10-23-2012, 03:49 AM | #29 |
Drives: '13 SWP Sport-Tech (Limited)
Thanks for the info guys. Looks like I'm going to be going for 205/55/16 tires.
Went to Costco and the one's I wanted were $199 each but they had no wheels in stock. They had some steelies but the bolt patterns weren't the same so I either need to buy them elsewhere or get everything from a different place. Looked at Kal Tire and this is the quote I got online. Thoughts? Added up quickly with the recommended 4 wheel alignment and lead free passenger wheel balance and that doesn't even count the steel wheels yet. Michelin X-Ice® Xi3™ Tire (205/55R16 94 H) 4 $199.12 $796.48 *500* 413R 1.25" RUBBER VALVE STEM 4 $3.45 $13.80 4 WHEEL ALIGNMENT (recommended) 1 $114.95 $114.95 LEAD FREE PASSENGER WHEEL BALANCE 4 $23.00 $92.00 †Installation, Rotations, Flat repairs and Lifetime balancing 1 Free $0.00 †Road Hazard Warranty and 30-Day No-Hassle guarantee 1 Free $0.00 Sub-Total $1,017.23 Taxes $124.43 Environmental Fees $20.00 Total Price$1,161.66 |
10-23-2012, 06:59 AM | #30 |
Drives: '13 Ultramarine
The car is pretty new...unless you suspect issues with the front end, I would skip the alignment. The savings will buy at least two of your steel wheels. Are you going to pass on the TPMS? I thought about doing this as well, but I really don't want to stare at the light for 5 or so months. A large tire shop should be able to set you up with sensors and programming. In my case, I bought the sensors from the dealer (about $50 X 4), and will have to have them do the programming. They want $89 each time I swap the wheels from summer to winter and back. There has got to be a cheaper way...
10-23-2012, 07:43 AM | #31 |
Ah, crap. Didn't realize there would be a consequence to not getting TPMS. Hrm, maybe I'll skip it this year and if it bugs the crap out of me add it next year.
Somebody figure out an easy way to disable the TPMS light without it affecting anything else? |
10-23-2012, 08:57 AM | #32 | |
i'm sorry, what?
Drives: Canada
woopty-do just inspect your own tires once in awhile you're boss.
The Following User Says Thank You to 7thgear For This Useful Post: | Demandred7 (10-23-2012) |
10-23-2012, 09:37 AM | #33 | |
Drives: Subaru BRZ
As for tires/wheels, call Tires23 in Mississauga (Dixie/Matheson). They can get you steelies as well or you could look around for a used set of Subaru 16" alloys.
Bryan.
10-23-2012, 06:57 PM | #34 | |
I think I'd really rather stay away from alloys because of the salt. And I'm sure there's a bunch of great places to buy from in Ontario but shipping out West would probably be really expensive. So, I know I need 16" wheels in a 5x100 bolt pattern but anything else I need to look for like a specific width? I'm a little confused by information I got from Costco. Took a picture that said: 5x100, 12x1.50, 21mm, 17"/18". And anybody know what Lead Free Passenger Wheel Balance is? Is that something I need or a right rip? |
10-23-2012, 08:54 PM | #35 |
Any car made from 2007 on without TPMS would be a surprise to me. 7thgear is right, you don't need to run the sensors...I know the light would bug me (almost as much as a little piece of black tape covering up the light), so I got some. Lead free just means the wheel weights used do not contain lead. Lead is soft, dense, and makes a good wheel weight material. Lead weights are slowly being phased out for environmental reasons.
10-23-2012, 09:06 PM | #36 |
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
My 2010 Cobalt doesn't have a TPMS. Actually it's lacking ABS and cruise control, too. With power windows and locks. Piece of garbage. Edit: Anyone wanna buy it once I get my FR-S?
10-23-2012, 09:19 PM | #37 |
Drives: 2013 Scion FR-S Asphalt
10-23-2012, 09:30 PM | #38 |
I stand surprised.
10-23-2012, 09:44 PM | #39 | |
Drives: Subaru BRZ Limited
10-23-2012, 09:49 PM | #40 |
Drives: TR2,CooperS,BRZ
My car certainly does not have TPMS.
10-23-2012, 09:52 PM | #41 | |
Drives: Subaru BRZ
I'm a moron - didn't realize you were out West. I sometimes forget how big Canada is. Have you looked at 1010tires? I think they're based in BC somewhere. As for wheel specs, 16" with a width between 6.5"-7" will do fine for a 205 tire. Bolt pattern 5x100 (of course) and offset within 45-55 should clear everything. If I lost you check out this link - http://www.1010tires.com/About/Tech.
Bryan.
10-23-2012, 10:08 PM | #42 |
Similar Threads | ||||
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires | Chuynh207 | Wheels and Tires | 3 | 11-06-2012 01:19 PM |
snow tires | debs0712 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-18-2012 12:58 PM |
what tires will you be using this winter for snow? | denverizzles | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 08-01-2012 11:20 PM |
How effective are snow tires? | theredtape | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-18-2012 07:49 PM |
Snow tires? | smbrm | CANADA | 12 | 05-27-2012 01:20 AM |
