Old 06-21-2013, 01:44 PM   #29
2beFrank
2beFrank's Avatar
Drives: Firestorm 6MT
I bought the kit too, got it installed about 3 days ago and it has been working fine. I replaced the original bulb they sent me with a yellow bulb. There's an on and off switch, mine is currently just hanging by the pedals. When I get the once, i'll install it next to the truck button.
2beFrank is offline   Reply With Quote
Old 06-22-2013, 02:46 AM   #30
Fast_Freddy
Drives: Passat
Originally Posted by Sarlacc View Post
That's a bad habit IMO. (And it's illegal in many parts of the world.)
Two reasons for this:
1. Your fog lights will annoy and "blind" oncoming traffic.
2. The effective range of what you can see is limited to the brightest part of the road. You can see further ahead with just your low beam than you can with your fog lights on.
The general rule of thumb is you should only use fog lights when visibility is under 100m/330ft. And even then it's a judgement call, in heavy snow it's often better to leave them off.
So by all means, buy cheap aftermarket fog lights as bling on the car, but please don't use them unless it's absolutely necessary.
Aren't you confusing fog lights with driving lights? I'm not sure I agree that 55w fog lights aimed down and out will "annoy and blind oncoming traffic". When I see fog lights coming toward me I have yet to be annoyed or blinded when they are aimed properly.
BTW, if these are anything like the Ebay Chinese knock-offs I had for my Scion XB2, they work okay but the bulbs are garbage, the lenses crack very easily, they can't be aimed and require a $50 switch from Toyota which brings the total cost to within $50 of the oem fog lights with good bulbs and lenses. I went through 2 sets in 4 years.
Fast_Freddy is offline   Reply With Quote
Old 06-22-2013, 02:56 AM   #31
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Looks like the kit from Subaru down to the switch that I installed in a BRZ.. Bolted right in, drilled a small hole and everything worked and looked great.. Except the switch.. If anyone wants a factory look the switch kills it, but his did tap into the stak harness for the fog lights and turned the fog light dash light on
Gixxersixxerman is offline   Reply With Quote
Old 06-22-2013, 03:04 AM   #32
killercl0wnfish
Drives: fr-s
bulbs work fine and are nice and bright i orderd a 35w 3000k kit for them ... lenses seems thick and when i tap on them dont sound like its thin or weak.. i can adjust mine with a turn of a screw driver from the back... u dont need any kind of oem switch i just wired mine to the factory fog light wire that is already ran to the turn signals then found the white wire under the steering wheel and ran switch from wire to switch then switch to ground ... works perfect and even shows the fog indacater on the dash comes on with head lights only and use switch when u wanna turn it off or keep it off
killercl0wnfish is offline   Reply With Quote
Old 06-22-2013, 03:07 AM   #33
killercl0wnfish
Drives: fr-s
i have switch jsut sitting in the little holder under the hvac system right now i orderd a factory fog switch from my buddys shop for a more oem look .. idk what it came off of ill post pics when they come in
Old 06-22-2013, 03:27 AM   #34
Gixxersixxerman
Please tell me you mean a 35w 3000k holagen bulbs??? Not a hid kit.. It's bad enough the guys that throw HID in stock projectors without a retrofit, much less a hid in a open housing
Old 06-22-2013, 12:57 PM   #35
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
No.
Old 06-22-2013, 01:12 PM   #36
86driver
86driver's Avatar
Drives: 2013 Scion FR-S, WHITEOUT MT
Can you get some pictures of the wiring that you did. I'd love to do the setup that you did, but I'd like to know exactly which wires you connected to. If that's possible for you that would be great!
Sent from my SCH-I605 using Tapatalk 2
86driver is offline   Reply With Quote
Old 06-22-2013, 02:59 PM   #37
Arrakis
Arrakis's Avatar
Drives: 2013 Scion FRS
Hi killercl0wnfish,
Congrats, You new fog-lights look great!
Could you explain how you tapped the wires of your aftermarket fog-lights to the factory fog-lights wiring? I thought our FRS does not come with factory fog-lights!
Can you turn your new fog-lights on & off independently from the low beam and the high beam? Thanks!
Arrakis is offline   Reply With Quote
Old 06-28-2013, 01:44 AM   #38
TRD_07
TRD_07's Avatar
Wow, the parts to the kit look great. Now, I'll be ordering mine but I want to special order stalk with both the front/rear fog switch from Nijel. Thanks.
TRD_07 is offline   Reply With Quote
Old 07-04-2013, 06:51 AM   #39
killercl0wnfish
Drives: fr-s
Originally Posted by Arrakis View Post
Hi killercl0wnfish,
sorry I have not done this yet but computer fried ill do a Wright up later if I find a computer but there is a diy on this forum
Old 08-24-2013, 01:38 PM   #40
TheGuyWithTheFireStorm
Drives: FireStorm MT FRS
Still interested in getting a pair. How's everyone else doing with this kit?
TheGuyWithTheFireStorm is offline   Reply With Quote
Old 08-24-2013, 01:42 PM   #41
t00n3wb
t00n3wb's Avatar
Drives: 2013 Hot Lava Scion FR-S
Can you post a pic of the button near the trunk switch and light dimmer?
t00n3wb is offline   Reply With Quote
Old 08-26-2013, 02:43 AM   #42
KI_ZN6
KI_ZN6's Avatar
We have HID kits and LED foglights (H11) available for the FR-S. Plug and play, no modifications required. The HID kits will throw out more light while the LED foglights will be a subtle upgrade and will match with the HID headlights.
Send us a private message if you folks need any LED and HID upgrades for the foglights
KI_ZN6 is offline   Reply With Quote
TRD LIP KIT ON EBAY!!! chopstickz Cosmetic Modification (Interior/Exterior/Lighting) 17 02-03-2014 04:04 PM
Ebay Fog Light Kit... 5AD86D Cosmetic Modification (Interior/Exterior/Lighting) 12 06-19-2013 02:23 AM
found my car on eBay 20valvewynn83 Engine, Exhaust, Transmission 11 11-20-2012 12:00 AM
BRZ on eBay nzer AUSTRALIA 7 10-05-2012 03:24 AM
brz limited for 28k on ebay adprokid BRZ First-Gen (2012+) — General Topics 0 08-13-2012 10:51 PM
