#29 |
Drives: Attitude
FWIW I had speed bleeders on my WRX. They're nice, but become useless if you use a pressured bleeder like the Motive tool. The tool pressurizes (positive, not vacuum) the brake system and pushes fresh fluid through so all you have to do is crack the bleeders open; they won't ingest air since the circuit's are pressurized. Just another way of doing a one-man brake job that I thought I'd share.
#30 |
Drives: Toyota 86 GTS
Hey mate, what is the part number for the front and rear speed bleeders for this car?
Would appreciate the info as i want to get myself a set. |
#31 |
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
SB1010-SS for front and rear.
Fits like a charm. I am 95% sure this same speed bleeder will work for the clutch too
| The Following User Says Thank You to F1point4 For This Useful Post: | BAOVAN (12-27-2016) |
#32 |
Drives: White MT FR-S
There are two lengths offered - 31.35 and 34.44. Which length did you use or does it not matter?
Thank you for all of your great DIY write ups! I figured it out - it's the longer threaded version with the part # you gave. I looked at the part numbers closer and the short 31.35 is SB1010S-SS My eyes skipped the extra "S" and I thought they both had the same #.
Last edited by Amadeus; 01-28-2013 at 11:50 PM. Reason: to point out my stupidity |
#33 |
RedBunny w/ Wing
looks great.!
#34 |
To the OP or anyone else using the speed bleeders, any issues thus far? Does it actually make solo bleeding a breeze. I bring this up b/c my local track enthusiasts shop are adamant that years of trying to work with speed bleeders have failed, just ending up using the OEM bleeders and a 2 man crew. Something about letting air in as it closes.
SS lines are in route and picked a pump that will feed/keep the reservoir under pressure. |
| The Following User Says Thank You to MyRx For This Useful Post: | amram (04-09-2014) |
#35 |
Thanks for this write up. It helped. Flare wrench helped since standard wrench rounds the nut if it's on too tight. Thanks for lookout
#36 |
Drives: Scion FR-S
rounded every the nut every time i tried using standard wrenches. gave up and used pliers.
2013 Ultramarine FR-S 6MT
#38 |
Drives: GT86
Nice write up.
Spent a few hours at the track last week with my stock 86. Got settled, then into an aggressive groove. I found the brake feel /performance the most noticeable "low performance" part of the ride. The SS lines is a great idea, mine are on order.
| The Following User Says Thank You to Alabang 86 For This Useful Post: | amram (03-21-2014) |
#39 |
Drives: 1986 MR2
When I first purchased speed bleeders about a decade ago, they warned not to over-tighten them because they are hollow and could break. Having half a bleeder stuck in the caliper would suck.
Also, I'm wondering where the warning to not pump the brake pedal all the way for fear of rupturing the master cylinder comes from. Any source for this? |
#40 | |
#41 |
Drives: Raven 6MT
Thank you for this! Did a line swap last weekend and followed this. Made everything easy and simple. Definitely agree that a flare wrench is the way to go, almost stripped the nut for the hard line/flexible line connection.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
#42 |
Drives: 2003 Camry Blue | 2013 FR-S White
question about "air bubbles" Where exactly do we look for this? I understand the brakeline change as well as the bleeding part, but I'm not sure about looking for bubbles while bleeding the brake lines.
Figured I might attempt to do this on my own, once I get my car on a lift. |
| Tags |
| brakes, fluid, motul, speed bleeders, stoptech |
| BC Racing Coilovers with Free Stainless Steel Brake Lines!!! | Dustin@Dynosty | Brakes, Suspension, Chassis | 21 | 01-08-2013 11:34 AM |
| Dynosty Stainless Steel Brake Lines $99 Shipped | Dustin@Dynosty | Brakes, Suspension, Chassis | 9 | 12-29-2012 10:56 AM |
| Stoptech stainless brake lines + Motul RBF600 fluid combo | No Limit Motorsport | Brakes, Suspension, Chassis | 9 | 10-31-2012 08:36 PM |
| Stoptech Front Stainless Steel Brake Lines | Pekingduck | Brakes, Suspension, Chassis | 1 | 10-21-2012 11:29 PM |
| Stainless steel brake lines | taosracer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 09-20-2012 05:09 AM |
