Old 07-31-2013, 12:41 AM   #29
root
Drives: Raven FR-S
Originally Posted by grodenglaive View Post
and turn the fan on high = turbo + intercooler
It almost sounds like perpetual energy to run your a/c, which takes power, and run the cold air to the intake to make more power, but i think some companies experimented with that. I think the Ford Lightning?
Ah, just looked it up, it was a concept car and the a/c "charged" up a cooling resivour that would dump into the intercooler to give added cooling for a limited amount of time. Supposed to give you a boost when demanded, but once used up would take some time to recharge.
You could try water injection, but that can be a tricky thing. Again limited to when you run out of water.
root is offline   Reply With Quote
Old 07-31-2013, 01:03 AM   #30
Tromatic
Freeze car overnight?
Tromatic is offline   Reply With Quote
Old 07-31-2013, 02:52 AM   #31
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
When I and other people autox we often put bags of ice in our intake box so it can suck in cold air (I have a injen SRI so the box it comes with is perfect for this). This helps alot for short driving. So my suggestion to you is to install a ice maker machine in your engine bay and have it feed fresh ice straight into the intake box!
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 07-31-2013, 03:17 AM   #32
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Tromatic View Post
Move north? A cold-air intake provides cooler, denser air for the intake system, typically farther away from the engine heat under the hood. When the air itself is on fire, what can you do?
Originally Posted by pmdc View Post
You lose a bit of power when it's that hot, as the air isn't as dense. A CAI would help a *tiny* bit, in theory. Maybe not a noticeable difference.
Funny... my friend (editor at Import Tuner) is doing a MPG build on a Civic, testing out a "warm air intake".
Apparently it's meant to improve fuel mixture and increase volumetric efficiency.
We shall see.
-alex
Old 07-31-2013, 03:53 AM   #33
lgunnz
Drives: 2013 Toyota GT86
You want to know about slower cars in the summer, come here to Abu Dhabi! 120+ degrees with over 100% humidity! Not fun!
On teaching the girlfriend, just keep at it. I had the same problem teaching my wife and she wasn't just learning stick it was learning to drive period. At first it was terrible because she's the type that gets frustrated quickly if she doesn't pick something up right away. But with a little patience on my part and persistence on hers she not only got it after 3 tries but drives better then most people I know. Though she still prefers autos.
lgunnz is offline   Reply With Quote
Old 08-01-2013, 01:54 AM   #34
DIF
DIF's Avatar
Drives: FR-S in Firestorm, Katzkin, alpine
Teach her to drive a motorcycle first. once you know how to do that it's an easy conversion.
DIF is offline   Reply With Quote
Old 08-01-2013, 06:05 AM   #35
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
my advice, just dont worry about it. engines are hot, the air is hot, engine is still hotter. If you really worry about it, maybe consider different fluids (oil, tranny, coolant)
mrlewistan is offline   Reply With Quote
Old 08-01-2013, 10:15 PM   #36
humfrz
Well, I've been to places that feel that the humidity is over 100% ...... however, 100% is the highest relative humidity possible....... ..... outside of a pressure cooker or something like that .....
humfrz
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
common ways to sell online three3y3wrbbrz Off-Topic Lounge [WARNING: NO POLITICS] 1 04-15-2013 02:20 PM
Lowered Car, Losing traction while getting off drive ways 86_ZN6 Scion FR-S / Toyota 86 GT86 General Forum 54 10-26-2012 10:02 AM
Lemon laws or equivalent ways to resolve issues with Toyota in Canada? Ahz CANADA 2 09-11-2012 09:49 AM
