#29 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#30 |
Make love
Drives: H8R.. Not really
#31 |
Drives: Lightening Red BRZ Ltd.
I'm curious to see if there are other locations that this cooler can be set up. Here in Jersey the roads aren't great and it would be nice if there was a place on the car with good airflow while being protected from the elements.
Also, this looks like a good upgrade for this car as high oil temps eat away at power. |
#32 | |
#33 | |
Site Moderator
Drives: Stuff
You couldn't use their mounts but unless it's too wide you should be able to mount it vertically. I can't remember how much space is available over there. If it's in a place without air going past it or you have to run a small cooler and long hose runs I'm not sure there's a ton of benefit... if you put it there run one of the brake duct kits (on the pass side only) and direct air to the cooler on the passenger side. Drivers side would be more ideal from a oil line run length perspective but these cars have absolutely massive windshield washer tanks so all your space is taken up there already ![]() You can get the cooler measurements from Perrin but they'd have to make you custom lines or you'd have to throw these lines away and make new ones.. unless you can figure out how to route them in such a way that they'll reach to the pass wheel well (talking about the perrin kit specifically). Unless I'm wrong on the HKS one, it's basically a box of parts for you to figure out at MASSIVE margins.. I'd go with the Perrin kit any day of the week over that.
-Dave
#34 |
Site Moderator
Drives: Stuff
Just looked at some pics of the HKS stuff, you do in fact have to cut the lines yourself, figure out mounting, etc.. I like their thermostat except you need 90s (for pressure drop concerns you want as few bent fittings as possible!) for it but I like that you can get temp and pressure from the oil cooler sandwich adapter if you want. Otherwise, the HKS setup is one of the worst. The Greddy might be as bad, it's got a "funnel" to force air to it though.
For a packaged air-to-oil setup the Perrin does look like the best solution IMO. If you want something like the HKS make it yourself (you will be doing so with the HKS anyways, just paying double for the name).
-Dave
#35 | |
I guess for myself it's going to have to be pieced together myself or going the HKS route, unless Perrin can get me custom lines. This is what I have in mind. I just don't think I can fab up the metal piece in the HKS kit myself. ![]() ![]() If you look closely, the shield/metal is venting air to the oil cooler. Cutting out the area where the foglight on the FRS is simple enough like shown in this link, or doing a brake ducting like you said would add even more air. http://www.ft86club.com/forums/showthread.php?t=29281 |
#36 | |
Site Moderator
Drives: Stuff
![]() HKS description says 4M hose, which means you have to cut, route, put the ends on, etc yourself. That means doing it yourself. The Perrin kit comes with the hoses completely assembled, instructions on routing, etc. That big black plate isn't shown on FT86SF's site so I had no idea it was included nor is it mentioned specifically in the product descriptions I've seen from HKS when it first came out. If they are including that then installing the core itself would be easier. Any non HKS intercooler may make it less friendly of course for running the piping through it You still have to deal with the SS lines, so if you go that route I'd suggest the Koul Tool kit for SS lines, makes installing the hose into the socket a breeze, some hose assembly lube and put the fitting in the socket. Cut the SS line with a cut off wheel until you get to the inner rubbing, blow off line, cut rubber, blow out line (from the other end not where you just cut) to remove debris, etc.So that's what I mean by universal. Awesome if it includes a mount, it just wasn't visible or mentioned so I wasn't aware of that. I bet the back of that cooler gets coated in rubber and rocks pretty quickly lol
-Dave
#37 | |
I know HKS gets bashed a lot for being too universal and not specializing on any specific car company. I used to work at HKS, so i've personally seen R&D or at least heard about it. They definitely don't just throw on a bunch of parts in the catalog and hope it works I guess when it comes down to it, yes you are paying for the name and R&D for both the HKS and Perrin kits. You could put it together yourself for cheaper but at the expense and risk of your own R&D |
#38 | |
Site Moderator
Drives: Stuff
Other than that they make fine parts. Not much R&D in a cooler though. The only specific bits of the low spec kit is the spacer. The high spec, the spacer, grill for the wheel well, the mount and cutting the lines for you. I can fit an intercooler just fine with my setup and I know you can with Perrins also, so is the... 1100? or whatever the high spec will cost really worth it? Obviously that'll all come down to personal opinions
-Dave
#39 | |
I wasn't thinking much R&D is needed for oil coolers, but I do remember Perrin had the fitting come off on the prototype oil cooler that made a mess for a member on here. Just small things like that is the R&D i'm referring to. I rather have a company like Perrin resolve hiccups instead of myself. Basically I want to know someone with more knowledge with myself put the kit together. Yeah i've heard of the horror stories about HKS air filters. I actually had the HKS intake for my S2000 and it didn't seem to bad or clumsy. Then again I replaced the filter more often then recommended. |
#40 | |
Site Moderator
Drives: Stuff
![]() Perrin took care of the customer though and he was a tester, not a full paying customer
-Dave
#41 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
The Lotus Elise had two oil coolers back in 2005, then they made it an option in 2006 only coming with one unless you purchased the 'track pack' to go from one to two. Cars that are driven hard and red lined should probably have one. I bought the Perrin but haven't installed it yet.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| real world mpg frs/brz | muffinman | Scion FR-S / Toyota 86 GT86 General Forum | 131 | 07-13-2017 02:26 AM |
| You want it, you got it: PERRIN Oil Cooler GB | JoeBoxer | Groupbuys | 96 | 06-16-2013 03:10 PM |
| Perrin oil cooler group buy? | white devil | Engine, Exhaust, Transmission | 6 | 02-10-2013 03:17 AM |
| Real-World Data importing into GT5 | SnapOv3st3r | Other Vehicles & General Automotive Discussions | 0 | 09-07-2012 06:25 PM |
| Actual experienced real world fuel mileage MPG? | R8 | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 07-24-2012 07:50 AM |
