| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Btw - what is a Zx6?? I thought the code for this car was AS-1?
#30 |
Drives: an awesome one
I was wondering why no one mentioned those little blind spot mirrors that you can stick on the side mirrors.
#31 |
Drives: BRZ(sold), STI
#32 | |
Drives: 2004 350z
Oh and as far as the blind spot, I don't think its that bad. I mean in my 350 its BAD and you learn to change lanes using the mirrors adjusted correctly. Knock on wood but 6 years driving it in long commute. |
#33 | |
Drives: 2006 Scion tC RS 2.0
Brake. Turn. Accelerate. Repeat as necessary.
#34 |
Drives: SSM BRZ-L 6MT (gone)
Adjusting the side mirrors as C&D described (which I've been doing for 2 decades) doesn't mean you just glance in a side mirror, assume it's safe, then swerve to the next lane. All the driver has to do with the side mirrors aimed further out is lean their head towards the side they want to check while still looking at said side mirror. That creates a sweep of the area adjacent to your car as well as further out, without the need to turn completely around.
If you decide to aim the mirrors towards the side of your car for the motorcycle lane-splitting example, now to check the adjacent lane for cars you have to turn your head around. The C&D described method is clearly quicker and safer - your head remains pointed towards the road so your peripheral vision will still catch action in front of you. The turn to check a blind spot is a very unsafe moment while driving at highway (or higher) speeds. It's also essentially the way you need to adjust mirrors for racing. Can't physically look for a blind spot with a helmet on. You have to use the side mirrors as I described. HANS type devices have limited head movement even further. |
#35 | |
Glorious BRZ Master Race
Drives: Subaru Libird
![]() ![]() The time it takes to focus when turning your head alone without aid of a convex mirror is significantly more. After owning a few sport coupes with horrible blind spots, I've adapted ways to heighten awareness of my periphery. The convex mirror is but one tool and, yes, it takes some getting used to, but once you get it you'll never go back (only for cars with bad blind spots; I don't use convex mirrors on my SX4). You'd still want to turn your head with it (gotta watch for those riders), but the time and refocusing effort you need to take for that head turn becomes drastically reduced. Without convex mirror: Turn your head and lose sight of road in front (completely out of periphery) for the entire time it takes you to survey your blind spot, then turn back to re-focus on road in front. Worst of all, your check was still blocked the by C-pillar so you never know what's behind it. With convex mirror: Check side view and convex mirror so road in front remains in periphery, do a quick glance to your side for any glaring objects (no need to take time to survey) as a fail safe. Since it was just a spot check to the side, the road in front remains fresher in your memory. It completely reveals what's hidden behind your C-pillar. Best part: Whenever there is something in your blind spot, 99% of the time you will catch it in your convex mirror first and you never had to turn your head and lose time surveying the blind spot then re-focusing on the front --> Analogy: Convex mirror is to GPS navigation as head turn is to directions printed out on paper from Mapquest. You absolutely won't be turning your head losing and struggling to regain focus as much! Using convex mirrors in conjunction with a quick side glance is worlds safer than using either exclusively; saved my ass several times.
#36 | |
Still Dreamin'
Drives: 2001 Chevrolet Tahoe
#37 | |
They call me..."Ken"...
Drives: '04 Accord V6 MT
I've had much success with this adjustment method with most of the cars I drove, I can't say how bad it might be with the BRZ but as long as the rear windshield is wide and high enough, I think we'll be OK. |
#38 |
Gundam Meister
Drives: A Gundam
That's a good question we should keep in my mind once some of us test drive.
#39 | |
Hot Dog
Drives: quicker than arghx7
![]() FWIW, this car being a 2-door means the B-pillar is further rearward than a sedan. This automatically moves the B-pillar out of the way for your actual peripheral vision, and puts it in the typical blind-spot vision space you should be reserving for your side view mirrors. After sitting in the car and fiddling with the mirrors, I don't foresee any noteworthy blind-spot problems. Of course it doesn't have the amazing visibility of a MINI, but few cars do. As a reference point, the B-pillar on my Golf is so obnoxiously thick that I pretty much can't see directly next to me without moving my head, so I'm looking forward to having the B-pillar moved aft and out of the way.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#40 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
99% of the danger of blind spots is not being familiar of where they are. Once you know where you're blind, you can compensate.
I'm not too worried. Worst blind spot I've ever had to deal with was on a Chevy Colorado pickup. (WORST engineered POS I have ever driven) The B pillars don't look that big or intrusive from the outside, but from the inside I've lost many a car behind them. |
#41 |
Drives: n/a
right, blind spot might be bad, but definitely not as bad as the muscle cars. It shouldnt be much of a worry.
#42 |
Drives: '21 Civic Type R
Zx6 is the chassis code in general - ZN6 is for the Scion, ZC6 is for Subaru. As seen here:
Scion (well, Toyota since it's JDM): http://www.ft86club.com/forums/showt...t=chassis+code Subaru: http://www.ft86club.com/forums/showt...hlight=chassis
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram! |
| Driver Comfort Concerns | Audi | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 01-02-2012 09:52 PM |
| Production Questions and Concerns | Clamp | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 12-01-2011 04:43 PM |
| interior room concerns | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 73 | 05-01-2011 10:33 AM |
