Old 04-23-2014, 11:18 PM   #29
JerryMichaels7
Drives: Whiteout FRS
or go straight e85, knocked my crickets out
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 04-23-2014, 11:50 PM   #30
BRZnut
Drives: BRZ DGM Limited
Originally Posted by schmearcampain View Post
Digging up an old thread, but since my hpfp chirping started at around 9k miles and got progressively louder as I reached 10k (I mean really loud), I did some reading and added some TCw3 to my fuel.
It's only been a quarter tank, but the chirping occurs much less frequently and is much quieter when it shows up. On a single short drive it'll come and go. Chirping at some stoplights and not chirping at others. On top of that, the engine is quieter overall.
I went conservative with a 1:1000 ratio, but I might up that to 1:750 at the next fill up.
Things should improve even more after the third tank full
Old 04-24-2014, 11:29 AM   #31
schmearcampain
Drives: 2014 Argento FRS 6MT
I assume you're still using it without any complications? Still at 1oz/5gal? Crickets gone?
schmearcampain is offline   Reply With Quote
Old 04-24-2014, 12:54 PM   #32
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
That was my fix before. Got my pump replaced for the second time about a month and a half ago, now I get chirps WITH e85. Fuck it, I give up.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 04-24-2014, 03:33 PM   #33
Herndon
Herndon's Avatar
Drives: 2014 SWP BRZ
what kind of 2 stroke are you all using?
Herndon is offline   Reply With Quote
Old 04-24-2014, 03:57 PM   #34
2point0
2point0's Avatar
I grabbed the smallest bottle of TCW3 from Walmart for a few bucks. A couple capfulls in each fill up worked well.
Old 04-24-2014, 06:03 PM   #35
schmearcampain
Valvoline TCw3. $3.99 a quart at Autozone.
Old 04-24-2014, 06:06 PM   #36
schmearcampain
Originally Posted by cjsporl1996 View Post
Just use Shell V power it will exterminate the crickets....
Shell shill!
Hasn't worked for me.
Old 04-24-2014, 08:36 PM   #37
BRZnut
yes , from day 1 since the engine is so noisy. In 10K miles, no issues and only heard crickets once for 5 minutes, and that's with 10% ethanol gas which is all we can get around here.
Old 04-24-2014, 10:17 PM   #38
mike the snake
I posted a few times in the crickets thread about adding 2 stroke oil.
I wonder if Castor oil might work even better.
It is sometimes used as 2 stroke oil (Blendzall) and also as an octane booster (Blendzall octane booster is 1/2 castor).
Castor oil has some very special properties.
At the dilution ratios we are talking about, even a non-ashless oil won't hurt anything at all I'm sure.
Old 04-24-2014, 10:29 PM   #39
gramicci101
Off Topic
I got really distracted by the turbocharged, methanol-fueled GSXR 750 from post 13. That thing must be a beast!
Old 05-01-2014, 10:57 PM   #40
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I think I've become a believer. I drive a lot and have very consistent driving habits. I record my mileage on every tank so I'll give this a shot (2 oz per tank) and see if there's a difference in MPGs over the course 5 tanks. It did take my chirps away today so that made me happy.
It's not much different than using MMO or Lucas "upper cylinder lubricant".
PRO86 | STL | LuckyDog
Old 05-18-2014, 07:16 AM   #41
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
So basically any two-cycle motor oil that's TCW3 would work? 2 oz per 10 gallons?
l0aded is offline   Reply With Quote
Old 05-18-2014, 08:22 AM   #42
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
To those of you using TC-W3, just curious if any of you live in a state that requires smog tests. Has TC-W3 had any negative effects on passing the test? How many miles have you been adding it to your gas at fill up? I'm sure its safe in the short term but was wondering what the cumulative effects might be after using it for 50k or more miles.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Adding a Photoshop subforum! srt4_night_rider Site Announcements / Questions / Issues 5 09-02-2012 10:48 PM
Adding a sub enclosure yet ? rikdrt1 Electronics | Audio | NAV | Infotainment 10 06-08-2012 09:28 PM
Adding navi to FRS Pake1 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-04-2012 10:14 AM
Adding Navi to the FRS? Pake1 Electronics | Audio | NAV | Infotainment 3 06-01-2012 01:26 PM
Consequences to Adding Regular Gas? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 34 12-06-2011 12:52 AM
