#29 |
Hella Flush
Drives: 2013 SWP BRZ
I had to pass through the Bronx area to drop some people off and i did watch out for the crappy roads but when i couldn't avoid them it was not bad at all.
#30 |
Here's a couple bad pics of my car. I left the front where it is, but had to raise the rear an inch up from where it was in this pic. Initially the rear was probably 2" lower but now it's at 1'' or 1.5" drop.
I stuffed 265/35 Michelin PSS tires on 18x9.5 wheels with +45 offset which made for a perfect flush fit but the rear tires rubbed on the fender tab with 2.35 degrees camber. I'm going to trim the tabs, and add a little more camber and drop the rear back down when I get a chance. |
#31 |
Power Ranger
Drives: 86
Great Review, leaning towards ST coils now. It's comforting knowing they're manufactured by KW
Autofashion | FIVEaxis | Enkei
#32 |
Just drive it
Drives: 13' FR-S
They're really not bad for the price, it's basically same as KW V1 using regular steel body coated with anti-corrosion spray.
#33 |
Drives: 13' Subaru BRZ Limited SWP 6MT
Only problem with the ST coilovers, that has me going with something else, is they don't have ride height adjustment independent from spring pre-load. So for those looking to go low, you'll be riding the bump-stops on these. Otherwise great coilovers for the money.
For the price of the ST's with top camber plates, I'll be doing Fortune Auto 500's instead. They're digressive, hand built in USA from high quality components, separate ride height adjustment, have a great ride, and come with 5 yr warranty. |
#34 | |
Hella Flush
#35 | |
Slammed...maybe the separate ride height and preload is more of an advantage. - Andy |
#36 |
Drives: White frs
i plan on getting these as well and i was just wondering if you had to get camber kits for proper alignment?
#37 |
Hella Flush
I ended getting the crash\camber bolts for the front for more camber. I had the alignment done today and it steering feels a bit tighter and no front rubbing issues.
#38 |
Drives: White frs
#39 |
Hella Flush
Yup rears are stock, if I ever decide to fully road race the car then my setup will totally change. For the time being I will enjoy driving the car to work and around and about.
| The Following User Says Thank You to Ny Brz For This Useful Post: | 86socal (08-10-2013) |
#40 |
Drives: 2013 Scion FRS Whiteout
Is that the lowest you can go? Looks good! Thinking about getting the same coilovers.
#41 |
I just dropped my car 1.5" or maybe a little more on ST coilovers and the front had no issues with alignment but the rears cambered out to -2.35 degrees and I was told I needed the camber bolts to go back to less camber in the rear.
#42 |
Drives: 2013 Black BRZ Limited
You can't use camber bolts in the rear, although some people have tried. I would not recommend the camber bolt in the rear method. The two best ways to adjust rear camber are the whiteline camber adjustment bushings or any of the various control arms. Personally, I like the SPC control arms due to their cost, factory look, and ease of adjustment. They won't adjust as far, only +-2 deg, but I like how the adjustment point is towards the outside edge of the arm.
| RS*R Sports-i coilovers - install & review | ultra | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 50 | 07-27-2022 06:29 PM |
| Suspension Review: KW v3 Coilovers | DarrenDriven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 07-10-2015 12:42 AM |
| Mann Engineering Coilovers review | l8apexr | CANADA | 10 | 03-11-2014 01:11 PM |
| FR-S Coilovers Review | sraggs42 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 05-14-2013 01:16 PM |
| Who likes blue? FT-86 SpeedFactory Review - Standard R3 Coilovers | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 04-27-2013 04:50 PM |
