Old 12-28-2013, 01:57 AM   #29
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Too bad he as well as other tuners who might have been able to help have been booted again...
Thats odd.
Deadspool is offline   Reply With Quote
Old 12-28-2013, 02:08 AM   #30
xjohnx
Grip>Slip
xjohnx's Avatar
My money is on a bad pin in the harness. Seems to be a somewhat common occurrence. Wish someone would write a DIY on fixing it.
Old 12-28-2013, 02:28 AM   #31
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Originally Posted by jamesm View Post
weird on the backorder thing... a local bricked his and just picked up a new ecu at the dealer for like $600 iirc.. had it in stock
i guess some dealers have em and some dont. my dealership doesnt do a lot of scion business or stock scion parts. personally i think the backorder story is dealer speak for "its gonna be about a month before we can have your ecu tested to find out what you did to it so we dont have to cover under warranty"...
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 12-28-2013, 02:30 AM   #32
Danklvr
Danklvr's Avatar
@ Skullworks - is that ecu software proprietary or freeware?
Old 12-28-2013, 02:35 AM   #33
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by SkullWorks View Post
I recovered my Bricked ECU with ECUflash software,
It wouldn't recognize with anything at the time of the bricking either.
Do you have a tactrix OP2.0 cable or access to one?
If your ecu was bricked, by definition, it wouldn't be recoverable. What you probably had was a cal ID mismatch that prevented the initial communication. I'm the case of actual bricked ecus, you wouldn't even be able to achieve comms. This could be due to corrupt boot loader. In that case, the only solution would be to reprogram the micro on the board directly (not through obd).
Back on topic, the OP should definitely exhaust all possibilities (bent pin, bad cable, etc). One thing to try is to see if any other diagnostic tool can communicate with the ecu. A cheap $50 generic obd2 reader (from Pep Boys) would suffice. If that is able to read codes, things look good. If that won't communicate, and the pins on the obd2 plug look good, then things don't look so good
Old 12-28-2013, 03:02 AM   #34
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I had. Bricked ecu from bad code a while back. Ecutek had me send them my ecu, and they fixed it. It was about a 10 day turnaround, but way cheaper than a new ecu. I also wrote a DIY in the DIY thread.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
The Following User Says Thank You to Hawaiian For This Useful Post:
gdrider77 (12-28-2013)
Old 12-28-2013, 03:02 AM   #35
steve99
The Ecuflash software is free to download although you will need to get the BRZ Beta version, however you will need a Tactrix dongle to be able to communicate with the ECU
http://www.tactrix.com/
see post for BETA version download
http://www.ft86club.com/forums/showp...&postcount=307
http://www.tactrix.com/downloads/ecu...ta_1444040.exe
Might also want to look here
http://www.romraider.com/forum/viewt...=brz&start=330
appears newer beta version released, its a work in progress
Old 12-28-2013, 03:05 AM   #36
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Well. As I said the elm Bluetooth that I used with torque won't communicate at all, same issue won't connect to ecu. I am going to get under the dash and check very closely all the pins and make sure they all look good. Will look at that tomorrow.
I have been told by a couple tuners that ecutek has the capabilities to recover a bricked ecu, so hoping they will get back to me in the next few days with instructions on that.
Also, why was Visconti banned again? He has been super helpful for me?
gdrider77 is offline   Reply With Quote
Old 12-28-2013, 12:54 PM   #37
xjohnx
Grip>Slip
xjohnx's Avatar
This happened to me once, try this to confirm or rule out a loose pin in the obd2 port
Plug in your EcuTek cable to the OBD2 port and with one or two fingers behind your Ecutek cable, apply light pressure pulling it towards you, hold it in that position while you try to "Detect vehicle" from the ecutek software. If that doesn't work, put light pressure on the EcuTek cable in the opposite direction (push vs pull) and try to detect vehicle again.
I've also found that with the cable disconnected, if you pushing the metal tab on the ecutek cable inboard so that it bends slightly inboard, the cable will lock more firmly into the OBD2 port.
Old 12-30-2013, 12:40 PM   #38
kster1
kster1's Avatar
@gdrider77
Just curious, did this get resolved? Any updates? Thanks.
kster1 is offline   Reply With Quote
Old 12-30-2013, 01:44 PM   #39
gdrider77
gdrider77's Avatar
Originally Posted by kster1 View Post
@gdrider77
Nope, nothing yet. Dead ECU , dead car.
Last attempt was a reboot that Paul from @AVOturboworld sent me. Suggestion from @EcuTek, but no luck.
I am hoping that Paul has followed up with @EcuTek on it, and we are waiting. Not really sure on the status, but trying to be patient, as @EcuTek is overseas, so turnaround time might be slow, plus not sure if they are on vacation and what not. I was hoping they would have at least said something in this post, but appears they dont check the forums too regularly.
Will definitely keep everyone updated on it. Even if i have to pull the ecu and send to @EcuTek, that fine with me, just want some direction at this point.
The Following User Says Thank You to gdrider77 For This Useful Post:
kster1 (12-30-2013)
Old 12-31-2013, 01:31 AM   #40
FA20Club.com
Drives: 2013 White Out FR-S
sent you an email.
FA20Club.com is offline   Reply With Quote
The Following User Says Thank You to FA20Club.com For This Useful Post:
gdrider77 (12-31-2013)
Old 12-31-2013, 02:43 PM   #41
stugray
Drives: 2013 GBS BRZ Limited
I saw a thread on here recently where someone unbricked their ECU themselves but you need some electrical skills.
It required a power supply, a circuit board (or arbitrary function generator) to stroke the watchdog, and some wires soldered onto the ECU to a serial cable.
Or you could send in the ECU and they would fix it for a fee ( I think it was a thread on Romraider)
The Following User Says Thank You to stugray For This Useful Post:
Old 01-02-2014, 08:00 PM   #42
gdrider77
gdrider77's Avatar
For those that are wondering. I was able to get my ECU fixed via remote recovery from @EcuTek. They got in there and were able to get it fixed.
I am awaiting their response on why it happened. Just a FYI. I will update this more once i hear back from them.
The Following 9 Users Say Thank You to gdrider77 For This Useful Post:
Circuit Motorsports (01-02-2014), DriftEightSix (01-03-2014), feldy (01-02-2014), kster1 (01-02-2014), microbionic (01-04-2014), mike_ekim1024 (01-03-2014), Sportsguy83 (01-02-2014), whataboutbob (01-02-2014), Yobiwan (01-02-2014)
lovethe@mentions
Ecutek flash & warranty 3000HP Software Tuning 40 04-06-2015 10:33 AM
FA20CLUB ecutek flash mach330 Software Tuning 19 08-09-2013 10:35 AM
When do you reset the Avg MPG? WRXcellent BRZ First-Gen (2012+) — General Topics 50 01-16-2013 10:30 PM
DynoComp EcuTek Flash JRollar Engine, Exhaust, Transmission 8 01-16-2013 06:16 PM
FA20 Stg 2 Ecutek flash or no? DC-FRS Engine, Exhaust, Transmission 25 12-25-2012 07:13 AM
