#29 |
Drives: Red SCion FRS
So if my warranty is voided since I'm going to have my SC installed. Do they still fix my car if it is a recall ?
#30 |
Drives: Honda Fit
#31 |
Drives: Whiteout FRS
Toyota seems to be a little better with the after sales and the warranty stuff. I was a little torn between the frs and brz... but I think it's going to be frs for sure. I wouldn't be surprised to see some asbestos seals come out for this even if they're after market. Can't use it in brake pads and such, but this would be a perfectly viable application.
2014 Whiteout FRS
#32 | |
Drives: 92 Integra
#33 |
Track Junkie
Drives: Faster than the Stig!
Could some one please add a poll to this thread?
1- My car has had an injector seal leak but no damage was done. Dealer Validated Warranty. 2- My car has had an injector seal leak but no damage was done. Dealer Denied Warranty. 3- My car has had an injector seal leak that caused engine damage. Dealer Denied Warranty. 4- My car has had an injector seal leak that caused engine damage. Dealer Validated Warranty.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#34 | |
Drives: A lot of supercars.
#35 |
For those who haven't seen this.
#36 |
Drives: Honda Fit
@Carwhisperer:
1) Thanks for Post #39. 2) Combustion/misfires above 5200 rpm caused the nylon collars to fail? Have I understood that correctly? |
#37 |
Drives: SWP BRZ
#38 |
Drives: 2013 FR-S Hot Lava
Any news on this TSB coming to North America?
Live to drive another day
#39 |
Drives: 2013 Subaru BRZ
Not misfires, detonation. Also called spark knock, sounds like pinging from the engine. Most modern cars will have some light detonation from time to time, and it's considered normal. Any time you have detonation the cylinder pressures are higher than during normal combustion. Apparently this is blowing out the nylon seal.
| The Following 2 Users Say Thank You to andrew20195 For This Useful Post: | Carwhisperer (06-03-2013), Marrk (06-03-2013) |
#40 |
Drives: FRS
#41 |
That "on-off-on" cause is in direct opposition with my driving habits. I shift slowly to preserve the synchros in the tranny, as well as the engine mounts; the RPMs on this car drop rather slowly as a byproduct of tuning for emissions purposes and a heavi-ish flywheel.
I do, however, do a "on-off-on" to induce rotation mid-turn, without shifting. In other words, I'll lift on the throttle and get back on it to upset the car's balance. |
#42 |
Drives: STi
Has anyone successfully captured the knocking sound?
Sent from my GT-N7105 using Tapatalk 2 |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Direct Injector's Leaking | Carwhisperer | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-11-2013 10:31 AM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 05:43 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 06:03 PM |
