Old 08-23-2013, 12:10 PM   #29
ayau
Drives: Some rust bucket
Originally Posted by StormTrooper View Post
Well I have wheels, inlet tube, and light flywheel.
AutoX is just for fun...I mean I like to win but eventually I'm getting a aluminium drive shaft and that'll put me in some crazy class
I'm assuming you're running RTR CS class right now since you said you can only replace the shocks. You're technically not legal with the inlet tube and the aftermarket flywheel. Not sure what size your wheels are but you're basically limited to 17x7 +/- 6mm in offset. I'm sure at the local level, it won't really matter unless you start WINNING.
Old 08-23-2013, 05:21 PM   #30
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I havent done anything with suspension yet.....
I ran cs but should have been in stx or really n stx since ive only ran twice.
Since it's a DD stx seemed the best direction since most are common easily done mods.
I want headers since I really dislike the dip and it needs more punch especially at a mile high.
Also the courses here are small compared to other places....AS coverettes are down in the low 30 sec range.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
AutoX coil-overs what should i get? subaruferrucci Tracking / Autocross / HPDE / Drifting 4 02-19-2013 04:03 PM
Coil-overs \ Spring kit ????? v3rgil AFRICA 9 11-16-2012 09:27 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 10:12 PM
