| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: Argento FRS
I ripped the front badge off a paseo and literally just double sided taped it on. and you wouldn't be able to tell unless you go right up to it and look that its stuck on
#30 | |
Drives: 2013 Whiteout FR-S
#31 |
Drives: FRS
A black plastic mouse pad. It separates from the foam/rubber under it and you can attach it to the back of the Toyota logo and then to the steering wheel.
| The Following User Says Thank You to Nothing For This Useful Post: | Randyliciious (02-21-2014) |
#32 |
Drives: '13 frs
just out of curiosity if the airbag were to deploy with this diy badge, would you have a toyota emblem stamped on your face or is the way the airbag is designed to break apart more clever than that ?
#33 |
Drives: Scion FR-S
I said the same thing in another thread and most bashed me and thought I was crazy. But to answer you, yes you probably would have a toyota stamped on your face.
| The Following User Says Thank You to ScorpionOzzy For This Useful Post: | jkr (04-15-2014) |
#34 |
Drives: SWP FR-S
Nice!
#35 |
Drives: '13 Firestorm Base AT
#36 |
Drives: Toyota
I don't get this.. But wouldn't scion be stamped on our face without the emblem swap.. This isn't removing part of the airbag, just the emblem.
#37 | |
Drives: Scion FR-S
Like This: ![]() The Scion badge is adhered on there with strong adhesive and what look to be plastic pins, to keep it attached when the airbag deploys. and let me also say that it has been TESTED by the manufacturer. If your glued toyota badge doesn't stick properly to the airbag, or the glue isn't stong enough. When the airbag deploys WITH STRONG FORCE, the badge will become a projectile. |
| The Following User Says Thank You to ScorpionOzzy For This Useful Post: | FRSure (04-26-2014) |
#38 |
♥カレー大好き !!
Drives: ♿
did mine a couple days ago... im very satisfied with how it came out.
i used adhesive-backed black crafts foam lying around for the backing. ![]()
| The Following User Says Thank You to zAnSh1n For This Useful Post: | Dadhawk (05-26-2014) |
#39 |
Drives: 14' FRS, 90' Miata
Just ordered mine, can't wait to replace these scion badges...
#40 |
Drives: 2013 Subaru BRZ Limited in WRB
You guys do realize you're putting an insecure object, on top of a bomb, that can go off at any time, directly in front of your face??
Definitely looks awesome though - it's really funny seeing everyone jump on board using different backgrounds.
#41 | |
Drives: Toyota GT86
I was thinking to order this emblem but I don't want to engrave a 86 logo into my face if something bad is gonna happen.
#42 | |
♥カレー大好き !!
Drives: ♿
seat belt + curtain/side air bags are enough for me
| WTB: Stock steering wheel (wheel not airbag) | mobybrz | Interior Parts (Incl. Lighting) | 2 | 09-11-2014 03:23 PM |
| Steering wheel swap questions | firl21 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-02-2014 09:27 PM |
| scion frs steering wheel air bag and steering wheel | Jhon19lopez | Interior Parts (Incl. Lighting) | 7 | 01-04-2014 07:04 PM |
| Would it be easy to swap the front of my steering wheel? | bdanisi | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 05-11-2013 04:34 PM |
| Swap your Scion key emblem for a Toyota | Synack | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 08-03-2012 06:58 PM |
