#29 |
I have Tein Flex, been through two winters now, holding up quite well, after cleaning looks almost brand new. I just spray a can of silicone grease over it when I change my wheels to winter tires, and wash my car through a touchless car wash every other day to get the salt and grime off.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
#30 |
Drives: Subaru BRZ Sport Tech Satin White
Adjustable rebound rates aren't really. The adjustability is mainly to allow one shock to work with several spring rates, to broaden the applicability of a coilover design.
The adjustability of the rebound force is intended to be varied no more than a click or two or three for most applications. The entire adjustment range isn't intended to be used for one spring rate. Even if jounce is also adjustable you cannot expect every setting to work. Again, the spring rate pretty much determines the effective or usable adjustment range on your shocks. Once the sweet spot has been found you don't adjust them ever again. You may have two or three sweet spots if you track the car at different tracks but most likely you will have a street setting and a track setting, max. For wet or cold weather you would probably use your street setting, or close to it, even for the track. Lowering the car is also over rated. Unless you are prepared to adjust the alignment and maybe even fit different adjustable alignment components, you can make your car handle pretty much the same at factory ride height as you might by a one inch drop. Indeed, unless the alignment is also adjusted when you change ride height you are likely going to be slower lower. "Handling" mod money goes into tires first, then lighter wheels, then higher temperature brake pads and then when all that is optimized add coilovers and try out the suitable range of settings both for ride height and shock rates. The factory boys do a great job with the stock set up. Except for the crapola stock tires of course.... |
#31 | |
Like Suberman said, there's a sweet spot, and sometimes that sweet spot on the lower end coilovers still isn't that great. I'd take better base valving over adjustable valving that isn't great anywhere every time. - Andy |
#32 |
Drives: Scion FR-S 2013 Raven
Best coilover for winter
Tires first, then lighter wheels, then higher temperature brake pads then suspension....
I know this is the basis ![]() Thank you everyone and in particular Andy. If i buy an coilover set, I will stop my choice on KW V1.
o= FR-S =o |
| The Following User Says Thank You to Mikepage For This Useful Post: | Racecomp Engineering (01-09-2014) |
#33 | |
Which model of pss kit you speaking about? B14 or B16 or both are good? Lifetime warranty? Blistein are made by KW also?
o= FR-S =o |
#35 |
Just drive it
Drives: 13' FR-S
Just a suggestion... is it okay to wrap the shock body's threads during winter seasons? Something durable and ziptie only around the thread body.
#36 | |
Drives: 2014 BRZ Limited
#37 |
Drives: 2014 BRZ
Hi Mike,
I live in Quebec and had a set of KW coilovers on my 2k Celica, car was winter driven, yes they dont rust, especially with all the salt they use on our roads!! The problem i found with KW coilovers, or just coilovers in general, in winter is that the adjustments rings got seized. I was no longer able to adjust the ride hight!! That's why im debating Bilstein B14 coilovers or Bilstein shock and spring combo.. |
| The Following User Says Thank You to rickpalace For This Useful Post: | Mikepage (03-16-2014) |
#38 | |
Drives: 13 FR-s, 84 911
#39 |
Drives: fr-s
I had coilovers and drove during winter with my tein or k sport on my older cars. Ring were always seized but you just have to lubricate them and give them a little bit of love with a hammer and a punch.
#40 |
Lacking brains
Drives: frz
I sprayed my kwv3 with boeshield last winter as an extra precaution.
This year the car will be parked. |
| Coilover Review: FEAL SUSPENSION 441 coilover kit | mr. slim | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 11-28-2019 06:30 AM |
| DG-5 Coilover | harajukukei | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-27-2014 03:42 PM |
| Coilover Help | Legacy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 05-18-2013 03:30 PM |
| FS: (QC) STD R9 Coilover | dompower | Brakes, Suspension, Chassis | 4 | 05-04-2013 04:08 PM |
| Coilover LCA, ATA | ShikoBariki | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 04-18-2013 06:55 AM |
