03-10-2013, 10:31 AM | #29 |
OK, so Redline or OEM fluid recommended. Think I will be doing 30K change after reading this as well.
03-10-2013, 11:18 AM | #30 |
Drives: Whiteout FR-S
I would stick to the OEM fluid, it's very difficult to get 100% of the fluid out when doing an AT change unless you flush it which would be very expensive to do every 30k miles. I'll stick with a drain and fill using the factory fluid every 30-45k miles depending on driving style.
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post: | amram (03-26-2014), MmmHamSandwich (05-10-2013) |
03-10-2013, 11:55 AM | #31 |
Oh yeah, good point. If just draining and filling/changing without the flush some of the new will mix with old so in that case using same fluid is ideal.
03-10-2013, 05:47 PM | #32 |
In our experience the mixing of either Amsoil Synthetic or Redline High Temp ATF is perfectly fine, they are built to mix with the OEM fluids otherwise anyone who changed to a different fluid would have issues on their cars. That may have been true back in the 70s and 80s but not with modern Synthetic ATF.
-Mike Paisan 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
The Following 4 Users Say Thank You to AZP Installs For This Useful Post: |
04-02-2013, 11:49 PM | #33 |
AutoX-10/10ths every run
I stopped by a local Subaru dealer and asked about a AT service. They quoted me 52.50 plus fluids (@9.06QT). I figure that it'll take 6QTs. That'd be around 110.00ish Vs 250 at the Scion dealer.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
04-03-2013, 10:14 AM | #34 |
Drives: WRB BRZ
Is this price quote JUST for a AT fluid change? or is this like a package that they also change other things?
04-03-2013, 11:43 AM | #35 |
I asked them how much to change the AT fluid, and that was the number they gave me. Seems like the Subaru dealer is the way to go.
04-03-2013, 12:36 PM | #36 |
Member of the year - 2016
Drives: Scion FRS
I thought Subaru dealers refused to work on the FRS? Even though they are bascially the same car?
06-27-2013, 05:15 PM | #37 | |
Basically, it's 3x drain/overfills @ 2.1Quarts. So you'll need 6.3 US Quarts. drain/overfill, engine on, Park to M & back drain/overfill, engine on, Park to M & back drain/overfill, bring oil to "proper" temp, & drain through overflow until it's thin as a thread. tighten everything to spec. The instructions are obtuse because of the jumping around and slight differences in procedures on the first, second and third drain & overfills. |
06-27-2013, 06:59 PM | #38 |
We generally do our customers ATF on a 30k interval changing out about 1/3 to 1/2 of the total capacity during that change. We refill the exact amount that we remove so we know it has the proper amount in there. We haven't done any of the BRZ/FRS yet so we will have to investigate this procedure before we do one and see what we think of it.
06-28-2013, 09:30 AM | #39 |
Just drive it
Drives: 13' FR-S
Heck, don't feel bad about spending $250 on AT flush service...
I took my previous A4 to dealer for AT service and they quoted 970... Audi auto trans fluid costs 479+ JUST for parts... plus they charge like 2-3 hr for labor (reset trans module, update code, yadayada) |
06-28-2013, 09:31 AM | #40 |
Just drive it
Drives: 13' FR-S
06-28-2013, 10:18 AM | #41 | |
-Mike Paisan AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor! 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
Similar Threads | ||||
DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 02:23 PM |
Mt transmission fluid swap | bdanisi | Engine, Exhaust, Transmission | 8 | 02-08-2013 02:09 PM |
Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
