Old 06-18-2013, 11:32 PM   #29
ft86me
ft86me's Avatar
Drives: 2013 FRS
i have to second the fitment issue of cf components. as awesome as my seibon carbon rear delete was, there were some modifications with files in order to make the holes wider since they were ...off..pretty off..haha but you can't tell because the bottom portion covers that part up well. in terms of hoods, i'm pretty damn sure our hood is just as light and i also second the vented deal. ok i'm done haha.
ft86me is offline   Reply With Quote
The Following User Says Thank You to ft86me For This Useful Post:
IBill4You (08-20-2015)
Old 06-20-2013, 04:27 AM   #30
Hawk77FT
Drives: GTS 86
Originally Posted by SubieNate View Post
I'd be curious to know what the additive is. My guess would be some sort of nano-scale ceramic filler that either completely absorbs or completely reflects UV so that it never gets to the epoxy. Something like what they put in the 3M Crystalline tint films.
Nathan
The better the quality of the clear coat the less likely to yellow. Most nowadays cars have a good UV stable clearcoat and paint.
Any resin whether epoxy PE or VE will yellow at some point in time if it is exposed to the elements. Now, there are few good ones with very good UV additives added, so that coupled with a really good clearcoat should protect the CF very well.
The clearcoat used by top car manufacturers is really, really up there! None of the things you and I have mentioned, is used by the CF aftermarket manufacturers mainly because of the costs. The market is quite competitive so they need to keep the costs down to compete with lower quality products in the market, therefore they need to cut certain corners. There are some good quality stuff out there but it costs quite a lot and sometimes not even worth the effort.
Hawk77FT is offline   Reply With Quote
Old 06-20-2013, 04:36 AM   #31
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Does anyone know if dry carbon also eventually turns yellow as well?
Carlitoz3 is offline   Reply With Quote
Old 06-20-2013, 12:15 PM   #32
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Dry carbon has resin in it just like "wet carbon", the only difference is which stage of the process that resin is added to the cloth and how well controlled the fiber:resin ratio is. Depending on how the wet layup is done, the "dry" part could have additional vacuum/autoclave curing steps but these days it's hugely common to use vacuum bagging even on wet layup parts.
So short answer, yes. If they use a resin system that can fail due to UV and a cheap clear, it will yellow.
Cheers
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Carlitoz3 (06-20-2013)
Old 06-26-2013, 03:39 PM   #33
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Originally Posted by DeeezNuuuts83 View Post
It depends on what you're doing. But yes, there are advantages... slightly quicker acceleration, slightly better fuel economy, etc. But all of the advantages (and disadvantages) will be relatively small overall. So your experience likely won't be changed drastically with these kinds of changes. But if you lose weight in the right area (like when some people lighten up the load up front with a smaller battery), then that will help in multiple ways.
Do you know how much it costs to re-clear carbon fiber? I was thinking about doing that to my Evo's carbon fiber trunk at some point.
Hey sorry for the late response but the paint shop I went too quoted me about 200$. I'll probably pay a little more than that due to me saying to them to add another coat but most of the cost is prep work and what not.
Sent from my HTC One
SMOKETREES is offline   Reply With Quote
Old 11-13-2013, 05:18 AM   #34
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Originally Posted by SMOKETREES View Post
i have the Seibon hood and love it. I wax it pretty much 3-4 times a week just to keep it fresh but will be taking it back to get re-cleared in about 8-9 months. It comes cleared already but i would like def a thicker coat and most clear coats now in days have UV Protection in them blended already.....
looks nice. i have the same hood. any flaws with the weave or finish? mine had a few waves
NYCsubaruBRZ is offline   Reply With Quote
Old 08-20-2015, 12:19 AM   #35
Xxdragn89xX
Drives: 2015 Subaru BRZ
Seibon Carbon Fiber Hood
Random question that I cant seem to find. Is that center piece functional or just for looks? I can see from other pics the side ones are obviously.
Xxdragn89xX is offline   Reply With Quote
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 05:42 PM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 11:51 AM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
VIS Carbon Fiber Tansey86 Cosmetic Modification (Interior/Exterior/Lighting) 8 04-12-2013 11:54 PM
APR Carbon Fiber Lip Kit now available! ShowstoppersUSA Exterior Parts - The Rest 22 04-09-2013 07:42 PM
