Old 11-15-2011, 05:46 PM   #29
Dragonitti
Make no mistake, I'm still going to boost it. Just at a minimal PSI
Old 11-15-2011, 05:48 PM   #30
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
ill boost when it replaces my current track car
WingsofWar is offline   Reply With Quote
Old 11-15-2011, 06:53 PM   #31
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Originally Posted by Chocoholic005 View Post
A DI system is just a way of more fine tuning a engine for fuel quantity. Its not a miricle worker by any means tho. The amounts of pressure this high compression motor will produce combined with a turbo will likely lead to the motor dieseling.
If a certain motor under a certain amount of boost with standard injection started knocking at 9.5:1 CR, Direct Injection might allow the CR to be raised to 10.2 or 10.5:1 without knock occuring, but its not going to help much when you start trying to add any real sort of boost to a 12.5:1 motor.
Read up on DI -- it's much more than that, and it is really fantastic for tuning boosted engines!
The major problem with high CR pistons is that they tend to hold hot spots along the piston crown, and those hot spots make detonation more likely.
However, the incredibly atomized and precise targeting of fuel capable with DI means you can much more easily quench hot spots, and thus prevent knock.
Remember, running rich is all about cooling the piston with unburnt fuel. With DI you can do that far more precisely and effectively and use a leaner mixture.
Now it is certainly true that if you raise cylinder pressure high enough, something will break, even without detonation -- but that is not really going to much matter for a point or two of compression if the crank or piston rings simply can't handle, say, 30 psi.
I bet it will be possible to push 6-8 psi if not a bit more without undue risk -- and that should net you a nice bump in torque and power.
the big x factor was really tuning, and it sounds like the ECU will be reflashable, which is great!
Jordo! is offline   Reply With Quote
Old 11-15-2011, 10:43 PM   #32
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
Anyone else casually glancing at join dates before reading threads?
Neutral_Eyes is offline   Reply With Quote
Old 11-16-2011, 01:03 AM   #33
spoolin
spoolin's Avatar
Drives: Nissan 300zx twin turbo
Anyone else casually glancing at join dates before reading threads?[/QUOTE]
So your saying if I joined at a later date I have no knowledge of cars?
That's really ignorant.
And I agree with what's been said you turbo happy guys are spoiled.
I have two cars currently sitting in my garage a 700whp 1967 hemi dart and a 400whp 1990 300zx tt. you can make more then a 100hp per liter and this is from a 1967 motor with no where near the technology we have today to squeeze even more power and it's carb which has a lot less potential then di the first car proves this and I promise you it is no where near maxed out and it is all motor! No boost no nitrous. And I promise there is nothing like driving an all motor car even a 200hp one. Now I love turbos I think they are a great thing that can provide a lot of hp potential(and trust me I have one tattooed on my arm I am a huge fan of turbo cars) but they are in no way the only hp solution or even the best for this car there are a lot of things I will do to this car before I boost it, if I boost it.
spoolin is offline   Reply With Quote
Old 11-16-2011, 03:56 AM   #34
Godzilla35
Drives: Nissan GT-R
I have two cars currently sitting in my garage a 700whp 1967 hemi dart and a 400whp 1990 300zx tt. you can make more then a 100hp per liter and this is from a 1967 motor with no where near the technology we have today to squeeze even more power and it's carb which has a lot less potential then di the first car proves this and I promise you it is no where near maxed out and it is all motor! No boost no nitrous. And I promise there is nothing like driving an all motor car even a 200hp one. Now I love turbos I think they are a great thing that can provide a lot of hp potential(and trust me I have one tattooed on my arm I am a huge fan of turbo cars) but they are in no way the only hp solution or even the best for this car there are a lot of things I will do to this car before I boost it, if I boost it.[/QUOTE]
I think the benefit of turbos being power adders, without being too hard on the mileage, far outweighs the benefits of all-motor / N/A power on this car because it IS a sport semi-eco-car, in my opinion. But I'm not a turbo expert... I just feel like the engine is new, it has high compression, and there is not enough miles put on a STOCK motor, let alone a blown one to just slap a turbo on there (for any worthwhile power at least).
If I could get 330 hp out of this car some how and not be scared of blowing it up, I'd be totally happy.... but I don't think it's gonna happen...
Godzilla35 is offline   Reply With Quote
Old 11-16-2011, 04:27 AM   #35
chopstickz
Drives: Boost.
This motor definitely has potential, I would love to see the NA Potential, if it can reach 230whp I'm going that route. I'm sure the motor will be able to handle a 57mm turbo yielding 300whp with support fuel mods. As someone on here mentioned... it'll all be in the tuning. If anything, we can lower the compression a little bit with a thicker head gasket, I know this works for a 2jzge, I'm not sure if it'll work the same for a boxer motor though.
chopstickz is offline   Reply With Quote
Old 11-16-2011, 04:33 AM   #36
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Boosting the car without causing it to explode in a masterpiece of disaster will be the easy part. As others have said, DI changes the game on the detonation factor.
Be harder to figure out how to (efficiently) place that shit into the engine bay and keep the factory peripherals. That bay is crammed!
In any case, as with most newer cars, I expect within short time and order there will be a plethora of FI kits and whatnot available from reputable tuners to sate any power mongers thirst. Me? I'm waiting to see if Toda does their N/A magic with this engine.
FWIW, if I had to choose between being whined (turbo) at all day, or screamed (N/A), I'll take screamed.
OldSkoolToys is offline   Reply With Quote
Old 11-16-2011, 04:40 AM   #37
OldSkoolToys
Is a Monster
Drives: AE86, MA70
Stopped there...we're talking from the factory, meeting current (absurdly strict) emissions standards, maintaining everyday drivability for the not hardcore types, and reliability to backup a factory warranty......not aftermarket tuning.
oh, and
Old 11-16-2011, 05:15 AM   #38
spoolin
spoolin's Avatar
I drive my z everyday. But besides that point I think a lot of people are underestimating what this car will get out of just an intake exhaust and a tune, I think this car has a lot more power straight from the factory then they are saying which is why they made the ecu tunable. I think they have this engine so tuned down for mpgs and emissions that we will get a noticeable amount of power just from tuning the car.
Old 11-16-2011, 07:18 AM   #39
Matador
hashiryu
Drives: Mk4 Supra
Ever seen the engine bay of a 300zx?
a 57mm turbo for 300whp?
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 11-16-2011, 07:26 AM   #40
TrackDog
On-Ramp Renegade
Drives: 2005 Subaru Legacy GT
Oh YEAH! Well I'm going to bolt a 4531mm Turbo on mine with 982763cc injectors with a 9817905862103GPH fuel pump and run 789 octane fuel and make 1.876 Trillion HP! So shut it!
-Joe
TrackDog is offline   Reply With Quote
Old 11-16-2011, 07:36 AM   #41
Neutral_Eyes
Softparker
I'm not quite sure how you inferred that, but no, that's not what I'm saying. I'm saying a simple search for "turbo compression ratio" provides a thread dedicated to what this guy intended to discuss, and just about everything else relevant to that topic. But instead he skipped the introduction thread, and went ahead and posted this.. in the wrong forum to boot. It's happened quite a bit since the massive leaks, and it's usually folks who joined right after that are guilty of this.
Old 11-16-2011, 08:41 AM   #42
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
waiting for someone else to ask if it's a hatchback now
MrVito is offline   Reply With Quote
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 08:42 AM
From MKIV Turbo to FR-S Crashoverride Scion FR-S / Toyota 86 GT86 General Forum 62 11-11-2011 01:32 PM
2L turbo exiga. 86Fan Engine, Exhaust, Transmission 16 06-26-2010 06:36 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
2011 911 Turbo S S2KtoFT86 Other Vehicles & General Automotive Discussions 6 02-09-2010 03:02 AM
