Old 10-10-2013, 09:36 PM   #29
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
These are freaking beautiful!
Corner3garage is offline   Reply With Quote
Old 10-11-2013, 02:56 AM   #30
humanshield
Drives: bucket
been saving my pennies for the same setup. congrats on yours. maybe by spring for me.
humanshield is offline   Reply With Quote
Old 10-12-2013, 10:41 PM   #31
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Dezoris View Post
You will be going much lower than I did on these. Be curious on your thoughts on how you liked adjusting height front and rear.
They're super easy to adjust height on car NO? Interested to hear if this is incorrect in thinking..
Old 10-14-2013, 04:54 PM   #32
Dezoris
Dezoris's Avatar
I could not get the rear to adjust without removing the shock from the control arm on one side. Trying to double up wrenches is almost impossible with little clearance in the back.
Adjusting the front is also something you need to have the wheels off for and can be tricky but not much different than other coils. Took two weekends to do, measuring, adjusting, re-measuring, settling re-adjusting.
This excludes corner balance.
The Following User Says Thank You to Dezoris For This Useful Post:
OICU812 (10-14-2013)
Old 10-14-2013, 05:38 PM   #33
eckoflyte
Drives: Toyota 86 GTS
Hey savage, what was your method for measuring and getting the correct height settings? Did u take into account driver weight?
eckoflyte is offline   Reply With Quote
Old 10-14-2013, 06:29 PM   #34
Dezoris
Dezoris's Avatar
We used weights in the car when setting up 3x 50lbs. And then alignment we used actually driver weight plus 20lbs for gear.
We found using a large meter stick with mm and micrometer was easiest for measuring. On the alignment rack we got the car level, set pressures then measured from ground to center of fender metal and placed marks for repeatability. Re-measured 3x to make sure our readings were accurate.
Our initial alignment was basic because we gave a week for suspension to settle before we did anything else. Glad we did.
eckoflyte (10-14-2013)
Old 10-14-2013, 07:00 PM   #35
Dezoris
Dezoris's Avatar
You can see here basically you losen the bottom lock nut and the entire shock body can be rotated to adjust height without changing pre-load.
@eckoflyte @OICU812 @mav1178
Now the issue was on the other side we could not turn the shock body by hand so we actually had to remove the shock from the control arm which made it much easier to do.
We replace all nuts and suspension bolts as well so make sure you if you do what we did at the very least use red thread lock on all the bolts.
Could Not Rotate Shock Body:
FINALLY REMOVED SHOCK FROM ARM TO ADJUST:
FYI goal to finish this video this month along with the others way behind.
Old 10-14-2013, 07:12 PM   #36
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yeah @Dezoris I'm fully aware of how the height is adjusted on this setup, not much different from other coilovers I've used before for all types of different cars.
Will reserve judgment on how easy/hard it is to adjust height until I actually install the suspension, but this all just comes with the territory of owning adjustable suspension, in my opinion.
-alex
Old 10-14-2013, 07:14 PM   #37
Dezoris
Dezoris's Avatar
-alex
I am not implying you didn't. I will stay out of your thread until you get your final install done. Looking forward to it!!
mav1178 (10-14-2013)
Old 10-14-2013, 07:18 PM   #38
mav1178
mav1178's Avatar
haha contribute all you want... I reserved Post #2 for my own install pics.
Always good to pool info together.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
OICU812 (10-14-2013), RYU (10-14-2013)
Old 10-15-2013, 09:49 PM   #39
3 pedals n a stick
Drives: white out frs
I have these installed on mine for the last 2 months now love them! Live in cali no salt here unless I drive in the ocean.
3 pedals n a stick is offline   Reply With Quote
Old 10-18-2013, 04:20 AM   #40
Anaxilus
Drives: They have four wheels
Originally Posted by solidONE View Post
The height adjustable strut is an unbelievably snazzy design. I don't think I've ever seen this beside on Ohlins struts. Mustbenice
Endless Zeal and a few others have had similar designs for decades just FYI.
Anaxilus is offline   Reply With Quote
Old 10-20-2013, 03:30 AM   #41
OICU812
Just a dude
OICU812's Avatar
How's it going Mav?, get chance to get em on and broken in?
People keep mentioning rates of these coils in 343/343 spring rates? Every vendors store I look at they're 515 front and 400 rear..so what's that all about?
Old 10-20-2013, 02:00 PM   #42
mav1178
mav1178's Avatar
Havent' installed them yet... but the spring rate on mine are 6/6 kg/mm (~337 lb/in)
That's the standard setup.
-alex
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 06:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 01:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 05:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 04:27 PM
