Old 03-06-2013, 05:46 PM   #29
brzninja
brzninja's Avatar
Drives: 2015 WRB WRX Premium
Bad and no signal.
2013 Subaru BRZ Limited WRB
brzninja is offline   Reply With Quote
Old 03-06-2013, 07:00 PM   #30
Carlsbad
Drives: 2013 Subaru BRZ WRB Limited MT
The whole head unit is terrible.
I had the service bulletin performed on it (fix antenna connection and update memory card) and all my loss of signal problems went away.
the stereo is still horrible and th eusability of the navigation system is poor.
Carlsbad is offline   Reply With Quote
Old 03-07-2013, 05:24 AM   #31
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Originally Posted by chotemaamu View Post
Can you stream music from your Phone/USB even when the unit is turned OFF? I guess not. Is the lowest brightness level good enough for night driving?
Music still works with the screen off. Music is off if you push the volume button.
RAWR BRZ is offline   Reply With Quote
Old 03-07-2013, 05:56 AM   #32
tracerit
Drives: '13 SSM BRZ Limited 6MT
Are you able to stream music via blue tooth?
tracerit is offline   Reply With Quote
Old 03-07-2013, 06:02 PM   #33
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
I had the TSB done yesterday, but haven't had the chance to try it out. New cars will have the reception problem already corrected. Other than the reception it works ok, a bit clunky, but gets the job done.
Blue tooth streaming works, but you can't control an Ipod via bluetooth. There is Ipod control with USB though.
Mobius357 is offline   Reply With Quote
Old 03-07-2013, 06:46 PM   #34
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by GavinAnt View Post
After all the bad reviews, I've opted for an Alpine system.... Cant wait to get my BRZ (one of the first batch to arrive in South Africa on Monday)
thing is, the US spec unit is different than the rest of the world's
most reviews are based on that so YMMV
dori. is offline   Reply With Quote
Old 03-08-2013, 04:45 PM   #35
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Yes, you can stream music over bluetooth and the system supports DIVX videos but only through USB. It will also read back you text messages too.
Its a good standard Navigation system. Just make sure you have all the updates. The only problem is that I can not get the Navitools software to read my SD card. There are updates that have fixed problems and added features. Mine was updated by the dealer a month ago, so i figure I am pretty much good to go but is anybody else having issues with the software reading your SD card?
tripjammer is offline   Reply With Quote
Old 03-08-2013, 05:31 PM   #36
BryanGT
Drives: WRD BRZ Limited
I thought BMW iDrive was a crappy navigation / entertainment system. But this Subaru system is truly terrible in comparison. It's like they've never heard of gorilla arm. Changing the radio station requires that you take your eyes off the road. Some physical preset buttons would have been nice you tossers!
BryanGT is offline   Reply With Quote
Old 03-08-2013, 05:45 PM   #37
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Is your SD card locked? There should be a little switch on the left side of the SD card, try flipping it up or down and see if that fixes it.
LeeMaster is offline   Reply With Quote
Old 03-09-2013, 11:14 AM   #38
Imrac
Drives: 13 SWP BRZ Prem
Originally Posted by norsamerican View Post
"Traffic Jam Ahead" Me: "im the only car on the road for 20 miles" lol
^^ This.... Heading home at 4am in the morning on i5, not a single sole on the road, but every few minutes "Traffic Jam Ahead"
Overall though its fine. Mine has never lost signal, and usually has signal within 10 seconds of starting the car.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 03-09-2013, 11:26 AM   #39
#87
I usually post drunk
#87's Avatar
Ignoring the signal issue since they fixed it I only dislike 2 things.
1. Can't adjust your route without coming to a stop which is REALLY annoying. But as I understand it this is standard on all OEM navigation units.
2. Can't control music from headunit when using bluetooth. Only Next, Last, Pause, Play. Would be nice to have the USB menu when using bluetooth. Don't know if that is even possible though.
#87 is offline   Reply With Quote
Old 03-09-2013, 12:56 PM   #40
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Does it have a way to browse by folder if using USB storage?
Skippman is offline   Reply With Quote
Old 03-09-2013, 04:53 PM   #41
DeepHunta
Drives: '05 Outback Wgn, '05 Lotus Elise
BRZ nav system SUCKS! And I'm being nice here. But, whatever. It came with the car.
Before Subaru did some fiddling, I would lose signal all the time. I would be lost mid route.
After the fix, the signal is a lot better. But still the user interface SUCKS! I didn't buy the car for the nav system anyways. I bought it for the "push start button", HAHAHA!
Proud ex-owner of GBS 6MT BRZ Limited. Pre-ordered on Feb-29-2012, got VIN on 5/19 with ETA 6/6, arrived early on 6/2, but still didn't pick it up until Jun-6-2012. Recently sold the Buuurz as of 4/21/2014
DeepHunta is offline   Reply With Quote
Old 03-15-2013, 02:04 AM   #42
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I had the pleasure of this navi telling me the wrong exit, though I knew the right one... So that saved me.
But then I got to an area I hadn't been before, and it took me 20 miles away from my destination. Very frustrating.
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
sprintertrueno86 (03-20-2013)
brz navigation headunit in frs? p00mba Electronics | Audio | NAV | Infotainment 9 02-20-2015 03:51 PM
Navigation Units Dispect Electronics | Audio | NAV | Infotainment 12 12-16-2012 04:50 PM
So, how is the navigation? MmmHamSandwich Electronics | Audio | NAV | Infotainment 25 08-27-2012 03:12 PM
Navigation for FRS? Yuck Electronics | Audio | NAV | Infotainment 5 08-27-2012 01:02 AM
Navigation in daylight zex Cosmetic Modification (Interior/Exterior/Lighting) 3 07-05-2012 12:47 AM
