Old 08-28-2013, 12:03 PM   #29
ARK Performance
ARK Performance's Avatar
Drives: Subaru BRZ
GRiP, average 6 HP midrange increase
DT-S, average 9 HP midrange increase
@dokterdewe: please email me, lerry@arkperformanceusa.com
ARK Performance is offline   Reply With Quote
Old 08-28-2013, 12:40 PM   #30
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Originally Posted by dokterdewe View Post
hi there Lerry @ARK Performance i am a member with residency outside US, that is Indonesia.
can i contact you about Ark DT-S ? well surely hope you can help me in pricing and custom invoice note..
thanks..
You could also try contacting Titanmotorsports on here. They are a distributor of ARK that I bought mine through. I am international as well (though Canada is quite a bit closer) so they should be able to hook you up.
Nolan
pheoxs is offline   Reply With Quote
Old 08-28-2013, 11:42 PM   #31
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
i have mailed you please kindly help me..
i will try contact lerry first.. thanks for the help..
dokterdewe is offline   Reply With Quote
Old 08-29-2013, 02:51 PM   #32
ARK Performance
Drives: Subaru BRZ
Responded to your email @dokterdewe
Old 08-29-2013, 08:38 PM   #33
dnjshin0bi
dnjshin0bi's Avatar
Drives: 86 GTS (PW) Manual
@ARKPERFORMANCE, what is the weights of these 2 exhaust systems in comparison to the stock catback?
Thanks.
dnjshin0bi is offline   Reply With Quote
Old 08-30-2013, 01:40 PM   #34
ARK Performance
Drives: Subaru BRZ
The DT-S I believe was about a pound lighter and GRiP was about 2 pounds lighter give or take, we didn't have a proper scale to really measure oem, GRiP, and DT-S to an extremely accurate number but this is what our scale gave us
Old 08-31-2013, 09:18 AM   #35
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
@Titanmotorsports I live close by but could not see anything on your website about ARK. Do you have any available? And how much?
Enraged21 is offline   Reply With Quote
Old 09-03-2013, 01:20 PM   #36
Titanmotorsports
Titanmotorsports's Avatar
Drives: Supra
Send a message via AIM to Titanmotorsports
Pm'd
Titanmotorsports is offline   Reply With Quote
Old 09-03-2013, 01:45 PM   #37
ARK Performance
Drives: Subaru BRZ
Here's the link to the ARK GRiP cat-back from Titan
http://www.titanmotorsports.com/ark-...p-exhaust.html
Old 09-06-2013, 07:56 PM   #38
SigmaHyperion
Drives: 2013 SWP BRZ Limited
I'll get some pictures up in a day or two, but wanted to give some feedback...
Got my DT-S and Test Pipe installed last night.
I went into a bit worried about getting the right fitment based on some comments. Got everything hung (on urethane hangers), started tightening at the front and made my way back. Got out from under the car to check the tips -- absolutely perfect fitment.
I've done probably 10 installs of exhaust on my own cars. Probably helped on 50+ over the years (used to own an online aftermarket company with a storefront). I've never seen an exhaust that didn't need one iota of adjustment. It just went on.
As for the sound...
I've never had an exhaust that can go from so loud to absolutely silent depending on the RPM and load. And, strangely enough, the thing gets significantly quieter (drone-wise) as the RPMs build -- at 7000rpm there wasn't a ton of sound in the car, until one rolls down the windows. It sounds absolutely epic, but (at least with test pipe) it does drone at certain RPM levels, and the lower the RPM the worse. The dreaded torque dip is even worse now, as that seems to be where it drones the most -- probably due to a higher engine load in that RPM range. Drop a gear and it largely goes away. Not remotely as bad as most exhausts I've heard, but I was definitely hoping for less. And I will stress that this is with the test pipe.
I'm hoping for some improvement as it breaks in. Plus figure some Dynamat, which was already in the plans for road noise anyways, in the trunk will help because it actually seems like a fair bit of the drone is actually simply from the sound bouncing around in the empty trunk. It doesn't sound as much as the exhaust is droning as the trunk is just a big reverberating sound cavity.
Overall, the sound is simply too epic for me to be disappointed by the drone. It's fairly minor, I'm hoping it'll dissipate as it breaks in a bit, plus I think some Dynamat will help immensely. I'm not gonna go so far or be so pretentious as to say it sounds like a supercar, but it's definitely something that leans in that direction. It's a strange phrase, but the sound really compliments the car.
I do worry about the sound after a header install. But that seems to be an across-the-board worry with this car, as just about everything seems to make the car incredibly loud without some custom resonator installs.
As for ARK in particular -- I really would like to see your company tackle headers before the market gets too saturated. I've seen a LOT of exhausts over the years, from just about everyone under the sun, and the quality of this exhaust is right up there with the best I've seen. Not just arguably some of the most attractive exhausts on the market, but awesome craftsmanship with beautiful welds and, as already said, absolutely perfect fitment. Would love to see what you can do with a header setup that compliments the sounds of your exhaust.
SigmaHyperion is offline   Reply With Quote
Old 09-06-2013, 11:14 PM   #39
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
As for the sound...
So what RPM's does it drone on 6th gear? We good up to 75?
Old 09-09-2013, 11:24 AM   #40
ARK Performance
Drives: Subaru BRZ
@SigmaHyperion: We are definitely still considering headers and over pipe, and thank you for the honest review! We are always looking for areas to improve in to make sure you guys get the best product!
Old 09-09-2013, 01:09 PM   #41
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Sigma and to anyone wanting to reduce cabin noise. Dynomat is NOT what you want, that is a vibration isolator. You want a noise isolator, look into thermal damping mat, or noise isolation matting, such as these products.
http://zeronoise.com/automotive_nois...automotive.htm
Old 09-09-2013, 01:44 PM   #42
funx
Drives: 2013 frs
that looks amazing, thank you
Introducing...ARK Performance USA!!!
We recently just joined FT86CLUB and want to personally let FR-S/BRZ owners that we are here for the community so ask us anything! As a quick introduction here are two product sheets on the exhaust systems we have to offer that you can get through one of our authorized dealers! As of now we will not be conducting direct sales so please contact one of the authorized dealers:
Titan Motorsports (@Will)
THMotorsports.com (@Alan)
Corner3Garage (@Mike)
FT86SpeedFactory
ModBargains
...and more on arkperformanceusa.com
And of course if you have an ARK Performance exhaust please share, the more pictures the merrier!
Sincerely,
Lerry @ ARK Performance
funx is offline   Reply With Quote
►►The Definitive LOWERING SPRING Thread◄◄ LOWEST PRICES ON FT86Club & FREE Shipping!! CygnusPerformance.com Brakes, Suspension, Chassis 38 08-05-2013 01:28 PM
►► SUPER PRO ◄◄ Every Single BRZ/FS-R Part They Make IN STOCK NOW with Free Shipping! CygnusPerformance.com Brakes, Suspension, Chassis 30 08-01-2013 06:28 PM
► Styluz Wheels ► 17x7 18x7.5 5x100 ► In Stock ► Free Shipping FM Wheels Wheels and Tires 2 08-01-2013 05:18 PM
►►►► For a Limited Time Only Like Cygnus Performance on Facebook Get $5 FREE!!!* ◄◄◄◄ CygnusPerformance.com Announcements, Contests, Giveaways 1 03-08-2013 07:04 AM
►►Stance Super Sport Coilovers◄◄ Free Shipping - Photos and Video FT-86 SpeedFactory Brakes, Suspension, Chassis 43 01-31-2013 09:17 PM
