Old 02-22-2013, 01:49 AM   #29
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Nitro22 View Post
Hi Huehuecoyotl,
Hotchkis Camber Plates do not raise the car. You do not lose any bump travel. This was a major consideration when they designed them. The bearing bucket resides above the strut top surface, but the plate portion is mounted underneath the strut tower. This will allow the customer to use any strut brace as well. Everything made in the USA btw. =)
Cheers,
-Aaron
But the Hotchkis camber plates, like the Whiteline top hats, don't allow you to adjust/tweak camber (I think). If I'm not mistaken, if you use the Hotchkis camber plates, you are meant to adjust camber with the crash/camber strut bolts. So if I want to use fixed strut bolts the Hotchkis plates won't work.
Phaedrus29 is offline   Reply With Quote
Old 02-22-2013, 01:59 AM   #30
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
Hi Phaedrus,
Hotchkis Camber Plates are completely adjustable. The plate itself is slotted, so it can slide inboard/outboard as desired. The crash bolts allow for even further adjustment. (zero to -3 degrees) You can still use the original strut bolts and acheive up to -1.5 degrees of camber with plates alone.
Cheers,
-Aaron
Nitro22 is offline   Reply With Quote
Old 02-22-2013, 02:04 AM   #31
jamal
jamal's Avatar
Drives: Legacy GT
It doesn't appear that you can use these camberplates with stock sized springs or RCE yellows though, right?
Originally Posted by sw20kosh View Post
I'd really like to know which camber plates besides the Hotchkis and AST work with stock suspension. @Racecomp Engineering
AST: http://86tech.com/forums/showthread.php?t=93
RCE plates work with stock springs too. They even mentioned it in this very thread.
Originally Posted by Racecomp Engineering View Post
Ours use the stock springs perches for springs and for coilovers you use the perches that the coilovers come with.
/threadjack.
- Andrew
jamal is offline   Reply With Quote
Old 02-22-2013, 02:10 AM   #32
Phaedrus29
Phaedrus29's Avatar
Hi Phaedrus,
Cheers,
-Aaron
Ah I see the slots now in a picture. So would the TIC plates have more adjustability than the Hotchkis plates alone?
I thought he was saying the RCE yellow springs work with the stock spring perches. Does RCE even make camber plates for the BRZ?
Old 02-22-2013, 05:56 AM   #33
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by GC_Adam View Post
No, Our camberplates do not raise the car. They actually give back some of the bump travel lost when you lower these cars.
In the pic the green line represents the fender...Now see how we've moved the upper spring seat and strut mounting point further up effectively giving back bump travel lost when lowering your car.
With other mass-produced off shore camberplates that mount flat from the bottom you end up losing valuable stack height and bump travel.
very good picture, thousand words, good explanation
thanks
Huehuecoyotl is offline   Reply With Quote
Old 02-22-2013, 10:04 AM   #34
Yes, we have plates but have some supply issues at the moment.
- andrew
Old 02-28-2013, 01:17 AM   #35
Xdragonxb0i
Drives: ex500r
how difficult would it be to add camber plates on a basis/street level suspension that doesnt normally come with a camber plate pre installed?
Xdragonxb0i is offline   Reply With Quote
Old 03-01-2013, 03:41 PM   #36
GC_Adam
GC_Adam's Avatar
Drives: '08 Impreza, 03 SV1000S
Its not difficult at all, provided the plates have the correct hardware to work with what ever dampers and springs are being used.
GC_Adam is offline   Reply With Quote
Old 08-30-2013, 04:17 PM   #37
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Do u have those hotchkis plates for sale? Do they work with stock shock and lower spring?
Hi Phaedrus,
Cheers,
-Aaron
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-05-2013, 06:34 PM   #38
Nitro22
Nitro22's Avatar
Hotchkis Camber Plates are sold directly through Hotchkis. They are designed to work with the OE strut with lowering springs or OE springs. They definitely work with Koni's as well. They will also work with coilovers that normally utilize the OE top hat.
Cheers
Old 09-05-2013, 07:25 PM   #39
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
wat!
TouchMyHonda is offline   Reply With Quote
Old 03-21-2014, 04:01 AM   #40
DAEMANO
Time Traveller
- andrew
How's this coming along? Any idea of a restock ETA? Your plates look like they could fill a lot of needs here Andy.
Thanks!
Old 03-24-2014, 12:01 AM   #41
Insurme1
Drives: 2013 Scion FR-S 10-Series
Has anyone had experience with the MK1's on ebay? (Camber kits)
Insurme1 is offline   Reply With Quote
Which camber plates are you running? Coastermikey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-15-2014 10:26 AM
MSI Camber plates wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-29-2012 07:16 AM
Camber Plates delusional Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-30-2012 08:17 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
