#29 |
id like to see some great numbers but id also like the car to be geared in a sporty manner. what i want is a close geared six speed not a kinda four speed with two overdrives to get that super high hwy mpg something like 22-25 otherwise it seems like the "pure driving experience" as the main objective people are raving about would seem to have been comromised
#30 | |
Drives: 2014 Boxster S; 2015 Macan S
#31 |
Drives: 2005 Hyundai Accent
22-25 mpg highway is ludicrously low. The MX-5 gets 28 highway and no one will ever complain about the gearing in that car. And with an extra 600lb, the genesis coupe 2.0T gets 21/30. And neither of those engines have DI which helps improve fuel economy.
#32 |
Site Moderator
Drives: Stuff
And s2000s were rated for 25-26 hwy (depending on the year) at 2850ish lbs with a 2L NA motor......
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#33 | |
Hot Dog
Drives: quicker than arghx7
Still, if the car gets a legit 31 MPG highway, that'll be fine. What would suck, however, if the highway rating is 31 but you can't even hypermile a 29 MPG tank. I'd rather be pleasantly surprised than disappointed.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#34 | |
When In Doubt...
Drives: Slowww
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#35 |
Drives: '06 AM V8V Coupe
CVT doesn't help as much as the manufacturers try to make it sound like it does. The highest gear is the one with the biggest impact on fuel economy; When you are in lower gears, you are typically using much more engine power and the engine operates efficiently. The reason sports cars tend to do poorly is because closely spaced gears translate to a relatively short cruising gear.
#36 |
Feeling Iffy?
Drives: it like I stole it
Didn't one review for this car predict 38 mpg? I'm hoping for 35 mpg if this thing is going to be 197 hp.
#37 |
I think if the 2500rpm at 60 is correct, then that means this car turns about same rpm as a Civic 1.8L on the highway. Perhaps a bit more pumping loss due to only having the fixed cam and slightly more displacement, so I think it should be comparable (aka, 40 on the highway if traffic is smooth).
#38 | |
Feeling Iffy?
#39 | |
When In Doubt...
Drives: Slowww
I've gotten just over 35mpg with an 11' Legacy 2.5i with the CVT on a trip to NY. Look at the EPA ratings of the Legacy with the CVT vs. the 5 speed manual.
#40 |
Manual transmissions on cars tend to be geared shorter because they assume people driving stick want more performance and care less about fuel economy. A CVT has a large amount of friction by design, and BSFC is actually pretty consistent across the rpm range typically seen in daily operation, so in theory the advantage is practically nonexistent.
Besides, when the EPA does tests they don't even drive the car on the road, and automatic transmissions are likely programmed to maximize EPA performance, so I have a hard time trusting those numbers which show a huge gap between CVT and manual. Just because you got 35mpg on the CVT doesn't mean the manual would've done worse. This is all speculative though, I may be wrong :P |
#41 | |
When In Doubt...
Drives: Slowww
#42 |
Drives: Subaru Legacy
I would be interested in knowing the proper MPG aswell.
If its not to flash, Maybe you could have a over drive fitted to the diff or back of Gbox. For long boring straights put it overdrive in and drop the revs down to save gas. Having fun just put change the ratio back at a flick of the switch. I dont know how the practiblity of something like that would work on a new sports car like the FT86? You can still get brand new units that you can fit to older sports cars. Wether you could adapt one these new units to work and if it would last, I dont know?
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
| Interior Expectations | Archer256 | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-31-2011 04:28 PM |
