Old 03-23-2012, 12:32 AM   #29
Verdugo
Senior Editor @ NWMotiv
Verdugo's Avatar
Drives: 2002 Do-Luck WRX, 2010 Audi A4
BRZ at Carter Subaru in Shoreline, WA -- First Impressions
Hi everyone,
I paid a visit to one of the traveling BRZs at Carter Subaru in Shoreline, WA. I took a bunch of photos and wrote up my own personal impressions Enjoy!
http://www.nwmotiv.com/cars/subaru-b...t-impressions/
Thanks,
Armin
Since the joint venture between Toyota and Subaru was announced last year, few cars have received as much hype, excitement, and naysayers as the upcoming Scion FR-S and Subaru BRZ. The spiritual successor to Toyota’s AE86 of Initial D anime and drifting fame, both the FR-S and BRZ have swooned automotive journalists around the world with its handling prowess, low weight and center of gravity, and above all, low projected MSRP. We’ve definitely had our eyes on both of these models here at NWMotiv, even coming up with a concept composite of what our future BRZ might look like. However, despite all the peer pressure, Facebook polls, and constant research, nothing could possibly mean more than actually seeing, feeling, and ultimately driving the car in person. While we weren’t able to get any driving impressions this time around, we were at least given the opportunity to closely examine a new Subaru BRZ on the showroom floor of Carter Subaru in Shoreline, WA as this dealer demo vehicle continues its tour across the country.
Story and Photos by Armin H. Ausejo
Carter Subaru cleared out its main area just for the BRZ, putting the Lightning Red coupe front and center at their dealership. You can easily see the BRZ from the street and seeing it up close and personal instantly leaves an impression. The car’s body lines are truly sexy: from the fender bulges, to the shape of the roof, to the mean tough-guy stare of the headlamps, the BRZ just looks like you’re ready to kick it into ludicrous speed just sitting there. It’s definitely a small car, being about 3 inches shorter than the first generation 350Z and 2 inches shorter than the FC RX-7. Once you open the hood, you see what all of the low center of gravity hubbub is all about. The motor is completely and literally below the hips, and you pretty much have to give a very honorable bow just to touch the motor (more on the motor and engine bay later). The HID and LED headlamps truly differentiate it from its Scion brethren, although the clear reflectors in front were easily mistaken for fog lights. The wheels are – well, they’re very stock-looking wheels, and the 5×100 bolt pattern is a bit disappointing for the sake of aftermarket wheel options, much less possible future wheel bearing issues. Thankfully, there is quite a bit of space in the wheel wells and reports from the FR-S camp have said that fitting 10-inch wide wheels on the rear is as easy as destroying your 2002 WRX’s transmission with an AWD burnout. The stock tires are laughable Toyota Prius tires, which means you’ll be able to get your dori-dori on with little effort, but we’re already dreading the future forum posts complaining about the tires and 12 mph spool on wet roads.
Opening the door to the interior, our suspicions were indeed correct about the backseat. Both Subaru and Scion list their respective versions as a “2+2,” but the only 2 things you might be able to fit in the back seat are half of your 17-inch track/auto-x wheels and tires. Unless you’re a very vertically challenged individual, there’s absolutely no way you can even fit a toddler in the back seat, much less a child or small adult. One would believe they left in a couple back seats in for insurance purposes, but they truly are useless, so you might as well just keep them folded down the whole time. On the other hand, the front seats are quite comfortable and while they don’t have a name like Recaro or Sparco stitched onto them, they could easily pass as one of their models. If anything, the design of the front seats is similar to a Bride seat. The interior plastics and other materials have a nice feel to them, very similar to that of Subaru’s 2008+ STI. Even the gauges glow red like the STI, and the interior stitching also has an STI look to them. Visibility out front and to the sides is excellent, almost bubble canopy-like, however the blind spots offer a pretty thick C-pillar that doesn’t give a very good rearward view for quick lane changes.
Stepping out once again, we next take a look at where Subaru and Toyota decided to save weight. One of the main draws of this new model is the fact that the curb weight is going to be in the 2700-2800 lbs range, depending on your options and choice of transmission. Subaru lists its most basic version of the BRZ with a manual transmission weighing in at a mere 2762 lbs and upon further examination, you can really tell where they decided to skimp or go cheap to save weight. One glaring example was the fender liners, which were simply exposed rubber pieces in the engine bay. You could press up on the fender liner from the wheel well and the exact same piece would be popping up in the engine bay. On the contrary, the hood is extremely light, easily lighter than an STI’s aluminum hood, thus Subaru decided to spend a little extra for weight savings in this case. Overall, the car didn’t feel cheap in any way, but making sacrifices such as the fender liner does give off an air of cutting corners, even if that could potentially lead to a better driving experience.
Ultimately, driving experience is all that really matters for this car in the end. With a 200 horsepower, naturally aspirated motor under the hood, many people will easily scoff at the idea that this car will be any better than a Hyundai Genesis Coupe or even an RSX Type-S. “Needs more power” was the phrase heard the most when standing around the car with fellow enthusiasts and unfortunately this car was not available for any test drives. We were at least able to hear the motor, which definitely had a nice boxer rumble to it. We have no doubt that an aftermarket exhaust will make this motor really roar. Nevertheless, there is definitely some room in the engine bay for additions. The motor is quite pushed back toward the firewall, so any aftermarket turbo system would most likely need to be mounted in front of the motor, much like the current generation Subaru Legacy GT and opposite of the WRX and STI. However, rumor has it that this motor uses the same motor mounts as the WRX and STI, which of course begs the question of why not throw in an STI motor from beginning if that’s the case? As completely valid as that question might be, one has to remember while Subaru did the vast majority of the design and manufacturing of this vehicle, the original idea and concept is Toyota’s, and as the spiritual success to the AE86, keeping it a lightweight, naturally aspirated car just made sense. Nevertheless, perhaps Subaru’s H6 3.6L motor from their Legacy 3.6R might prove to be an interesting swap in the future.
Full article continued at http://www.nwmotiv.com/cars/subaru-b...t-impressions/
Armin H. Ausejo
Senior Editor, NWMotiv.com
Photographer, ArminAusejo.com
Verdugo is offline   Reply With Quote
Old 04-03-2012, 01:06 AM   #30
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
[u2b]kOaxzZqF4A4[/u2b]
poormans_LFA is offline   Reply With Quote
Old 04-09-2012, 01:47 PM   #31
poormans_LFA
FT86Club.com O.G.
[u2b]IzKqWrIGJ3A[/u2b]
Old 04-09-2012, 09:34 PM   #32
sysfailur
scoob addict
sysfailur's Avatar
Drives: 08 AW STi, 13 LR BRZ
Send a message via AIM to sysfailur
^omg so glad I picked red.
sysfailur is offline   Reply With Quote
Old 04-16-2012, 02:29 PM   #33
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
another pic of the LR BRZ Limited that's been going around the tristate area. It was at my local dealer today. (be warned, its instagramed out)
dori. is offline   Reply With Quote
Old 04-16-2012, 02:56 PM   #34
Add me to that list! Looks even better in person.
Old 04-17-2012, 02:34 PM   #35
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
When did you see LR in person?! I have only seen Silver and DGM
I cannot wait to pick up my ride.
But, but, but... It's only 200 hp?!
Lighting Red is offline   Reply With Quote
Old 04-17-2012, 02:54 PM   #36
I'm one of the Scion 1st86, so technically I've seen Firestorm when we were in SoCal, but its the same color code, different name.
Old 05-21-2012, 03:23 PM   #37
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
[ame="http://www.youtube.com/watch?v=zvssVyJ8R5o"][Supersports News24]やっと!! やっとBRZじゃなく、86を公道で撮影致 しました!!(^^) - YouTube[/ame]
Red in the wild
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-21-2012, 03:40 PM   #38
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Not normally huge on red, and initially steered well clear of red on the BRZ, but now I gotta say a red BRZ with some flat black wheels would look hawt.
MmmHamSandwich is offline   Reply With Quote
Old 05-21-2012, 04:55 PM   #39
sticky
sticky's Avatar
Drives: 86 GTS 6AT
Originally Posted by ESBjiujitsu View Post
Red in the wild
That's actually a 86 - but thanks for the vid
sticky is offline   Reply With Quote
Old 05-21-2012, 05:49 PM   #40
MmmHamSandwich
Drives: '13 FR-S
That's actually an 86, but thanks for the pic. Just playing around. That's the stuff right there.
With those black BRZ headlights it would look even hotter.
Soo many colors on this car make me second guess my choice of silver.
Old 06-04-2012, 08:25 PM   #41
JAG
Drives: 2013 Subaru BRZ Limited (Red 6MT)
my lightning red BRZ
JAG is offline   Reply With Quote
Old 06-04-2012, 08:38 PM   #42
Lighting Red
God DAMN what a sweet car!
STERLING SILVER BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 526 09-07-2026 02:25 PM
FR-S and BRZ Exhaust Compilation Thread Spd229 Engine, Exhaust, Transmission 666 03-11-2026 04:10 PM
DARK GRAY BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 766 10-18-2021 08:40 PM
Lightning Red BRZ & Brilliant Red A4 Photoshoot BRZ4me BRZ Photos, Videos, Wallpapers, Gallery Forum 9 06-02-2012 04:42 PM
BRZ4me's Lightning Red Mini-Review BRZ4me BRZ First-Gen (2012+) — General Topics 41 05-29-2012 12:08 PM
