Old 12-22-2013, 04:10 PM   #29
alexm86
Drives: White GTS Manual
Originally Posted by mfbmike View Post
I'd like to hear more of your impression with the DBA T2 rotors? What about them didn't you like? Did you also change pads/fluid?
After a few sessions on the track they started to make a whurring noise, a friend of mine runs the same rotors and he had the same experience.
After a week or so of very mild driving it went away though and hasn't come back even with some intense braking I've had in a recent heat wave here in Aus.
I was considering changing to T3 Rotors instead but now I'm thinking I might just get a BBK.
I changed the Pads to Ferodo DS Performance pads, they didn't get much fade but they crumbled a little around the edges, next time I'm gonna run Ferodo DS 2500 pads instead as everyone has been recommending them.
Fluid was changed out just before the track day to a Bendix fluid, not sure on the deets on it I just asked my mechanic to sort it quickly before the track day as the original fluid was almost brown.
alexm86 is offline   Reply With Quote
Old 12-23-2013, 03:07 AM   #30
mfbmike
Drives: 2013 FRS, 2008 R32
Hm, I wonder if it was a bedding issue that caused the noise. Oh well. Thanks for the insight.
mfbmike is offline   Reply With Quote
Old 03-16-2014, 08:07 PM   #31
alexm86
Changed to some DS2500 pads and Dixcel 328 racing DOT 4 Fluid two weeks ago thanks to Garage 88.
Feels much better on the road with a better pedal feel.
I'll have it out at the track next month to feel how it actually holds up at the track
Old 04-19-2014, 09:04 PM   #32
alexm86
Installed an OEM Subaru Oil Cooler, should drop track temps from 130 Degrees to no more than 110 Degrees
Thanks to Forged Performance for setting up the kit https://www.facebook.com/forgedperformanceaustralia
Old 04-29-2014, 10:19 PM   #33
alexm86
Sparco 4-Point Harness & Custom Fire Extinguisher Centre Console Mount
Red vs White nix Scion FR-S / Toyota 86 GT86 General Forum 91 01-23-2015 12:38 PM
Does this car only come in white? dori. Scion FR-S / Toyota 86 GT86 General Forum 61 09-29-2012 09:51 AM
We need a white FT-86 Rockstar AUSTRALIA 13 12-03-2011 11:50 PM
