Old 08-02-2013, 09:59 AM   #29
Dezoris
Dezoris's Avatar
Originally Posted by Sportsguy83 View Post
Have you tried asking the dealer how much the connector costs? Have you tried getting it under warranty?
Maybe the connector itself is not that expensive and it is a plug and play replacement?
Also, non-motor related stuff still has warranty and I have gotten work done from my dealer for non power train related stuff.
The cable is OBD2 port is an entire cable and assembly and is $800 from Carson Toyota, major labor to swap.
Warranty might be worth it but not if the car is all modded and tuned.
The Following User Says Thank You to Dezoris For This Useful Post:
Sportsguy83 (08-02-2013)
Old 08-02-2013, 10:00 AM   #30
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by whitefrs View Post
We tried every possible way with it and it still stops halfway.
We know for sure is not the map as he load this same map to another turbo frs
Have you tried a different cable? I know @swift996 had a similar problem that ended up being a bad ecutek cable.
Old 08-02-2013, 10:01 AM   #31
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Mine,Johns and Jrs and problem
Persist.-
Old 08-02-2013, 10:02 AM   #32
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Did u check my pm?
I sent u a link as u are the only person i know that replaced the obd2 port
Old 08-02-2013, 10:05 AM   #33
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
http://www.bmotorsports.com/shop/pro...k9j6vmohvi2c43
Old 08-02-2013, 10:10 AM   #34
Dezoris
Dezoris's Avatar
Did u check my pm?
I just responded. sucks about digikey. But for people having an issues its the female pins on the OBD2 they are extremely sensitive. 3 of mine were destroyed. 5 of 6 OBD2 scanners would flicker or not work.
Re-wired it and used an extension cable for all my OBD2 needs now not to damage main port.
Old 08-02-2013, 11:27 AM   #35
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I bought an extension cable some days ago too.
Old 04-07-2014, 03:00 PM   #36
1Cor10:23
1Cor10:23's Avatar
Does the plastic port itself originally have some play to it? Just noticed today as I was switching between OFT and BT adapter, some wiggling of the port itself. Connection seems okay, will get an OBD extender/splitter.
Old 04-07-2014, 03:32 PM   #37
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yes. that's normal. mine works fine. i just becareful when pulling out cable
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
1Cor10:23 (04-07-2014)
Old 05-02-2014, 05:10 PM   #38
xjohnx
Grip>Slip
xjohnx's Avatar
Just rewired mine, it wouldn't have been such a bad job if you didn't have to be a contortionist in order to access the wires under the dash. The proper tools also make the job MUCH easier. I picked up an extremely overpriced Delphi ratcheting crimper, but it gave perfect, clean crimps every time.
That's how the symptoms usually starts to present. My bluetooth adapter would drop connection randomly over bumps, same with my ecutek cable while logging and hitting bumps. I found that if i ran the wire on the ecutek connector in a manner such that it kept pressure on connector while in the obd2 port that it would help a little, but it continued to get worse (to the point where i lost connection in the middle of flashing a new rom a couple times.)
Repinning it seems to be the only real solution.
The Following User Says Thank You to xjohnx For This Useful Post:
zc06_kisstherain (05-02-2014)
Old 05-02-2014, 08:08 PM   #39
zc06_kisstherain
Drives: SWP BRZ
I am thinking to get extended obii cable and never touch it
Old 05-02-2014, 08:37 PM   #40
xjohnx
Grip>Slip
xjohnx's Avatar
If its already loose you may be too late for that to work.
Old 05-02-2014, 08:54 PM   #41
1Cor10:23
1Cor10:23's Avatar
Don't just extend, get a splitter as well
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Old 05-02-2014, 09:16 PM   #42
Dezoris
Dezoris's Avatar
If you run an OBD2 BT adapter like OBD2MX the male pins are very thick and the factory OBD2 female pins will get damaged after only 10 or so connections. Always use an extension cable for these.
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
DIY: OBDII plug relocation solma DIY (Do-It-Yourself) Guides 6 05-30-2013 12:11 AM
OBDII Connector nzer AUSTRALIA 64 05-09-2013 02:44 PM
OBDII (OBD2) Connector nzer Electronics | Audio | NAV | Infotainment 35 04-21-2013 12:36 AM
OBDII iPhone app/adapter phanguy Electronics | Audio | NAV | Infotainment 2 03-12-2013 12:34 PM
