
I wrote a story BRZ unusual, please bear with me here as well while you're at it. This exclusive goods BRZ is set to the BSS KIT Although we introduce the BILSTEIN BSS KIT for 86 previously.
Different dimensions are also different if the setting.
Unlike the 86 vehicle height is not a matter of much lower safety standards,
The extent of about 30mm is set BRZ only the vehicle height is lowered.
It is like setting while retaining the atmosphere according to the Subaru BRZ 4WD specific users, and the damping force, of course, spring rate
I'm different than for 86.
It is chic and BRZ and 86 separate setup (· ∀ ·) good!
kana rather than to do so elSPORT? ? ? Does it not matter Made to Order Nde I (o ^ - ^ o)
elSPORT only because you said ... than private vehicles
In conjunction with this, damper settings and a unique, non-suspension, BILSTEIN easy order system Please use it by all means.
Because I am afraid that I can not answer your phone or, in the mail, the contents of the setup that I own bent めっちゃ Please visit us.
Old 09-20-2012, 10:50 AM   #39
kanundrum
86 Among many, is the built-in LSD and 4.555 final gear BRZ minority still. Owner who is a young mother with young small children coming from us all the way, Mie Prefecture.
It is a good looking ride to BRZ
I'm glad ... I want to ride the circuit is also now
It is a car that would quite enjoy just put the first LSD ...
For us it is like such a bad good
Innovation would say the car suspension replacement I hope it is still first Pupupu (`艸 ')
Own unique setting because this car is not limited to the suspension settings I have for you will still be exchanged may say so, please contact us.
If you can I believe this, I turn around めっちゃ input of the nose is scary good.
Ignorant even under small corner ...
Old 09-20-2012, 10:51 AM   #40
kanundrum
This product is enriched with OE mount bolt directly to the traveling sport diff mount reinforcement is required, but need to sort out and costly to change to strengthen the rear side is usually, and lower the suspension of members It is a revolutionary enhancement that can be mounted. Completed in about one hour work time required.
Was set cheaper product prices and ¥ 12.600
Part of the image becomes part of the gold.
Will be more effective at the same time as installing rigid collar that sells previously.
By strengthening the mounting of the differential, the response can be better to tell the tire firmly on the power transmitted from the engine, leading to traction up.
※ Please note that sound is easily transmitted vibration.
Old 09-20-2012, 10:52 AM   #41
kanundrum
Please see because once you introduce a big throttle in your blog that we have installed, such as suspension the other day. Your car is a vehicle here.
Old 11-05-2012, 11:01 AM   #42
kanundrum
Today BRZ & 86 are receipts from the morning to the pits! Attach the elSPORT Sasupenshishon, BRZ is 86
I own mounting applied, the setting was injected expertise BILSTEIN BSS + rack kit.
I also replaced the front stabilizer, What do I do with the secret? Is
There is also the choice of stabilizer expertise ...
BRZ is to complete setting in elSPORT V1!
Injected into the know-how is already full rack of course this also
When the vehicle is traveling, president of Toyota ... what to visit there!
I was hella surprised.
I was very pleased and woven convey the status of the current 86 and BRZ.
It was a little bit of conversation, I was truly nervous
Seems to have gotten very interested also shown in the recent rally.
Ah ~ I was really surprised
I should have taken that away 2SHOT photo
It is mortifying ('Д ⊂ Gusun
FR-S PARTS CATALOG SYSTEM IS UP AND RUNNING TPO Scion FR-S / Toyota 86 GT86 General Forum 96 06-03-2015 06:16 PM
LUCK Motorsport 86 ZetaVI Scion FR-S / Toyota 86 GT86 General Forum 18 04-04-2012 03:38 PM
Toyota 86 LUCK equipment Harinjo Scion FR-S / Toyota 86 GT86 General Forum 31 02-28-2012 03:18 PM
New Project x2 S2KtoFT86 Other Vehicles & General Automotive Discussions 9 10-25-2009 12:17 PM
