Old 12-29-2011, 11:38 AM   #29
Levi
Drives: Toyota
Ok. Thanks. I wish to know how much lighter the CF hood of the BRZ STI is, compared to the aluminuim hood of the BRZ.
PS: Isn't CF an abrev. for CFRP?
Levi is offline   Reply With Quote
Old 12-29-2011, 11:41 AM   #30
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
I'm sure we all want to know that, but at the end of the day, the aluminum hood will probably weigh 8 to 12 lbs, and the carbon hood maybe a few lbs lighter. Its just bragging rights, not really function IMO.
The carbon roof has more merit, if the steel roof structure can be reduced from the use of carbon. It also has chassis rigidity merits, as carbon has very high compression strength.
bambbrose is offline   Reply With Quote
Old 12-29-2011, 11:47 AM   #31
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
Carbon Fiber vs Carbon Fiber reinforced polymer/plastic (I have seen both) (http://en.wikipedia.org/wiki/Carbon_%28fiber%29) Wiki link
Carbon fibers are usually combined with other materials to form a composite. When combined with a plastic resin and wound or molded it forms carbon fiber reinforced plastic (often referred to also as carbon fiber) which is a very high strength-to-weight, extremely rigid, although somewhat brittle material. However, carbon fibers are also composed with other materials, such as with graphite to form carbon-carbon composites, which have a very high heat tolerance.
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-29-2011, 02:25 PM   #32
Itgb
Drives: 2003 BMW M3, 2006 Scion xB
Here is an example of weight savings through CFRP. The BMW M3 CRT used CFRP for it's hood and stated a 75% reduction in weight vs. steel. Aluminum is about 50% lighter than steel, so CFRP is a further 50% reduction from aluminum.
Rough Example:
Steel Hood: 40lb
Aluminum Hood: 20lb
CFRP Hood: 10lb
Here's a cross section of the CFRP hood
2003 BMW M3 | 2010 Audi A4 Avant | 2006 Scion xB | PAST - 1986 MB 190E 2.3-16, 2005 Volvo S60 2.5T
Itgb is offline   Reply With Quote
Old 12-29-2011, 02:38 PM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Rough Example:
Steel Hood: 40lb
Aluminum Hood: 20lb
CFRP Hood: 10lb
Aluminum is about 1/3rd the weight of steel btw. If you use a structure under the CF (of whatever variant) the CF will be heavier.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-29-2011, 03:17 PM   #34
Itgb
Such a general statement about weight difference is not valid for this purpose. A hood(and any part for that matter) is designed specifically for the material. Metal thickness, load points, structure, etc. are all taken into account when the part is designed. If you were to switch a hood from steel to aluminum, you don't just switch the material and call it a day. The whole part is redesigned.
Here is an example of a cost analysis between steel and aluminum. They say there is about a 40% difference in weight(sorry I was off a little) after all the inner structure is trimmed away.
The purpose of CFRP is that the structure is built-in. There is no externally added structure as many times happens with CF.
Old 12-29-2011, 03:20 PM   #35
stott
Drives: 1984 Mustang SVO
it's a bit disingenuous to say that 'aluminum is 50% the weight of steel' or 'aluminum is 1/3 the weight of steel' when referring to car parts, since this does not imply that an aluminum hood will actually weigh half as much as a steel hood.
as an example of what i mean, look at a copper radiator vs. an aluminum radiator. copper is significantly heavier, and also more expensive than aluminum. but you can make an efficient copper radiator using less copper than you'd have to use of aluminum for similar heat dissipation results. copper is more than 3 times heavier than aluminum, and about that much more expensive too, yet an aluminum radiator doesn't really weigh 1/3 of what a copper radiator weighs. at best, it might weigh half, but typically closer to 60%
stott is offline   Reply With Quote
Old 12-29-2011, 03:44 PM   #36
Levi
Drives: Toyota
Saying CF is heavier than ALU is like saying an 18" rim is lighter than a 17" rim.
It depends on construction not material, and when you make a part of CF instead of METAL, it is in the aim of being lighter, not to look good. If this thread is about CF look, then I am off-topic, and this is a ricers thread.
Old 12-29-2011, 03:59 PM   #37
old greg
Rocket Surgeon
Drives: PSM GGA OMG
It depends on construction not material.
Exactly. What previous posters have been saying is that the vast majority of "carbon fiber" hoods/trunks etc. are made cheaply with a layer of carbon over fiberglass and are usually laid up wet (excessive resin = a heavy part). These parts are much heavier than they could be if done properly but are still lighter than their steel counterparts. It's this cut-price "carbon" that is heavier than an aluminum panel. Properly made cfrp parts are indeed lighter than the aluminum equivalents, but they come with such a high price tag that they are the exception rather than the rule.
old greg is offline   Reply With Quote
Old 12-29-2011, 04:30 PM   #38
Dimman
Kuruma Otaku
Dimman's Avatar
^ Fiberglass hoods with CF appearance layer...
Because titanium.
Old 12-29-2011, 04:35 PM   #39
DommerEOD
I'm a Carcissist
DommerEOD's Avatar
Drives: JERRV , 11 STI, 07 FJ
If you really want to save weight, do it the red neck way.... take the effing hood and decklid off!
DommerEOD is offline   Reply With Quote
Old 12-29-2011, 04:42 PM   #40
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
My statement was actual fact. It really is about 1/3rd the weight difference of steel. Your statement is just as variable when it comes to part contruction as mine, both are useless statements there.
I have yet to see any reasonable priced CF hood be 50% lighter than an OEM aluminum piece.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-29-2011, 04:45 PM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-29-2011, 04:49 PM   #42
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
Correct. Hypothetically the carbon fiber can never be more than 37% lighter than aluminum, let alone 50%.
All construction methods aside, just looking at density.
A 20 lb steel hood, if made entirely of aluminum, would weigh 6.8 lbs.
The equivalent hood in CFRP would weigh 4.32 pounds.
Which leads me back to my very first argument. Why spend $1000 + to save a couple pounds?
No Carbon Fiber Roof!? Slide Scion FR-S / Toyota 86 GT86 General Forum 54 07-15-2012 11:16 PM
What you want under the hood of a higher performance OEM variant of the AS1? MrVito BRZ First-Gen (2012+) — General Topics 26 12-27-2011 12:07 AM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 01:29 PM
Toyota, Subaru and... Carbon Fiber! virobloc Scion FR-S / Toyota 86 GT86 General Forum 10 10-17-2010 12:46 AM
Can someone do a chop with the hood 5cm higher as described in the Autocar interview? devtec FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 37 06-08-2010 01:11 AM
