Old 04-11-2012, 08:04 AM   #29
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
Originally Posted by ZmZMWagon View Post
Did they say when it would be available for sale?
Not that I know of. I'm hoping that the person who actually talked to them will chime in at some point.
Brett
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 04-11-2012, 10:25 AM   #30
Brett
They had it for sale at the FormulaD event didn't they? I know they had them in their booth, but maybe that was just a sample. It did have the 4WD chassis.
Oh and like most RC cars the proportions were wrong. It was too wide because of the Chassis.
Old 04-11-2012, 01:06 PM   #31
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Originally Posted by Kiwi View Post
I'm 100% sure it will be AWD.
RC cars require AWD to drift properly. The shrunken down size and weight of RC means it doesn't behave the same as real life cars.
Pshhh really? then how is this possible...
[u2b]APIrg7cEVYw[/u2b]
The key to RWD RC drifting is actually knowing how to tune a drift car. People running crazy CS setups say it's a very similar feel to RWD drifting.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 04-11-2012, 01:59 PM   #32
Kiwi
Drives: Volkswagen Golf GTI
Ok you've found an example to prove me sort of wrong.
The fact that most RC cars don't behave like real cars still applies. Notice that he requires "crazy" setups and also modification of the RC car to mimic the actual design of RL cars. The most obvious is the need to place the motor in front of the front axle. Most RC cars have most of their components placed between the axles, keeping the mass very close to the center. So with this kind of design, there isn't enough momentum at the front to keep the drift going, which is why the front wheels require some power to hold a drift. So unless HPI designs a chassis specifically for the purpose of drifting with Rwd, it will have awd.
Kiwi is offline   Reply With Quote
Old 04-11-2012, 03:01 PM   #33
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
I'm positive HPi won't be making them for a while, but placing the motor in front of the axle is NOT necessary, there are many RWD drift setups that have the motor behind the front axle, but close to it. Steering servos however can be placed in front of the axle, and help with the distribution.
What really matters in a RWD RC drift car is:
1. weight distribution (60/40 is ideal)
2. steering lock (70+ degrees almost a requirement)
3. caster and camber (caster is non adjustable, requires modification or custom setup)
4. throttle response (something nitro rcs don't have)
5. the right tires (preference really, but some RWD setups are on rubber tires, not abs plastic like the 4wd.)
Considering the amount of custom work required, many 4wd drifters just say it's impossible, when in reality it just requires a bit of modding and a lot of skill.
Anyway, I'm sure it'll catch on, just give it some time. One thing's for sure though; the people who have done it are happy with the results, and it's one step closer to real scale drifting.
edit: just re watched the vid, and I'm not sure if you are aware, but the motor is close to the rear axle in the car in the vid, further proving my point. His car is completely stock with the addition of a metal lock to aid the weight distribution problem of the stock car.
Old 04-11-2012, 04:35 PM   #34
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
HPI
Originally Posted by Argent6978 View Post
I'll probably just buy the body and put it on one of the cars I already have.
Yeah should fit E-10 / Sprint 2 I bet
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 04-11-2012, 05:43 PM   #35
Brett
First 86
Brett's Avatar
I don't know. I didn't actually go to their tent.
Brett
Don't shop, adopt!
Old 04-12-2012, 03:10 AM   #36
Kiwi
Looks like you're correct. I've mistaken the object over the front axle as the motor, but in fact it is still in the middle.
Old 08-21-2012, 06:47 PM   #37
JC@lutzPerformance
Drives: haggard drift mobile
did they ever release the body for this? or RTR kit?
JC@lutzPerformance is offline   Reply With Quote
Old 08-21-2012, 07:25 PM   #38
CrazyWookiee
Drives: Whiteout FR-S
Tamiya has released a TT-01 Chassis with an 86 Body:
http://www.tamiya.com/english/produc...ta86/index.htm
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 08-21-2012, 07:27 PM   #39
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
This better have more than 200 hp
oso_25 is offline   Reply With Quote
The Following User Says Thank You to oso_25 For This Useful Post:
Prava (10-16-2012)
Old 08-21-2012, 08:17 PM   #40
DanVIIIVI
DanVIIIVI's Avatar
Drives: 86GTS 6M
Tamiya already has 2 'Toyota 86' versions of RC cars out on the market. One is based on the entry level TT01 chassis and the other is the more advanced TA06 chassis which can be set up for counter steer drift.
I already have a HPI Sprint2 Flux chassis with a mustang body and just bought myself a clear 86 body shell to paint pearl white as a miniature version of my ordered 86 till it arrives
DanVIIIVI is offline   Reply With Quote
Old 08-21-2012, 08:43 PM   #41
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Pics?
Old 08-21-2012, 08:54 PM   #42
DanVIIIVI
DanVIIIVI's Avatar
Drives: 86GTS 6M
Pics?
TA06
http://www3.towerhobbies.com/cgi-bin...&I=LXCLUF&P=PU
TT01E
http://www3.towerhobbies.com/cgi-bin...&I=LXCLHV&P=PU
For those that already have a 1/10 scale chassis and just want the body: http://www3.towerhobbies.com/cgi-bin...?&I=LXCLVU&P=7
sorry folks, Scion FRS will have Scion badge on steering wheel CyberFormula FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 12-05-2011 02:36 AM
Just got off the phone with Scion... FR-S release date late spring 2012 nate89 Scion FR-S / Toyota 86 GT86 General Forum 13 12-03-2011 04:00 AM
Greddy Set to Build Scion FR-S for Ken Gushi in 2012 Kids Heart Scion FR-S / Toyota 86 GT86 General Forum 8 11-29-2011 10:22 AM
Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion UriarteMD FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-14-2011 08:13 PM
2012 Honda civic VenomRush Other Vehicles & General Automotive Discussions 38 05-17-2011 05:26 PM
