Old 12-26-2012, 11:24 PM   #29
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Perfect... doing these here soon to mine
Bill
Scooby South is offline   Reply With Quote
Old 05-21-2013, 01:14 AM   #30
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Rear Mount Whiteline Bushings
Bill
Installed mine this week (May 20th, 2013). Wished the two packets of moly grease mentioned in the instructions were in the package instead of just one. Waiting new tires and rims so I don't have a butt report. I will install the Whiteline transmission bushing (with Perrin Performance transmission T product) and Whiteline steering bushings along with replacing transmission and rear end fluids with AMSOIL products before getting on the road with Weds 105s 18x8 and 245/35/18 Michelin Super Sports. Looking forward to niceness beyond expression!
Hot Rod Heaven is just one more mod away.
Tom
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 05-22-2013, 11:47 PM   #31
charged86
charged86's Avatar
good work as always @F1point4
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-10-2013, 08:45 PM   #32
Brzzee
Brzzee's Avatar
Originally Posted by F1point4 View Post
This! As you saw in my photos, one of my bolts had growth on it. Barnacles? I think it was exposure to seawater or something during transport. I'm not sure what this means long term.
20121028-WhitelineRearCrossmemberBushingsDIY-20 by VictorN07, on Flickr
I finished the bushing swap yesterday (6/9/2013). The right-hand, front bolt had corrosion similar to this picture on my November 2012 delivery, BRZ limited purchased at Sewell Subaru in Dallas.
The left side bolt had a light coating of red grease and no corrosion.
Anyone heard a possible explanation from Subaru or Scion? Could this be an issue for Texas or Southwest delivered Twins?
Old 06-10-2013, 08:58 PM   #33
OrbitalEllipses
Drives: Attitude
One of my front camber bolts had similar corrosion. I'd consider it a non-issue, but something to watch out for when doing suspension.
Brzzee (06-10-2013)
Old 06-10-2013, 10:48 PM   #34
Brzzee
Brzzee's Avatar
Which side?
Old 06-10-2013, 11:03 PM   #35
OrbitalEllipses
Drives: Attitude
I don't recall.
Old 06-11-2013, 10:31 AM   #36
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Same thing with my FRS.
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
Evil86 is offline   Reply With Quote
The Following User Says Thank You to Evil86 For This Useful Post:
Brzzee (06-11-2013)
Old 06-11-2013, 11:32 PM   #37
Brzzee
Brzzee's Avatar
Wow! My engineer trained mind starts on a trail to figure the reason for this bolt and this location across platforms and delivery points. Why only this bolt? And why the passenger side only has the problem?
Anyone connected with factory reps?
Old 06-19-2013, 10:12 PM   #38
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thank you for the excellent DIY.
Same Bolt , Same Location May 2012 FRS
I sprayed it with Dry Film Lubricant
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 06-20-2013, 12:40 PM   #39
brillo
Drives: 2013 Firestorm FR-S
I had these installed by a professional shop yesterday (great mod), just be aware that loosening the subframe will likely alter your rear alignment so I would suggest installing these along with other suspension mods and get an alignment shortly thereafter.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
The Following User Says Thank You to brillo For This Useful Post:
normancw (02-09-2014)
Old 07-27-2013, 03:10 AM   #40
eckoflyte
Drives: Toyota 86 GTS
Thanks for this awesome guide. Just did mine today using this guide and it was a relatively painless job.
eckoflyte is offline   Reply With Quote
Old 07-27-2013, 03:13 AM   #41
eckoflyte
Also, if I ever wanted to regrease these bushings, what sort of grease would be suitable for the job?
Old 08-27-2013, 06:54 PM   #42
emutcfut
Drives: 2013 Argento
Thanks for another great write-up.
Did these over the weekend and WOW car feels amazing now. No squat or delay when the car takes off. Feels incredible! I do get a very slight whine through the chassis now, but only noticeable with the radio off.
emutcfut is offline   Reply With Quote
bushing, crossmember, diy, whiteline
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
Installed the Whiteline crossmember bushing(no pics sorry) gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-26-2013 03:00 PM
++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ genometuning Transmission and Driveline 4 10-12-2012 10:23 PM
