Old 02-19-2014, 12:09 PM   #29
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Haven't installed them yet. Still winter in Fargo, so car is put away in the garage.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 02-19-2015, 10:40 PM   #30
dkx64
Drives: 2014 Frs
Hey just about to install JL c5-653 3 way's. could you go a bit more indepth on your install? Any cutting? Did the new tweeter fit with the new dash speaker on both sides?
thanks!
dkx64 is offline   Reply With Quote
Old 02-20-2015, 10:31 AM   #31
Gopherboy6956
thanks!
Oooo, I have to think back a bit on that one.
I don't remember having to do any other custom mounting other than the melting the tweeter to the plastic housing. I MAY had had to put the mid in there a little sideways? geeze... i'd have to look again to be honest.
I WILL Say - the best thing I did though was take the extra time and work to run the crossovers into the trunk. I've messed with the settings a few times since install, and it's really nice not to have to crack open the door panels or roll around under the dash to work with them.
I don't have any great pictures of the trunk after I did that, but it's pretty straight forward.
Old 02-20-2015, 07:51 PM   #32
dkx64
Drives: 2014 Frs
Reason I ask, is because I've been reading around and notice that some people are putting the tweeter in a DIY pillar housing. Dont get me wrong, looks pretty badass, but that would be completely irreversible. Id most likely take the JL's out of the car when I decide to sell it.
Either way, you had to make speaker mounts for all speakers correct?
Did you just run longer speaker cables from the crossovers? That does sound like a much better idea. hows that new headunit?
Old 02-21-2015, 08:00 PM   #33
Gopherboy6956
I just build the front door speaker mounts. I left the rear speakers stock and hooked them up to the amp as well.
I ran much longer cables all around, correct.
Love the headunit. I had tried a lower pioneer model but the interface was PAINFULLY slow.
Old 02-22-2015, 04:32 AM   #34
Starzard
Starzard's Avatar
I went from a 2004 RSX to a BRZ too
World Rally Blue Crew
Starzard is offline   Reply With Quote
Old 02-22-2015, 12:48 PM   #35
Gopherboy6956
Haha. It was such an eye opener to slide into the BRZ and then go back to the RSX - the seats in there felt like bench seats in comparison to the BRZ.
But the high school kid in me sure misses Vtec.
Old 02-22-2015, 02:05 PM   #36
Lonewolf
Lonewolf's Avatar
Drives: Moped
I just went through your thread from beginning to end...thanks for the car pron
Old 02-22-2015, 03:25 PM   #37
Gopherboy6956
Thanks for checking it out. I can't wait to take it out of the winter hibernation and get my smaller pulley / pro tune in April.
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
Lonewolf (02-22-2015)
Old 03-09-2015, 11:56 AM   #38
Gopherboy6956
Just ordered my 17x9 rpf1 with 255/40 ZII star specs. Should be interesting to see if it fits.
DustinS (03-09-2015)
Old 03-09-2015, 12:57 PM   #39
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Car looks really good!
What offset are the RPF1s? 17x9 et35 with 255 should fit without any issues as long as you have coilovers(which you do).
DustinS is offline   Reply With Quote
Old 03-09-2015, 01:00 PM   #40
Gopherboy6956
the 17x9 rpf1's are 45mm offset. After checking the fitment guide on here, it looks as if I might have 'predicted issues'. If i do, it seems a 3mm spacer in the front will fix that, as 42mm offset fits just fine.
Old 03-09-2015, 04:34 PM   #41
TWMPerformance
Drives: Manual Transmission, All the Way!
Car looks serious dude! (y)
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 03-22-2015, 02:28 AM   #42
Gopherboy6956
3/14/15 - Wheels & Tires and Driveshaft came in:
Enkei RPF1 17x9 45mm Offset with Dunlop ZII Star Specs
Meaty!
Driveshaft Shop Aluminum Driveshaf
Pixel67's Daily Driver Build - Journal pixel67 Member's Car Journals 44 06-16-2016 11:48 PM
Hyper-BRZ Build Journal hypermax Member's Car Journals 62 06-11-2016 12:39 AM
Build Journal for Koigataki (6MT Argento FR-S) Koigataki Member's Car Journals 25 10-10-2013 03:09 AM
Jdmitr BRZ Limited journal/build thread jdmitr Member's Car Journals 18 10-01-2012 01:50 AM
Longo Scion Demo Build Journal - Car arrives next week xravexboix Member's Car Journals 12 06-15-2012 01:00 AM
