Old 07-18-2013, 07:20 PM   #29
Faceless
Drives: 2013 Raven Fr-s
Originally Posted by wparsons View Post
On an 8" wheel without measuring, I would guess that at stock height and stock camber a +40 would be about dead flush up front. +35 will poke a bit and +45 isn't quite flush. +35 with ~2* of camber will probably look perfect though.
On mine the rears are a few mm sunk in and the fronts are just about perfect riding stock height. For a 17x8 square setup I feel that the +35 offset is the best fit.
Faceless is offline   Reply With Quote
Old 07-18-2013, 09:48 PM   #30
canon_spec
Drives: FT86 GTS
I've only recently just fitted the RPF1s in 17x8 +35 and loving them so far. Still running the stock rubber on them and tbh the stretch isn't too bad. Looks good honestly. Will be going to 225 once the rubber needs replacing but until then enjoying what I have.
Here is pic to show you how they look.
canon_spec is offline   Reply With Quote
The Following 2 Users Say Thank You to canon_spec For This Useful Post:
BabaYaga (06-12-2015), normancw (07-24-2013)
Old 08-02-2013, 02:29 PM   #31
Dezoris
Dezoris's Avatar
Huncentric Rings on RPF1
Are you guys having to run hub centric rings on RPF1, 17x8"?
If so, which ones to do you use that will hold up for track use?
Old 08-02-2013, 03:44 PM   #32
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I've got the plastic ones that the Tire Rack supplied. They have held up fine to track use.
celica73 is offline   Reply With Quote
Old 08-02-2013, 03:49 PM   #33
We don't use any
Old 08-02-2013, 06:30 PM   #34
KONVERTER
KONVERTER's Avatar
you should be.
and you must.
KONVERTER is offline   Reply With Quote
Old 08-02-2013, 06:59 PM   #35
wparsons
wparsons's Avatar
This argument again
I'm running no rings in mine either, with no issues at all. As long as you're running taper seat lugs (which are the proper lugs for the wheels) and tightening them down correctly you absolutely do not need the rings.
flickr
Old 08-02-2013, 07:04 PM   #36
Faceless
I'm running mine without rings cause I'm too lazy to jack up my car to pull the wheels off. I've had the rings for 2 months now haha.
Old 08-02-2013, 07:14 PM   #37
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
We're running Aluminum Rings on ours:
Touge Factory is offline   Reply With Quote
The Following User Says Thank You to Touge Factory For This Useful Post:
Dezoris (08-05-2013)
Old 08-02-2013, 07:46 PM   #38
KONVERTER
KONVERTER's Avatar
Right... You don't have an issue until a wheel flies off...
I have seen it, and have dealt with the lawsuit...
Old 08-02-2013, 07:50 PM   #39
kster1
kster1's Avatar
What size rings are needed for RPF1s? Is it 73mm x 56mm?
kster1 is offline   Reply With Quote
Old 08-02-2013, 07:52 PM   #40
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I'm running aluminum hubcentric rings on my wheels but I don't have RPF1s... seems to be giving the wheels a better/more-snug fit overall, but I can't say they're really necessary. The tapered lug nuts should be plenty to hold the wheels in place, but it can't hurt to have extra assurance the hub is holding things in place as well. My 2 cents at least.
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
Freerider (02-03-2018)
Old 08-02-2013, 08:41 PM   #41
UncleFester
[ame="http://www.amazon.com/gp/product/B002809U9C/ref=wms_ohs_product?ie=UTF8&psc=1"]Amazon.com: Gorilla Automotive 73-5615 Wheel Hub Centric Rings (73mm OD x 56.15mm ID) - Pack of 4: Automotive[/ame]
UncleFester is offline   Reply With Quote
The Following 2 Users Say Thank You to UncleFester For This Useful Post:
kster1 (08-02-2013), whataboutbob (08-03-2013)
Old 08-02-2013, 08:50 PM   #42
Dezoris
Dezoris's Avatar
Well here is the thing plastic does nothing for holding the wheel on just helps center. Far from load bearing and high heat I would assume would melt them. You guys with aluminum rings you dont get any siezing or cracking of the rings? Have you actually tracked them under high brake temps?
@Mike csg
You run sprint and rpf1s with no rings and your own lugs no issues with wobble etc?
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei RSM9 17x8.0 +48 AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-17-2014 06:50 AM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 04:26 PM
