Old 03-25-2013, 09:09 PM   #29
RyleyMA61
Drives: '84 MA61 Supra, '88 Mercedes 500SEC
Originally Posted by Huehuecoyotl View Post
if there was a way to have it start up with VSC sport that would be great
- 1988 Mercedes-Benz 500SEC - 200kW Euro Luxury
- 1984 7MA61 Supra - 300kW/600Nm
- 1983 JZA61 Supra - 2JZ screamer - Sold :'(
- 2012 ZN6 86 GTS - Hopefully coming in 2012...
RyleyMA61 is offline   Reply With Quote
Old 04-02-2013, 01:19 AM   #30
polarstorm
polarstorm's Avatar
Drives: Scion FR-S
Originally Posted by radroach View Post
Was doing a Tail of the Dragon run in another driver's FR-S, TC On and Sport Off, and we slid off the road at 40mph because of my added weight. The TC totally seemed to hiccup that time, letting us outright lose our grip and not regain any control.
I definitely prefer sport mode ON because at least you have a better feeling for the limits of the car. But I'll leave TC in the partially on/off (sport) because it allows you to more smoothly regain from a skid.
I was going to ask about these modes, then I found this video, found it useful to help me understand what I'm up against.. I agree with a prev comment by the experience track driver, that it's a matter of when and not if.. especially here in snow country.
[ame="http://youtu.be/j8qggahGNH0"]http://youtu.be/j8qggahGNH0[/ame]
polarstorm is offline   Reply With Quote
Old 04-02-2013, 03:15 AM   #31
MadFRS
MadFRS's Avatar
Drives: UltraMarine FR-S
That's a great video...good find.
MadFRS is offline   Reply With Quote
Old 04-02-2013, 09:56 AM   #32
radroach
Drives: car
One of the bigger challenges to face in the car is weight distribution. If you put someone in the back the car will be more tail happy. But if you put someone in the side the car will be more slide happy.
Old 04-02-2013, 10:08 AM   #33
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
In general, I keep VSC/TC in Sport mode. This is for general driving around town. I like kicking the back out a little bit whenever I can. I've yet to turn it completely off - I'll save that for if/when I'm in a safe location like a track.
I will leave the system in normal mode in cases of inclement weather - if the ground is wet/snowy/etc.
To note, the system is very intrusive in normal mode on the stock rubber. Any sort of quick turn will get it to kick on and cut the power. Since I've switched to stickier summer tires it's much less annoying, particularly in Sport mode.
MVJ1975 is offline   Reply With Quote
Old 04-02-2013, 10:47 AM   #34
SupraRon
SupraRon's Avatar
Drives: Raven 6AT
I do about 90% of my driving with all nannies on. I only used the snow mode a couple times when commuting in a snowfall. It slows your launch so that you dont start off spinning. I've only fully disabled VSC a couple times to fool around. I plan to use sport mode and VSC fully disabled on the track to get a better understanding of the vehicle's dynamics.
The fun has returned!!
Morimoto Mini H1 HID conversion
SupraRon is offline   Reply With Quote
Old 04-04-2013, 12:24 AM   #35
FR Sports
FR Sports's Avatar
Drives: Ultramarine FRS 6MT
I haven't tinkered much with the TC/VSA system yet but the other day I was making a left turn at an intersection at moderate speed. A mid corner bump sent my rear end sliding even with the system in normal mode. I was surprised that the TC/VSA system didn't kick in sooner. I slid almost a second before I felt the system kick in. It was fun but I thought the system is more sensitive when it's in the normal mode?
FR Sports is offline   Reply With Quote
Old 04-04-2013, 10:07 AM   #36
boead
boead's Avatar
Would the TC/VSA system wear the breaks out faster overall?
boead is offline   Reply With Quote
Old 04-04-2013, 10:20 AM   #37
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
From what I've experienced the nannies don't apply the brakes. The system just cuts power.
Old 04-04-2013, 10:25 AM   #38
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
i might be wrong but the stability control uses abs while traction control cuts power
if you think about it, you can slide without throttle so cutting power would be useless in those situations
dori. is offline   Reply With Quote
Old 04-04-2013, 10:26 AM   #39
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Makes sense. I suspect I've never had anything other than the traction control kick in.
Old 04-04-2013, 10:27 AM   #40
dori.
Señor Member
dori.'s Avatar
then I guess you just never got sideways enough
Old 04-04-2013, 10:37 AM   #41
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
You know, I wonder if that's not backwards - trac uses abs, vsc cuts power.
As I said above, I mostly run in VSC Sport mode, which shuts the traction control off, but leaves VSC on with a higher threshhold. When I get a little extreme, all that system does is cut power on me.
Old 04-05-2013, 04:59 PM   #42
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
Off.
Always.
It's the first thing I do. 90% of the time in winter too (Studded tires on this car is unbelievably good).
So I can have fun if I want, but mostly because I don't trust the system. Sometimes you need to power out of a situation.
I know it dangerous and an insurance liability. I've raced this car on ice, driven in snow storms without spinning the tires. As long as your aren't driving like a moron your fine (depending on experience level)
RazBRZ is offline   Reply With Quote
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 10:23 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 03:40 AM
VSC Sport, Trac Off, Both Off - Which do you use for normal driving? pinoyplaya BRZ First-Gen (2012+) — General Topics 100 08-28-2012 03:24 AM
Delivery day. To sport mode or not? Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 5 06-21-2012 07:50 AM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 12:50 PM
