#29 |
Because compromise ®
Drives: Red Herring
@Turdinator
I have a Beatrush one fitted. Seems functional enough. Nice large surface area against the master cylinder. Painted black, blends in nicely in the engine bay.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Turdinator (01-24-2014) |
#30 | |
Chase Engineering |
#31 |
Just a dude
Drives: Scion FR-S 2013
I have the GS one zero complaints here. Radium Engineering now also makes one to, looks nice.
#32 | |
Señor Member
It would match your strut brace I already have.
1974 TA22 Celica
2013 86 GT |
#33 | |
Dances with Cones
Drives: 2013 Scion FR-S Raven
The red "cap" on the end does appear to help spread out the amount of direct surface pressure on the master cylinder. Whether this is needed or not, I don't know but it does help finish it off. Does it work? No idea. The pedal does seem to be a little more direct but I wont know until summer if it's actually contributing or not. Even then, it still might just be a guess whether it's working or not. Good thing I bought it used
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
#34 |
1. Radium
1. Perrin 2. GrimmSpeed
| The Following User Says Thank You to Dezoris For This Useful Post: | JR007 (02-27-2014) |
#35 | |
Thanks again, we appreciate it! Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | Turdinator (01-27-2014) |
#36 | |
Pegasus White
Drives: 86
![]() I'm happy to be the tester
Driving: Pegasus White Manual GTS 86.
#37 | |
Drives: '11 535i
![]() The stainless steel set screw we use, actually bites into the aluminum a bit which creates a more solid connection. This is important to understand, as the MC doesn't just flex straight out from the fire wall, it actually flexes left to right a little bit. We found on the STI's, that the movement left to right is significant enough that having a smooth flat "cap" may still allow for some movement. So our cup point set screw, serves two purposes, which both reduce the movement. Also keep in mind that those parts are very thick and they will not cause damage to the MC. |
| The Following User Says Thank You to PERRIN_Mladen For This Useful Post: | Efferalgan (01-28-2014) |
#38 | |
Drives: 2025 BRZ, ex-2012 GT86
#39 |
Good stuff, we'll be in touch!
We'll continue to include the red anodized machined cap. We tested a number of setups and cap designs, along with no cap at all, and found no relative motion between the cap and the master cylinder while in use. With that, the cap essentially acts as an extension of the master cylinder, distributing the forces across the entire back of the casting and protecting your OEM components. If that's not a concern, or if you'd prefer to use just the bolt, removing the cap is always an option. Obviously, this differs a bit from Mladen's design methodology and test results, but regardless, I'm sure their braces offer an improvement in pedal feel as well. Either way, it's an awesome upgrade, so pick the one that you're most comfortable with! If you're interested in following along with our design process, check out this thread: http://www.ft86club.com/forums/showthread.php?t=11831 Chase Engineering |
#40 |
Drives: Ultramarine FR-S
#41 |
I have a stack of Radium stuff sitting in garage to finish video on.
Will post up in a few weeks. In terms of the brace its by far the most robust design, however the likely truth is I doubt it would technically reduce deflection more than the others. But since they did modeling around forces similar to suspension parts it's an easy sell.
#42 | |
Drives: 2013 SWP BRZ
correct me if I'm wrong..but from your explanation, if the MCB moves not only vertically but horizontally and the set screw 'bites' into the aluminum then will it not carve/wear it away and cause room for movement? |
| DIY - Master Cylinder Brace - Grimmspeed | F1point4 | DIY (Do-It-Yourself) Guides | 27 | 05-28-2018 04:35 PM |
| BRZ/FR-S master cylinder brace - $60 | Turn in Concepts | Brakes, Suspension, Chassis | 35 | 01-26-2013 01:17 PM |
| Perrin master cylinder brace | SubaSteve | Brakes, Suspension, Chassis | 9 | 01-11-2013 11:46 PM |
| Perrin master cylinder brace for sale | SubaSteve | Mid-Atlantic | 0 | 01-07-2013 08:52 PM |
