Old 06-05-2014, 02:31 AM   #29
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by 86drift View Post
I'd like to see evidence of that. Rather than assumptions based on a table name change. It's easy to test. Just make one map really aggressive.
The throttle maps are completely different though for those 2 "modes", enough that it would be very obvious, not a " I think I can feel a difference " kind of thing. The VSC buttons do not affect throttle response.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2014, 02:37 AM   #30
86drift
86drift's Avatar
Drives: Toyota 86 GT
Originally Posted by skye67 View Post
It does feel better after I push the button. Pushing buttons is fun.
I like pushing buttons to :-)
My butt dyno must be better calibrated and thus able to notice the difference.
86drift is offline   Reply With Quote
Old 06-05-2014, 04:12 AM   #31
Kodename47
Kodename47's Avatar
Drives: UK GT86
You wouldn't need a decent butt dyno to be able to tell the difference. The only "SI Sport" labelled tables are to do with throttle mapping. Actually to be precise it's the accelerator pedal to desired torque tables. These then look up a separate torque to throttle angle table. Anyway here are the 2 tables:
That's quite a big difference, that'd be very noticeable not a "I think I can feel a difference".
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2014, 05:15 AM   #32
Guillaume
Guillaume's Avatar
Drives: Exige S 240
I agree that the difference when the sport mode is engaged is subtle, at best. And I also agree that the "SI Sport" table is hugely different from the normal one.
But then what does that mean? The "SI Sport" is never used?
Old 06-05-2014, 05:30 AM   #33
steve99
What myself and @Kodename47 are saying is that their is a huge difference in the throttle tables so if in fact these tables were switched when you pushed the VSC sport button there would be a huge difference in throttle response. when in fact there is not.
What we suspect is these tables are for normal and limp home/safe mode when the ecu detects a sensor or other problem and not in fact used for "sport", or they maybe just not used at all
Their are also cam timing tables for normal and safe mode and ignition tables for normal and safe.
In romraider these are labeled A and B with no reference to "sport" his tables are from Ecutek definitions
Any difference you feel may be just the less intrusive traction and stability control in "sport" mode this can actually slow or limit throttle response when slip or loss of traction detected as well as apply individual brakes
Old 06-05-2014, 05:38 AM   #34
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Ha yes, that explanation I can buy. Because I seriously feel no difference when the sport mode is engaged, and the "limp vs normal" explanation makes a lot more sense to me.
Old 06-05-2014, 06:33 AM   #35
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm pretty sure the "SI sport"/#2 is what the ECU usually uses as it ties in better with the other DBW tables. Table #1 looks more aggressive though, the torque request at low throttle and low pedal % is quite high, so I would guess that it's not used. Maybe a cruise map?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2014, 07:26 AM   #36
steve99
reckon that SI drive stuff is possibly a hangover from legacy's definition
http://www.subaru-global.com/tec_sidrive.html
H&R Sport & Super Sport Springs for FR-S / BRZ @ Guerilla Racing GuerillaRacing Brakes, Suspension, Chassis 5 01-11-2013 05:20 PM
FR-S E85 Tuned! Kochinopride Engine, Exhaust, Transmission 9 11-07-2012 02:29 AM
Lutz Performance | STANCE (Super Sport & Supe Sport+) coilovers Diego@lutzperformance Brakes, Suspension, Chassis 1 10-04-2012 01:43 PM
FR-S vs. Tuned WRX and Tuned B8 S4 Snozzberries FR-S / BRZ vs.... 2 07-29-2012 09:35 PM
Used tuned 86! STJ Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2012 10:42 PM
