Old 11-02-2011, 01:24 PM   #29
ydooby
ydooby's Avatar
Drives: Toyota MR2 Supercharged
That's the centerline of the crank it looks like. Mathmatically that's 18.11", not the 17.8" previously stated so either the 17.8 is wrong or the 460mm isn't CoG. 18.11" is more than my Integra so I doubt that's accurate... I hope not.
Also they never said the lowest, they said one of the lowest. GT3's are lower too.
Somehow I remember they said it's the lowest "of any production car".
Anyway I'm 100% sure it says CoG and not the centerline of the crank in the brochure. Try Google-translating "center of gravity" to Japanese and you'll see that it's "重力の中心" or "重心", exactly the wording in the brochure.
ydooby is offline   Reply With Quote
Old 11-02-2011, 01:25 PM   #30
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
When you sit in car like this and the weight dist is 53/47, depending on the weight of the person you can cause some rearward bias to make it closer to 52/48 or 51/49? Also putting the battery in the trunk helps too.
SUB-FT86 is offline   Reply With Quote
Old 11-02-2011, 01:25 PM   #31
skinsfn36
skinsfn36's Avatar
Drives: 2006 Honda Civic Si
Cant wait to see the translation!
12.5 CR would be nuts
skinsfn36 is offline   Reply With Quote
Old 11-02-2011, 01:25 PM   #32
nate89
nate89's Avatar
Drives: MR2
Originally Posted by madfast View Post
No gooseneck hinges for the trunk! thank GOD!!!
That would destroy the trunk space.
Some things I saw from the pics:
-460mm from ground to the center of the crank (low CG)
-53:47 F/R weight split
-Cd (coefficient of drag) of 0.27 (this is really good)
-D-4S tech (direct injection pairs with secondary EFI)
-1,998cc Displacement
-200 HP
-151.2 ft-lbs torque
-12.5:1 Compression ratio (I guessing on this one, and I really hope I'm wrong)
-86mmx86mm bore/stroke
-Mcpherson suspension front/ Double A-arm rear
-Rear seats fold (as one unit)
-Cup holders can slide
-Can carry 4 tires!!!!!!!!!!!!!!!
-Awsome trunk hinges (no goose neck as mentioned above)
-The rest is up to you Hachi
nate89 is offline   Reply With Quote
Old 11-02-2011, 01:28 PM   #33
ruskymx
ruskymx's Avatar
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
Wonder why this is in english?
There's also a small section in english in the second photo about D4S 4 stroke gasoline. Everything else in japanese...can anyone edumacate me on the reason why? Just seems odd...
ruskymx is offline   Reply With Quote
Old 11-02-2011, 01:29 PM   #34
iggyhop9
Drives: 2009 Toyota Camry XLE V6
Originally Posted by ydooby View Post
So they lied to us. The LFA and the 360 still have lower CoG than the FT-86! Grrr...
At least it's MUCH lower than the WRX STi.
I think its the lowest CoG of any 2+2
iggyhop9 is offline   Reply With Quote
Old 11-02-2011, 01:30 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No direct translation I'd guess.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 01:30 PM   #36
FBS
Drives: 02 Forester
Took another look...
I'd love to know what that graph on the 3rd page is all about
FBS is offline   Reply With Quote
Old 11-02-2011, 01:31 PM   #37
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Could be, that would be against what they've publically stated (since they said 17.8" specifically).
Once it's translated we will know
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 01:32 PM   #38
skinsfn36
skinsfn36's Avatar
12.5:1 will make boosting safely on the stock internals very difficult, probably why we don't have a TRD FI option yet
Old 11-02-2011, 01:32 PM   #39
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
With a square bore and stroke at half a liter per cylinder, wouldn't we be able to spin the living HELL out of this puppy!
Can you imagine how this will sound at 8.5K!
RiskyTrousers is offline   Reply With Quote
Old 11-02-2011, 01:33 PM   #40
Slide
Drives: Toyota Aristo
Damn amazing info!
Can't wait to read what it al says
Slide is offline   Reply With Quote
Old 11-02-2011, 01:33 PM   #41
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Excellent!
Love the drag coefficient being 0.27. It also makes sense now seeing the 4 tire diagram, how they expect us to transport track tires. The fold-down rear seat looks useful. Interesting to see they're bragging about a 500mL bottle fitting in the door pocket.
The engine specs look good; 12.5:1 static CR is typical for n/a DI. The problem I see is the torque/power graph; it doesn't jive at all with the 197HP peak @ 7k RPM and 151LbFt peak @ 6600 RPM. There's no numerals for RPM on the graph, however torque and power peak appear to be much further than 400 RPM apart, more like 1400 RPM apart. Also, I'm not a fan of that torque curve; it's too much like an n/a 2ZZ or F20; it won't feel natural, linear, or flexible like the Miata engine.
Edit; just noticed the 7400 RPM redline, not bad.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-02-2011, 01:34 PM   #42
madfast
Drives: 2010 Evo X MR-T
actually, it would be the death of any chance for factory forced induction... i just cant see them boosting a car with 12.5 CR with a warranty.
madfast is offline   Reply With Quote
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 02:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 01:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 06:35 PM
