DIY (Do-It-Yourself) Guides For all DIYs. |
01-02-2019, 11:06 AM | #30 | |
Country Boy 4 Life
If you feel that way, that's fine with me. I have stated how I feel after actually dealing with a few stuck seat bolts.
I LIKE TIRES! |
01-02-2019, 11:20 AM | #31 |
Drives: LS Swapped Scion FRS = 440HP
I used both a heavy duty Milwaukee impact gun on one seat and a breaker bar on the other to remove mine, sheared the torx heads off the front bolts regardless. Rears came out fine on both.
I felt like I could push down more with the impact gun for a better bite, but the end result was the same. |
01-03-2019, 02:52 PM | #32 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
The easiest thing from experience on those bolts that I stripped as well was to heat them for about 10seconds with a torch from Home Depot. A little bit of the carpet got singed in the process but those bolts turned so easy after the heat. You will seriously not believe how easy it is after that
The Following 2 Users Say Thank You to SuperTom For This Useful Post: | eastendraceshop (01-09-2019), jcw99 (07-23-2019) |
02-01-2020, 01:49 PM | #33 |
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
Does anyone have the Toyota part number for the 2017+ hex head seat bolts? Looking to replace the torx type with the updated version. Thanks!
02-01-2020, 02:06 PM | #34 |
if you cant find it, get a M10x1.25 flange bolt
Similar Threads | ||||
Seat rail bolt part number? | nalc | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 12-05-2013 10:16 AM |
Passenger Seat Rail Plastic End Piece Off | skyre | Issues | Warranty | Recalls / TSB | 4 | 12-04-2013 10:56 PM |
need help unbolt seat rail bolt | chenshuo | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 07-01-2013 10:06 AM |
Another seat rail option! Nagisa Auto Seat Rails | vividracing | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 02-28-2013 04:15 PM |
Nagisa Auto D-Lock Super Low Seat Rail | poormans_LFA | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-06-2012 04:35 PM |
