Old 11-02-2011, 07:16 PM   #29
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
what you might be looking at is a flat or even reverse domed piston depending on what they have in there stock.
A straight up vanilla piston won't cut it, DI piston are typically domed, with a deep asymmetric dish near the fuel injector.
(pictured: 2JZFSE)
Old 11-02-2011, 07:30 PM   #30
madfast
Drives: 2010 Evo X MR-T
(pictured: 2JZFSE)
only if they use stratified charge. assuming you can reprogram the ecu to not run stratified charge, a simple piston swap may be enough to lower compression, among other ways...
madfast is offline   Reply With Quote
Old 11-02-2011, 07:33 PM   #31
serialk11r
Drives: '06 AM V8V Coupe
I think you can't mess with the piston shape with D4-S, they don't use stratified charge but the piston is shaped so the direct injector + port injector create a very even distribution of fuel in the cylinder. If you remove the piston shape, don't expect the performance to stay the same; uneven AFR will promote detonation and poor combustion.
Old 11-02-2011, 07:46 PM   #32
madfast
D-4S on the 2GR absolutely uses a version of stratified charge for cold start. PI is used on the intake stroke, and DI is used on the compression stroke. toyota calls this "weak stratified charge".
the dish in the piston has little to do with D-4S, because other cars without D-4S have the dish as well.
Old 11-02-2011, 07:49 PM   #33
Allch Chcar
Drives: N/A
Dish is better for combustion. I have seen it on the Honda L series and they used other techniques to raise the compression ratio.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-02-2011, 08:04 PM   #34
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
1) Buy a WRX EJ20 turbo motor, wiring harness and ECU for $2000 used
2) Sell your FT86 motor for $2000
3) Profit!
Kostamojen is offline   Reply With Quote
Old 11-02-2011, 08:19 PM   #35
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
3) Profit!
That will most likely be the best thing to do with the car... except I'll keep my stock motor, that way you can put the stock one back in if you ever sell the car and keep your built subie engine
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-02-2011, 08:20 PM   #36
serialk11r
3) Profit!
Until the fuel costs catch up
EDIT: So for people who only want a tiny bump in power, continuing the discussion from the main thread in main forum, 200hp at 7000 is actually pretty pathetic considering what went into this motor. A better exhaust might be able to give a little more and if you don't mind the slight decrease in fuel economy, bigger cams would do some too. 215hp might be realistic considering how the torque is a relatively impressive compared to torque peak 148ft-lb at 7000.
And I am still betting a few years down the road there will be an engine update. I'm not getting a car anytime soon, still in college, but if I'm right I probably will go for said updated FT, well if nothing better comes out.
Old 11-02-2011, 08:27 PM   #37
GotBoost?
Drives: 2007 OBP STI (SOLD)
You forgot labor for installing your new(used) EJ20 turbo motor.
GotBoost? is offline   Reply With Quote
Old 11-02-2011, 09:58 PM   #38
GotBoost?
215.... I hope your talking WHP at that number, and even then your forgetting all the other stuff you can do to an NA motor.
EDIT: I was thinking more in the range of 260-280 still staying NA.
Old 11-02-2011, 10:10 PM   #39
Kostamojen
Won't happen.
Old 11-02-2011, 10:17 PM   #40
GotBoost?
Granted it depends on the block and internals, but it is entirely possible. Throw a really aggressive heads/cam set up on it, plus your headers,intake manifold, throttle body, and other basic bolt on's. I fail to see why you think that its not possible to milk another 60-80 hp out of it.
I'm pretty confident that its a very conservatively tuned motor like most factory production cars.
I've also seen far more aggressive power gains from NA motors, for instance a 99 Formula with a heads/cam/intake/headers pushing 440 whp (305 is stock at crank).
Why do you find it unreasonable to put 280 out of a FR-S / BRZ
Old 11-02-2011, 10:23 PM   #41
serialk11r
Not going to happen without changing displacement. And no, I was talking brake hp. There is no way some simple stuff like that will net 40hp in gains. I don't think I'm forgetting, I am just listing the things that would be relatively cheap.
Old 11-02-2011, 10:24 PM   #42
Shevon
Shevon's Avatar
Drives: Accord Coupe
My old DC5 CR was 11.0:1, i stayed NA but planned on boosting, however car got totaled. But point in case that motor was high strong, many people i know boosted and did fine on stock parts. A friend of mine was pushing 320whp of 9 psi i think with a bolt on greddy kit. Point is though 12.5:1 is pretty high, higher than most wanted it to be, there will be a few kits out there not to mention the few that will custom buld their set up. I prolly boost mine anyway its all about how its tuned, personally im not power hungry so if i can boost and get 250whp running 7psi on stock safely ill be happy.
Stop bitching and crying!! This is a NO BITCHASSNESS zone!!!
Shevon is offline   Reply With Quote
New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 584 08-28-2023 08:53 PM
Engine build Maxim Engine, Exhaust, Transmission 41 10-03-2011 09:22 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
Super Bowl! Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 13 01-29-2010 04:02 PM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 09:46 PM
