Old 11-29-2011, 05:17 PM   #29
SHINCHU86
SHINCHU86's Avatar
Drives: 98 z28 but i miss my ae86
Originally Posted by bambbrose View Post
I think these are horrible.
Almost as bad as the OEM 17" wheels. The BBS look much nicer IMO.
I think a wide 17" with proper offsets will be the best.
QFT
first mod = rolled fenders
Sold my 94 S14 for a 1998 Z28 Camaro. Woops.
Springs, Shocks, Sways, Bushings
Cam, Lid, magnaflow catback, BBK intake manifold, LS7 lifters, ECU tune. good for 400 hp.
sure its fast, but it drifts like a boat.
SHINCHU86 is offline   Reply With Quote
Old 11-29-2011, 05:49 PM   #30
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Originally Posted by speed-wiz View Post
It's too bad because wheels with lower or negative offsets usually look much better.
Negative offset? Enlighten me..?
looked it up, aesthetics only ewwww
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 12-06-2011, 06:51 PM   #31
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
Originally Posted by SHINCHU86 View Post
QFT
Already done from factory from what I read....
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-06-2011, 11:45 PM   #32
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
What would be the best offset for performance do you guys think? Why do people want ridiculously big wheels like 18s or 19s? Aren't 17s usually preferred as a mix of looks and performance?
koyv90 is offline   Reply With Quote
Old 12-07-2011, 12:17 AM   #33
JFC
Drives: 2015 86, 2015 Evo X
QFT
Um correct me if im wrong but arent the GT86 fenders already rolled??
Pretty sure seen a pic of it at the Japan Launch.
JFC is offline   Reply With Quote
Old 12-11-2011, 02:22 AM   #34
caeavesrsx-s
Drives: 02 Swede
Originally Posted by quik1987 View Post
What do you guys think are the biggest, lightest 18s that will probably fit the big brake kit?
SSR Comps, if they come in 5x100.
caeavesrsx-s is offline   Reply With Quote
Old 12-11-2011, 03:03 AM   #35
3scapist
Argues nekkid
3scapist's Avatar
Drives: 08 E92 M3
I'm personally in love with the Enkei PF01s
http://www.tirerack.com/upgrade_gara...t+Silver+Paint
and O.Z Alleggerita HLT's
http://www.tirerack.com/upgrade_gara...racite+Painted
Both 18's and both simple lightweight designs.
3scapist is offline   Reply With Quote
Old 12-11-2011, 05:22 AM   #36
cossey
Drives: Reanult Megane R26
they do 18x7.5s only though at 17.4lbs they aren't the lightest though, Advan RS in the same size is 16.5lbs and TE37s at 17lbs
cossey is offline   Reply With Quote
Old 12-11-2011, 05:36 AM   #37
3scapist
Argues nekkid
3scapist's Avatar
Drives: 08 E92 M3
I wonder how much the stock rims and tires weigh. I know the stock genesis coupe rims weighed a heafty 25lb..goddamn.
Old 12-11-2011, 12:09 PM   #38
JDLM
JDLM's Avatar
The 18 or 19 ? (They offer a 19 I believe)
On my BMW I have factory 18" wheel w/ runflats (staggered tires) to 19X10 and 19X8.5 wheels (w/o run flats) and they are lighter. It's all about process/manuf.
Old 12-11-2011, 01:57 PM   #39
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Originally Posted by armythug View Post
Not a fan of those oem wheels either. I have my mind set on some Volk 18' TE37SL in Black on a white 86.
This, but white on white.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
Old 12-11-2011, 03:57 PM   #40
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
I hope these will fit on an FRS *w* Volks GTS in gun metal I always liked classic 5 spokes. I don't my old 16 Work CR Kai will fit on the FRS ;/
and im hmm so so with the oem I wished the FRS/BRZ came in a Platinum color, the Dark grey is too dark for my taste haha
Old 12-11-2011, 04:15 PM   #41
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Originally Posted by no_name View Post
A RWD car with a higher offset than my FWD? What is this world coming to?
The offset you need is specifically related to the width of the wheel and the suspension design. Most RWD cars these days use high offset, so they can get the length they need on the suspension arms without intruding into trunk and engine bay space.
The JZA80 Supra used +50mm offset, the IS F rear wheels are +55mm offset.
As for low/negative offset, again it depends on the car. Old Supras used +8mm offset from the factory, and most older RWD cars are typically in the -10 to +10mm offset range, often 0mm is common as well, but it's going to depend so much on how wide the wheels are and where the hub sits in relation to the wheel well.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 08:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
