| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 | ||
Trust me, I'm the Doctor
You'll find you start stalling less when you get used to it, and also get less "jerks" b/c you can more easily sync your clutch-out and throttle-on foot movements to coincide and apply the correct amount of throttle to keep the rpms in the range to not jerk when you hit the release point. Quote:
That, and it's more fun.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#30 |
Drives: 2013 BRZ Limited AT
What I've learned from driving a variety of manuals from a crappy four banger Mustang, full-on Cobra, STI, etc.
-Skipping gears and keeping revs low while shifting makes things really smooth. I regularly go 1-3-5-6 in the STI. -Slower clutch slip (releasing the clutch slowly) brings smoother shifts, but increases clutch wear. This is the newbie's solution to jerky shifts, generally. -Learning where the engagement point on the clutch is, and adjusting the clutch pedal to a comfortable distance is KEY to smooth reliable shifts. If you do it right, you can bump the pedal and click through the gears with no slop or jerk. -Learning the sound of your engine at various RPMs helps both on the track and putting around town. Figure out the point where your engine starts to bog (noisy, no power to pull away) and you can downshift very smoothly from just above there. Also note, you don't HAVE to downshift when approaching a stop. -Taking off in 2nd is much smoother, but can cause more clutch wear. -A lightweight flywheel makes a noticeable difference in how quickly the car revs up when shifting and made no change to the reliability of my STI. |
| Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 03:56 PM |
| Guesses about Gear Ratios and Wheel Torque | Deslock | Engine, Exhaust, Transmission | 63 | 08-27-2013 02:42 AM |
| RPM at Highway Speeds | sparis45 | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-26-2013 03:41 PM |
| any way to change the gear ratios in manual? | SuperDave | Engine, Exhaust, Transmission | 17 | 10-19-2012 11:07 PM |
| Guesses about Gear Ratios and Wheel Torque | Deslock | BRZ First-Gen (2012+) — General Topics | 4 | 12-01-2011 07:15 AM |
