Old 08-13-2013, 05:52 PM   #29
Takumi_Fujiwara_GT86
TEAM HYBRID
Drives: FRS Limited Edition
Originally Posted by mikemcberty View Post
only -3 up front right off the camber adjustment on the coilover pillowball mount. the front is factory settings at 0. no camber kit. No pulling, rolling, shaving of the fenders.. no rub no issues... although a few 90mph highway dip scrubs on the way to Cali from Vegas whenever I go.
awesome. thank you for the reply back! Do you reside in Vegas? will you be going to the EOS show this coming weekend?
Takumi_Fujiwara_GT86 is offline   Reply With Quote
Old 08-22-2013, 09:54 PM   #30
mikemcberty
Drives: 86
I was there. I did not show my car however. When the rain came- I left, it was crazy weather that day.
mikemcberty is offline   Reply With Quote
Old 09-10-2013, 08:22 PM   #31
grostoine
Drives: Subaru BRZ
Will it be possible to add a 20mm spacer to clear brembo brake in the front or there is no chance it can fit?
grostoine is offline   Reply With Quote
Old 09-10-2013, 08:25 PM   #32
vividracing
vividracing's Avatar
The look really nice. And the shots look well done. Congratulations!
vividracing is offline   Reply With Quote
Old 09-10-2013, 09:01 PM   #33
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
They will clear brembos with a 20mm spacer
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 09-10-2013, 09:29 PM   #34
grostoine
Drives: Subaru BRZ
But not the fender loll
Just made a ''test'' fit with the camber I can make and the wheel would be 15mm out of fender in front and 5 mm inside in the rear. No way i'm gonna take this setup
Old 05-23-2015, 12:54 AM   #35
shafted
shafted's Avatar
Drives: N/A
How would this work on TRD springs or I'm guessing it would rub?
shafted is offline   Reply With Quote
Wheel Directory: Work Meister S1R 18x10.0 +12 / 18x10.5 +17 larryw Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 01-16-2014 01:29 AM
Wheel Directory: Work Emotion CR Kai 18x7.5 +48 TexMex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-03-2014 08:44 PM
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 brunofrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-08-2013 01:26 AM
Wheel Directory: Work Emotion CR Kai 17x8.0 +42 sneaky Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-08-2013 04:05 PM
Wheel Directory: Work Emotion XC8 18x?.? +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-14-2012 02:42 AM
