Old 02-12-2013, 11:28 PM   #29
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
Originally Posted by dori. View Post
trunk that wont pop without they key
Originally Posted by immortal_suby View Post
What does this mean?
I assume you checked the trunk lock button on the left side inside the trunk right????
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 02-12-2013, 11:47 PM   #30
Sean-SRM
Sean-SRM's Avatar
Drives: Silver Scion FR-S
Have around 11k miles. The problems I have had are very similar to what has been posted.
The windows not working in the cold is by far the most frustrating!
Sean-SRM is offline   Reply With Quote
Old 02-13-2013, 07:03 AM   #31
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
you know, I totally forgot about that!
I've had something rolling around in the trunk so it probably hit it
dori. is offline   Reply With Quote
Old 02-13-2013, 10:56 AM   #32
chandz05
chandz05's Avatar
Drives: CBS BRZ limited MT
Almost 10k miles here, and no issues, chips or scratches even though I've been using her as a DD (knock on wood). I *might* have the chirping issue, but I can't be sure. I can't hear the sound at all from inside the cabin with the windows closed. Doesn't bother me, so I don't worry about it. Definitely have crappy GPS signal, but once again I hardly use the GPS, so eh.
chandz05 is offline   Reply With Quote
Old 02-13-2013, 11:11 AM   #33
Jayde
Jayde's Avatar
~7200 miles. Chirping fuel pump but rarely hear it since it's cold out. I'm sure once it warms up I'll start hearing it again. Also have the rear deck or airbag pop/tick/noise as well as a similar noise from the driver's window.
Jayde is offline   Reply With Quote
Old 02-13-2013, 02:13 PM   #34
xxscaxx
Drives: 2013 SWP BRZ
over 8k, just the chirp. GPS signal too but I haven't gone back yet to get it fixed.
xxscaxx is offline   Reply With Quote
Old 02-13-2013, 03:03 PM   #35
strat61caster
strat61caster's Avatar
Originally Posted by dmudry View Post
i just ordered my car in January, and it is being built right now. does anyone know if they have fixed all of the small issues at factory level? and will mine come with the relocated GPS, tail light condensation and oil burning fixed?
Mine was built in December, 2,500 miles later no real issues to speak of, nothing worth taking it into a dealer. By which I mean I don't think I could get them to do anything to the car no matter how hard I complained, no noticeable condensation, crickets are minor, smells and rattles are intermittent and could easily be attributed to "quirks" (No GPS, no cold weather so those don't apply to me).
Only posting because I doubt anyone who is posting here has a car built later than October...
Old 02-13-2013, 04:04 PM   #36
Goya
Goya's Avatar
Can someone explain this trunk issue? Is it that the trunk wont open, or that it opens when you dont want it to?
Goya is offline   Reply With Quote
Old 02-13-2013, 04:13 PM   #37
strat61caster
There's a button inside the trunk to the left. When it is pressed it activates a valet mode so that it can only be opened when a key with the proper RFID chip (not the valet key) is used in the keyhole of the trunk (under the lip to the right of the licence plate). It will not open if you press the button from the cabin or the button on the key. It gets pressed accidentally and then you have to insert your key in the trunk keyhole open it, then press the button to set it to normal mode.
It's all clearly explained in the manual which nobody seems to read.
Old 02-13-2013, 04:15 PM   #38
Jayde
Jayde's Avatar
Sure you guys didn't hit the button in the trunk that cuts access off to using the key?
Old 02-13-2013, 05:05 PM   #39
fritzy
Drives: BRZ WRPB Premium MT
Nearly 7000 miles.
GPS, which I just found out there's a fix for from this thread (thanks!)
Backed into an illegally parked car in the dark (my fault, really), and chipped the bumper plus some scuffs and cracked the tail lens. I'm trying to figure out if I want to make an insurance claim to get that fixed at a $500 deductible.
I've noticed the center dash rattle -- few things bother me as much as that, but not lately (maybe an AC thing?).
fritzy is offline   Reply With Quote
Old 02-13-2013, 06:15 PM   #40
NOHOME
Drives: RAVEN
So the answer based on what I read is that "No Problems" is the exception.
NOHOME is offline   Reply With Quote
Old 02-13-2013, 06:34 PM   #41
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by foxhu View Post
Any body has their BRZ/FRS over 5k miles and have no or little problem with their car??
bow:
BRZ 5500 miles- only recall atm. no engine failure or so. accidents during 2000 miles only bummer got mess up.
no issues at 23,000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 02-13-2013, 08:58 PM   #42
dori.
Señor Member
dori.'s Avatar
no, I can use the key to open it, but not the button on the dash or the button underneath the trunk lid
Miles miles miles kndonlee Scion FR-S / Toyota 86 GT86 General Forum 52 12-17-2012 03:06 PM
How many miles are on your FR-S? Jayde Scion FR-S / Toyota 86 GT86 General Forum 47 11-26-2012 12:24 AM
Only 951 miles to go! TRBO2NR Scion FR-S / Toyota 86 GT86 General Forum 25 10-26-2012 01:34 PM
how many miles everybody at? cjdriiiiift Northwest 24 10-23-2012 10:54 PM
Just hit 1k miles! pinoyplaya BRZ First-Gen (2012+) — General Topics 3 08-26-2012 10:52 PM
