#29 |
Drives: 2013 DZE/01 (sold for MX5 ND1)
That's a lot of wheelbase just to have big speakers.
#30 | |
2 yrs and counting...
Drives: Audi & Toyota
The car is targeted to be around the $20000, and yes it could be relatively inexpensive, but that doesn’t tell us the TRUE cost of the car let alone the engine cost. We don’t even have the exact pricing for the car yet. So let me ask you, do you know the TRUE cost of the EJ20 engine if it was capable of producing 160 lb-ft vs. the TRUE cost of producing 150 lb-ft? I am really curious to know your answer. Could you also help me find the TRUE cost of 2GR-FSE and 2GR-FE? And like I said before, the FE is used on Camry's to RAV4's so other than DI, what would make this engine “much more expensive”? It's unlikely to be that high in a cheap NA 2.0L. I see. So only a marginal increase of 5 lb-ft or 2.5 lb-ft/L from the NA concept based on your prediction of 150 lb-ft is “more realistic”. I just find it funny that not even your own example of the SI shows a 2.5 lb-ft/L increase. I'll be surprised if the NA FT86 has anything below 145 ftlbs, but at least it's a remote possibility How is 141-145 lb-ft even a remote possibility. That’s a 0-5 lb-ft increase with DI with respect to the base and NA concept engine. If you are going to say it’s a “cheap” engine then please show me how much more it would cost to increase torque by 0-5 lb-ft based on your 150 lb-ft prediction. It even sounds funny saying torque would not increase at all with DI since you said it’s conceivable that FT86 could have only 141 ftlbs. Not to mention if Toyota does work on the engine makes your statement even more unlikely. Which statement is fallacious? Starting from your first post and another affirmation here in your 2nd reply: Only said that 70-75 ftlbs/L was more realistic for NA (especially given Toyota's commitment to cost cutting). = 140-150 lb-ft/L. So how is 140 lb-ft even realistic for this engine when it gets 141 lb-ft in the base engine without even having DI? And your other ranges don’t even sound “more realistic” when you don’t even know if Toyota is cost cutting on the engine to a point where they won't go above 150. Also, how about you answer all of my questions from my previous reply instead of skipping it? It also brings me to another point. Why does toyota have to use boxer engines and not use their own engines? Wouldn't using their own engines be more cost effective? Why would I need to put a wager in for the 160 lb-ft range when I said it's possible for this engine? You however should though put in some money, since you think it’s too “costly” for Toyota to do it and it doesn’t fall into your 140-150 lb-ft/L “more realistic” range. But I’ll put in a wager that it’s not 150 lb-ft if you put in the same amount saying that it will be 150 lb-ft. Last edited by 86Fan; 10-18-2009 at 03:51 AM. |
#31 | ||||||
I already answered this. Quote:
You wrote that 150 ftlbs and 170 ftlbs are equally realistic, so it's time to put up or shut up. It's only $10 and it's for charity anyway, so unless you're no longer confident in your prediction, why not? :pIf you're not willing to do that, then I'm going back to my previous suggestion: let's agree to disagree and move on. We've both made our arguments and predictions, and this discussion has become repetitive and circular. |
#32 |
BRZerhood Lurker #13
Drives: 15 DGM BRZ Premium
I say base model 2.0l 160 hp
and GT-S model 2.0l 190hp 165ft/lb tq I also think since you can get a TRD supercharger on a Fj cruiser and a Scion Tc that the possibilities of factory boost for the FT-86 are probably good. It may not happen the first year though. My guess FI model probably will be around 265hp like the wrx. Last edited by zigzagz94; 10-18-2009 at 09:12 AM. |
#33 |
Drives: yaris
i don't think the supercharged vs (if it comes out) will ever produce that much
maybe 200-210; but even that seems unlikely |
#34 | |
Also let me refresh your memory, Only said that 70-75 ftlbs/L was more realistic for NA (especially given Toyota's commitment to cost cutting). = 140-150 lb-ft/L. So how is 140 lb-ft even realistic for this engine when it gets 141 lb-ft in the base engine without even having DI? And your other ranges don’t even sound “more realistic” when you don’t even know if Toyota is cost cutting on the engine to a point where they won't go above 150. I already answered this. No not really, read the first paragraph. Also I'll remind you again, I'll be surprised if the NA FT86 has anything below 145 ftlbs, but at least it's a remote possibility How is 141-145 lb-ft even a remote possibility. That’s a 0-5 lb-ft increase with DI with respect to the base and NA concept engine. If you are going to say it’s a “cheap” engine then please show me how much more it would cost to increase torque by 0-5 lb-ft based on your 150 lb-ft prediction. It even sounds funny saying torque would not increase at all with DI since you said it’s conceivable that FT86 could have only 141 ftlbs. Not to mention if Toyota does work on the engine makes your statement even more unlikely. Not sure what I mean? Your Civic SI example shows an increase of 5 lb-ft/L not 2.5 lb-ft/L from the result of DI. Thought you would be able to do the simple math. We both said 160 is possible and it's the average of our predictions. Why would you even ask me to put in a wager for 160 then? I won't have to when I say it's possible. You however should, you clearly said this is a cheap motor and you also said, NA piston engines that get above 70-75 ftlbs/L are generally expensive. So tell me how can this motor able to get to 160 lb-ft and be cheap and generally expensive at the same time? I made it quite clear that my prediction could be high. You keep regurgitating the same thing over and over again but you have yet to show me that your 150 lb-ft is more realistic based on cost of the engine. Your prediction is based on your 140-150 lb-ft statement since the torque falls right at 150 lb-ft. Pretty simple to see. Time to put up money when you said your prediction is more realistic. I'm confident that you won't be right and like I said mine could be high. Please I'm so willing to bet you won't be right.
#35 |
Drives: yaris
hp/ft-lbf, these are NA engines at 2.0L
toyota 3ZR-FAE: 158/144 (i4 config) subaru 2.0r (i can't find engine name): 158/137 (h4 config) so between the two of them I feel confident they can attain 165-170hp/145-150ft-lb (155 is a possibility though I don't see 160 happening anytime soon) however, the celica gt-s (codeveloped engine with yamaha) i think produced 180hp/133ft-lbf; so we may see even higher horsepower rating than 170, possibly closer to 185-190 |
#36 |
Drives: yaris
if it did let's say produce 190hp, weighing in at 2600; it'd compete in acceleration against a subie of 225hp and 3200 lbs (something I see making quite a lot of sense); and later a possible turbo version for toyota competing with the higher end wrx model (though I doub't toyota will ever compete with STI model); assuming subaru's won't lose any weight
#37 | |
#38 |
Drives: yaris
as a naturally aspirating version, that was the number that kept popping up as I searched around. surprised me
#39 | |
Drives: RX8
#40 |
Team ScioNRG President
Drives: 2017 WRB BRZ
Im gonna guess from pictures of the tach (7.5k redline), that the motor will put out probably 140ft/lbs. of torque and 180bhp. (base motor)
reasons: 1. This is not a drag car, it is supposed to be designed for "drifting" and road racing. 2. Obviously, they can not sink too much money into upgrading the motor if they are going to keep the rest of the car up to par with the rest of the market (interior, comfort, exterior, paint quality, etc.) while still marketing to a target audience. Sure, they could have a wonderful interior and an LSD, and this is and that, but then you are driving the costs up and pushing the car out of its projected price point. I don't think they will too much to the base engine. As long as they keep the weight of the car down, it will perform. |
#41 |
Site Moderator
Drives: ichi 86 Project
Just one Q. Why ppl are assuming those low TQs? Subie's EJ engine never had a low TQ. They always stay right next to HPs. My RS has 160hp/166tq, even new 2.5i have 170hp/170tq. I've never seen stock EJ engine that has low TQ. Even EJ20 engine, some has 5~10tq more than hp.
Also low rev. STI always rev close to or over 8,000RPM. Only US STI rev to 6,500RPM. So I don't see why FT86 wouldn't rev up to 8,000RPM. Are you talking bout EJ20R? If that's the one it's from '93~'99 Legacy pushing 275 bhp. |
#42 |
I have no problem with the idea of the engine revving high, possibly close to 8k.
However, an N/A engine which such a high rev limit is going to want to make power towards redline (and since this car is not being engineered to be a drag car, it will have the top end power) or else the redline would not be what it is. The car does not need to make gobs of torque at 2000rpm in order to be fast. If the motor did make great torque towards the bottom end, it will simply run out of steam up top. - This is where the Scion tC FAILED. Plenty of low end power, and fun in 1st and 2nd gears, but it completely falls on its face in 3rd gear. Hopefully, the NA version will have a high compression ration (at least 11:1), and make power at the high end. That way, we will get the benefit of good fuel economy when cruising around town, and power when we need it (around the track at high RPMs) |
| NEW Subaru 086A BRZ STi impression and info | Hachiroku | BRZ First-Gen (2012+) — General Topics | 65 | 08-23-2011 01:38 PM |
