#29 |
Drives: 2012 Toyota 86
lighter springs in the front will promote more over steer. the reason between the two different spring sets is to try to retain the characteristics of the stock springs, in wich subaru is supposedly stiffer in the front.
#30 |
Drives: Scion FRS
Ive driven my car on the road course in completely stock form with both factory tires and 225/45/17 advan neovas. The car has a higher tendency to understeer than I had originally hoped for. If you have an frs, i feel the spring rate stagger is necessary and the swift springs definitely helps the car rotate just enough without being tail happy.
i ordered mine from modern automotive performance, great to deal with and fast shipping. |
| The Following 2 Users Say Thank You to SeeSharkySwim For This Useful Post: | OICU812 (06-17-2013), TouchMyHonda (06-10-2013) |
#31 |
Drives: FRS(sold), AP2, R35, FJC, ED9
i guess im still torn between the frs spring rates vs the brz. ive never driven a brz so im not sure how the the handle differs on brz compared to the frs. i guess ill have to wait till i do the hpde event to see if the stock frs feels tight or loose and go from there.
#32 |
Drives: 2013 Scion FR-S Raven
Are cutting bump stops necessary?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#33 |
Vtec Jesus
#34 |
Drives: DGM BRZ Limited 6MT
I cut mine - It was really simple to do. I was hesitant at first b/c I thought that if I wanted to go back to stock height, I would now have to buy new stops. However, after seeing my car with the swift springs and new wheels, I will never put the stock springs back on. The ride is amazing too!
#35 |
I'm adding Koni's next week, just want to make sure I measure correctly, therefore how much did you cut?
#36 |
Drives: 6MT
how much rear camber was added after the springs installed?
#37 |
Drives: WRB LMTD '13
#38 |
#39 |
Thank you!
The new Swift (BRZ) springs on my daughters FRS is everything we expected.
#40 |
Drives: 2013 Scion FR-S Asphalt 6-Spd
#41 |
is better than you
Drives: 2013 raven FRS
just wondering, will it be better to run the brz springs on the frs? or just run the frs made ones? I mainly care about handling with no understeer.
#42 | |
Drives: Some kind of Subaru
| Prototype Swift Springs for FR-S | mines13 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 137 | 09-17-2013 10:36 PM |
| Stance coilovers with Swift Springs | clickfiveZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 06-05-2013 07:20 PM |
| Swift springs rate ID | subaruferrucci | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 05:26 PM |
| Fortune auto with swift springs? | DarkCard | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 03-29-2013 04:15 PM |
| SWIFT lowering springs ? | rikdrt1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 10-31-2012 07:15 PM |
