#29 |
Drives: '23 BRZ
Looks WAY the hell better without. Also, with spacers scrub radius is affected/increased, which gives a lot more unwanted and unnecessary steering input from road imperfections. Also, spacers increase leverage of the wheels on the suspension, decreasing effective stiffness (wheel rate). Only positive is *slightly* increased track width, but only 1%, the negative impacts on scrub radius and wheel rate are a lot bigger.
| The Following User Says Thank You to ZDan For This Useful Post: | freerunner (12-12-2024) |
#30 |
Drives: FR-S [Hot Lava]
I'm getting my Nvidia Cat Back put on this week, while it's on the lift I'm going to check to see if there is any rubbing. So far none though... it's just a lot louder from 2 inches more of rubber on the ground.
#31 |
SLO NO MO
Looks good man - where does it almost rub, up front at full steering lock against the wheel well or the OEM springs?
#32 |
The tire is maybe 1-2 millimeters from the strut spring hat in front. No rubbing anywhere though even when wheels are locked left and right.
#33 |
Just drive it
Drives: 13' FR-S
Dam those beefy tires. Love it.
I guess ET35 will stick out like that.. (with spacer) |
#34 |
Drives: 2013 SWP BRZ
love the wheels and license plate
#35 |
Drives: 2010 BMW 335i
Lookin nice man!!
We've sold several sets of the same wheel and it looks better every time! Truly one of the best setups for the 86 platform Keep her clean! Let me know when you're ready to drop her ![]() -AJ ECS Motorsports |
#36 |
Pegasus White
Drives: 86
if you are adding 10mm spacers how come you didn't go for the 17x9 +35 RPF1s?
Driving: Pegasus White Manual GTS 86.
#37 |
Because I have this problem where if I have money for car parts it literally burns a hole in my pocket. I stay up nights thinking about how to spend it.
+35s were not available in black when I had the money in my hands. ![]() As it turns out, I don't like the look with the spacers either so +35 would not look good on stock suspension. So now I have an option of just doing some 3mm spacers in the front if rubbing becomes an issue. |
#38 |
form follows function
Drives: RIP '13 BRZ
Looks great. Answers my question of +35 or +45. Just be careful when you lower it. I ate up my inner fender liners (on the inside) on 17x8+45s when I dropped to the minimum recommended ride height for KW V3s. Replacing the liners and raising ride height when I go to 17x9s. Enjoy the extra grip! ZIIs are monsters compared to the stock tires.
#39 |
I'm shocked you have clearance with 9" +45 wheels, it looks like I have less than 13mm of space between my wheels/tires and the spring seat with 225/45's on 17x8's. I haven't actually measured it, but it felt like 10mm or less.
Glad it fits for you, but you'll need coilovers to run useful camber
#40 |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
Need to switch the rear wheels. Tread in those pictures is backwards?
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
| The Following User Says Thank You to deucethemoose For This Useful Post: | Lee358 (07-09-2013) |
#41 |
#42 |
Alignment? Front looks like you have positive camber... could just be the camera angle.
~Namaste~ |
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 07:31 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 04:50 PM |
| Wheel Directory: Enkei Kojin 17x9.0 +45 | Clipdat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-02-2016 05:18 PM |
