Old 01-06-2014, 07:13 PM   #29
dssence
Drives: Toyota FT/MT 86
Hi thanks for your reply , can you tell me again what you told me to monitor in realtime the fuel average.. you mean to switch the option to showo n the dahshboard and see in real time the fuel consumption?. Again what about the revs I should be shifting gears.. I'm using the G-on feature. to switch gears properly on each gear.. which shows a triangle blinking when you got to do make the next shift.
Thanks. Why is that the first quarter won't reflect the normal fuel consumption ? sorry I'm not that knowledgeable I just supposed guiding myself from the first quarter tank to see the fuel consumption would suffice.
But I guess it's not.. I also don't know if the fuel the dealer gave me the car with it's RON98 or it's lower.. i've read in a couple forums that if the car it's meant to be for RON98 and you add a lower octane fuel it would have an impact on fuel economy how true is that?
dssence is offline   Reply With Quote
Old 01-06-2014, 07:24 PM   #30
dssence
Originally Posted by mav1178 View Post
Please do yourself a favor and stop gauging fuel consumption from the dash meter.
It is not at all accurate.
-alex
Hi thanks for your reply , why are you saying to stop gauging fuel consumption from the dash meter? which other way would you do to know how many litres are being used for a certain amount of kilometers by not using the fuel gauge?
Old 01-06-2014, 07:26 PM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
www.fuelly.com
My dash says I get over 30MPG.
My Fuelly says otherwise, currently around 25MPG combined after I put on 18" wheels with larger rolling resistance.
Keep in mind the dash gauge is estimating your mileage based on ECU conditions such as throttle position, O2 readings, knock/timing, etc. It will never actually be close to what you'd get in real world conditions, unless what you drive on daily is exactly what the computer fuel consumption map is like programmed from the factory.
-alex
Old 01-06-2014, 07:45 PM   #32
dssence
www.fuelly.com
-alex
Hi alex I understand what you're saying , at first I did think it the ECU had a learning curve. I honestly don't know which are the values my ECU came adjusted from factory settings. But I did measure quarter tank from the beggining and what I do know for sure it's that I did only 36KM with the first quarter tank. The Fuel average at first showed 50Litres/100km CRAZY! after I enabled G-on it came down to 25/100km CRAZY again.
Maybe I should disconnect the battery and reset the ECU.
It could also be the fuel on the tank it's not RON98 .. bein a lower octane.
Honestly I'm out of ideas. what's your bestadvice?
Old 01-06-2014, 07:51 PM   #33
mav1178
mav1178's Avatar
Inexpensive fix:
Drive until cheap fuel is gone. Refill with higher octane. Disconnect battery overnight. Drive normally.
Expensive fix:
Pump your gas out. Refill with higher octane. Disconnect battery overnight. Drive normally.
If your fuel consumption doesn't improve after 2 tanks, document it and take it to the dealer.
-alex
Old 01-06-2014, 10:54 PM   #34
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Dssence
I would suggest the following:
1) the computer in the car makes changes to the timing based on many parameters. The reason the lower octane fuel gives poorer fuel consumption is that the car's knock sensor retards the timing when it hears knock due to the lower octane fuel. Once you get higher octane fuel in the car this should help fuel consumption from this perspective.
2) in the owners manual there will be section that describes the dash buttons and the two that are used to reset the odometer, select the odometers, select the outside thermometer, the average fuel consumption display, the instantaneous fuel consumption display etc. Read this section, understand it and figure out what buttons to push to change the display value you see and how to reset those that are resettable.
3) the average fuel consumption dash readout tends to show a little better than real life calculating the fuel consumption from the km. driven and the fuel added.
4) you should read and record the average fuel consumption, at refill time and then reset the average fuel consumption readout to zero. This will tell you what the computer thinks is going on. Record the odometer mileage since the last refill to full(keeping in mind the instructions on the inside of the gas cap regarding how full full is). Add fuel, and use the fuel amount added and the km. since last refill to measure the real world fuel consumption. You can then compare that to the computer readout to see the difference. Do this for 2-3 tanks of fuel( go down to 1/4 to 1/8 left in the tank before fill up).
5) Driving Style: fuel consumption from a driving style perspective will be a function of when you shift up and down and how much throttle you use. You can see the impact of throttle and shifting by setting the dash readout to instantaneous fuel consumption. It will read blank when stopped and change as you drive with how you use the throttle and shift, but go back to no value when ever you stop the car. The average readout will always show a number greater than zero until you reset it to zero. That is one way to tell the difference between the two read outs in addition to the fact that the average fuel consumption readout screen says avg and L/100 km while the instantaneous readout just shows L/100 km on the screen.
6) you will see some very high instantaneous fuel consumption readings as you accelerate but lower values when cruising. The shorter the duration of higher values and the more time at low values will result in better fuel consumption. If you are seeing real world fuel consumption worse than the worst at the fuely website for this car then you may have a problem. If you are in the range shown there then you probably just need to work on your driving technique to improve to the better end.
Try this for a few tanks of fuel and see what you learn about your car and fuel consumption.
Just a suggestion.
Please note that if you have the dash readout set to avg fuel consumption, your readout can show a higher value because the first thing you do after fill up is accelerate away which uses way more fuel (particularly if you are heavy on the throttle) than cruising on the highway. Over the time to next refill, the average should even out depending on the mix of city and highway driving. Remember the throttle is not an on/off switch! You are allowed to use less than full throttle to accelerate!!
Cheers
smbrm is offline   Reply With Quote
Old 01-09-2014, 01:31 AM   #35
dssence
Hi thanks so much for such a compltete answer. Sorry I didn't answer but I had some personal problems. let me go bit by bit through all your help
Originally Posted by smbrm View Post
Dssence
I've talked to a guy from toyota who said the ECU has a learning curve, is this true? for the first couple hundred km's. Which tells the engine how to inject fuel. Again could a lower octane fuel aside from any other theories be lowering the fuel consumption leading to less KM?. Something I forgot to state was that since I took the car off the dealer I used air conditioning extensively cause it's really hot here now. I thought on new generation cars AC wouldn't be an issue regarding fuel consumption.. but who knows.. just I didn't mention it earlier. Something is going round in my mind , could Toyota have sent these units to my country Argentina with a different ECU setting which is making more fuel consumption? When I talked to User support here, I couldn't believe they covered their asses saying Toyota ARgentina didn't publish Fuel consumption figures here can you actually believe that? so when I said the guys what should be the average consumption rate for city/highway they said we can't back support that as we're not authorized to specifiy those figures.
I didn't know there was a real time fuel consumption monitor. Which of the two options is the instantaneous fuel consumption display, I need to check this. I know for sure there's one which shows the average. So the one you're telling me whenever I stop the car goes to 0. and then when I'm shifting gears varies accordingly to how I throttle the car and shift gears ?
Is G-on feature useful ? which tells you on the display when to shift gears for supposed fuel economy? or it's useless?
Can you explain a bit more here. What I thought I would do was to go almost empty this fuel tank cause it's how I got the car from the dealer which I don't know which Octane fuel rating it has, so I would just use the car to empty the tank and then do a full refill with 98 RON OCTANE fuel from shell v-power nitro. Then I would reset the trip B to 0km. And then when I get where the second quarter tank begins with the needle I would read the trip B kilometers rolled.
This is something I wanted to discuss.. believe it or not I come from a toyota celica 1979 liftback model and that was my jump to the FRS. so big jump. What I did feel was that the accelerator from my old celica I would rev the car like more specifically to the RPM's I wanted, and I have the impression " correct me if I'm wrong" that when I accelerate on the FRS the revs go to the sky I cannot rev accordingly to the RPMS specifically like I could do with my old car. Maybe I sound stupid, maybe it's a matter of getting accostumed to a new car like this one. Maybe this sudden revs is making the fuel consumption excesive on my foot.
Certainly that was what I was referring to on the previous statement. I think I'm not adjusting properly the REVS on my foot , when pressing the accelerator. I don't know if that's cause the car has an accelerator sensitivity issue.. or it's my foot problem. Again Average fuel consumption per litre for 100km what should be a figure here. If this doesn't improve could the ECU be programmed badly for fuel optimization?
Just a suggestion.
Additional Note : whenever I start my car.. I see the car increases revs for a couple of secs.. and then stabilizes is that normal?
Thanks so much ! I really apreciatte all your help and time
Cheers
Old 01-09-2014, 03:14 AM   #36
strat61caster
strat61caster's Avatar
How many km's have you driven total?
It is difficult to analyze fuel consumption over a short interval, there are too many variables.
ineedyourdiddly
Old 01-09-2014, 03:18 AM   #37
dssence
Hi honestly not that much, around 40km , with around 1/4 tank.. using AC. Some guy from toyota told me the car needs to be rolled at least around 100km for the ECU to properly adjust.
Old 01-09-2014, 05:52 PM   #38
smbrm
smbrm's Avatar
There is a button on dash that is marked DSP. If you press it, each press should cycle through the options that include "out side temp", "avg L/100 km", and "L/100 km". if you press and hold when showing "avg L/100km" the average will be reset to zero. Suggest you read about it the owners manual!
Yes, using air conditioning a lot will lead to higher fuel consumption.
I think you may just have a heavy foot. My automatic accelerates adequately with very little throttle application.
You need to read the manual and drive the car to find out how it works. Yes it will be quite different than late 70's Celica that was probably carburetted.
Come back after 2-3 tank fulls of experience.
Quick question about a dealer trading another dealer for the BRZ I want Prog BRZ First-Gen (2012+) — General Topics 17 09-15-2013 03:03 PM
Dealer can't flash my ecu... jm1681 Issues | Warranty | Recalls / TSB 16 09-05-2013 05:47 PM
Would you buy a car from a dealer that stuck a dealer (ad) plaque or sticker on cars? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 49 04-29-2013 03:37 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Servicing my FR-S at Subaru dealer rather than Scion dealer dnL Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 08-28-2012 07:25 AM
