Old 03-25-2013, 03:24 PM   #29
dawnst3ar
Drives: 2013 MT FR-S Asphalt
Ok, after having done this, I am trying to figure out why my radar shuts off everytime I put the car in reverse??? any ideas?
Also, could I tap into the same line to add a dashcam, or would I need to look for another line to run the power from?
dawnst3ar is offline   Reply With Quote
Old 03-26-2013, 10:28 PM   #30
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Check where you plugged in the prongs in reference with the pictures. If you have them plugged in the wrong spot it will turn off when you put the car in reverse (I have no idea why it does this...).
speedracer38 is offline   Reply With Quote
Old 04-04-2013, 09:46 AM   #31
Captain_Awesome_Pants
Captain_Awesome_Pants's Avatar
Drives: FR-S: Firestorm
Originally Posted by epsilonkore View Post
Yes the mirror connector is on the FR-S. I installed the Subaru mirror on my US FR-S this weekend, plug is tapes way up in the roof but its there!
So when I reached up to get this thing I can feel it but it barely wants to budge. I tried to pull on it a bit but Im afraid of breaking the connector off with too much force.
Anyone else encounter this? is it taped back or something?
Captain_Awesome_Pants is offline   Reply With Quote
Old 04-04-2013, 09:58 AM   #32
Foobar
SLO NO MO
Foobar's Avatar
I had to yank mine before it finally gave. I didn't notice any tape so I suspect it's wedged in there or if it was taped, it came off when I pulled.
Old 04-04-2013, 10:19 AM   #33
Good deal! Ill just stop being so gentle with it.
Old 04-04-2013, 11:18 AM   #34
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
so wait on valentine1, you dont use a power block, just direct phone wire connection?
Huehuecoyotl is offline   Reply With Quote
Old 04-04-2013, 11:27 AM   #35
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
They have a little block that comes with the new ones. You hardwire that in and use the phone wire to plug from that device to the radar detector.
Here is a picture. Its the roundish black device with the 2 phone jacks. I think the second port goes to the remote display if you have one.
Ranatsu is offline   Reply With Quote
Old 04-04-2013, 11:34 AM   #36
Ranatsu
Cone basher
Because on some Subaru's there was a reverse camera screen built into the Compass mirror. I'm pretty sure thats why there is a third wire.
Old 04-04-2013, 06:49 PM   #37
Huehuecoyotl
no my question was can you just feed the valentine1 12v raw or do u need to go thru the lil box?
Old 04-04-2013, 07:18 PM   #38
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Yes you can hardwire it raw. If I recall though you cannot enter the programming mode.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 04-04-2013, 11:53 PM   #39
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
Great writeup. Looks so simple, I'm going to make my own cord as well.
Can I ask you to confirm that of the 4 wires in the RJ-11 cable (yellow, green, black, & red), you are indeed just soldering the 2 D-Sub connectors to only the black and red wires? (so the green & yellow wires are unused)
[QUOTE=kykiee;536565]I made my own Invisicord. It came out pretty nice.
All you need is a Soldering Iron, Solder, Heat-Shrink Tubes/Electrical Tape, and Pin Connectors from a 9 Pin Male Crimp D-Sub Connecter, and RJ-11 Telephone Cable.
996garage is offline   Reply With Quote
Old 04-05-2013, 12:10 AM   #40
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
You want to use the middle two wires. If you look at the connector you will see two wires in the middle. For me, it was the green and red.
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 04-05-2013, 12:18 AM   #41
996garage
996garage's Avatar
Thank you kykiee!
I'm saving myself a trip to Radio Shack because if you have any old computer cable with the D-Sub pins, you can rip the face open with pliers, and you will likely find that several of the pins don't have wires crimped to them. Just push the pins out from the front and they are ready to use!
Old 04-05-2013, 12:39 AM   #42
kanundrum
Drives: 2013 Whiteout FR-S
I just tried tapping the gray wire for power and the black wire for ground and I get nothing.
Radar works though for sure and I am def tapping it correctly with contact.
Edit:
Inline fuse in the hardwire kit was blown.
2a250v
diy, radar detector, speedracer38
Direct wire radar detector Kieranz Electronics | Audio | NAV | Infotainment 25 11-02-2015 12:01 AM
Mounting a radar detector Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 24 02-06-2014 12:39 PM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
Mounting radar detector video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 10 06-07-2012 11:29 AM
