Old 10-23-2012, 09:13 PM   #29
Loki2x
Loki2x's Avatar
Drives: 04 Subaru WRX
I think the WRX vents are even 60mm, so it may even be possible to stick a WRX vent in one of the holes on that set up. Here's a pic of the other way around, where someone stuck a gauge in the vent similar to your idea.
Loki2x is offline   Reply With Quote
Old 10-24-2012, 04:37 AM   #30
Supermassive
Supermassive's Avatar
Originally Posted by Synack View Post
Hmmm, why not stick the gauge on the left. Maybe stick the knob by the gas cap release. See crudely microsoft painted picture below for both.
Now that I think about it this is exactly what I'll be doing.
I like how you cut and pasted the solenoid down there by the gas cap release! The solenoid goes between the turbo and the wastegate and basically throttles the pressure generated by the turbo that actuates the wastegate so you can basically boost up to 30 psi with this kit.
Just poking fun is all
Supermassive is offline   Reply With Quote
Old 10-24-2012, 04:59 AM   #31
doggy
doggy's Avatar
Drives: Scion FRS Firestorm MT
Originally Posted by Loki2x View Post
Would it be possible to vent air out the sides or below. I really like the design of this. I am coming from the GD WRX frog eye set up. Are those holes for 60mm or 52mm?
Holes are 52. Its not posible to fit 60 without midification do dash it self.. Still thinking about vents... Even if i would make them - they would be small - and not posible to close them... Just holes on the sides..
doggy is offline   Reply With Quote
Old 10-24-2012, 06:17 AM   #32
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Would it be possible to have a 1-gauge pod and keep one of the two original vents (swap it from the the OEM panel)? With a N/A engine, all you really need is oil temp anyway and the passenger (aka "the GF") can keep a vent on her side.
Old 10-24-2012, 08:36 AM   #33
doggy
doggy's Avatar
There will be single gauge pod pretty soon too. It will be dash mounted - keeping all the vents in place.
Old 10-24-2012, 11:15 AM   #34
Synack
Boosted
Synack's Avatar
Drives: Sideways
He was saying he could set boost on the fly lol. I figured this is where he was going with it.
Old 10-24-2012, 04:27 PM   #35
Supermassive
Yeah you can set it via the gauge itself, it has two push buttons on the face. That's why I am looking for a good mounting solution so that its within reach.
Old 10-24-2012, 06:29 PM   #36
Synack
Boosted
Synack's Avatar
Drives: Sideways
Should be easy to mount if to the existing pillar. Temporarily. And then get the single pod when it comes out.
Old 10-24-2012, 06:47 PM   #37
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I think the best idea would be a retrofit into the actual gauge cluster of the car. The analog speedo is 99.9% worthless anyways, just cram 2-3 gauges in place of that thing.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 10-25-2012, 12:07 AM   #38
RavenFR-S
If you do insert vents, will the choice of vents be directional?
I like the design of the pod in the middle. I will definitely be up for one once they are ready. It is a bit rounded as another member mentioned. Will it be tweaked?
RavenFR-S is offline   Reply With Quote
Old 10-25-2012, 12:27 AM   #39
Synack
Boosted
Synack's Avatar
Drives: Sideways
Kinda annoying that legit gauge pods aren't out by now.....
Old 10-25-2012, 02:38 PM   #40
ANREX
ANREX's Avatar
Drives: GT86
Slash
http://www.slashowy.com/toyota86_series_index.html
http://www.ft86club.com/forums/attac...1&d=1352598895
ANREX is offline   Reply With Quote
The Following 2 Users Say Thank You to ANREX For This Useful Post:
Khyron686 (03-21-2014), usptwins (01-15-2013)
Old 10-25-2012, 02:39 PM   #41
Synack
Boosted
Synack's Avatar
Drives: Sideways
BRING USA DRIVER PILLAR!!!!
But damn that looks sick.
The Following User Says Thank You to Synack For This Useful Post:
Old 10-25-2012, 03:01 PM   #42
doggy
doggy's Avatar
Yes - thats the problem If i will do vents - they will be straigh front and not posible to adjust...
As for the roundness - you will see that its not that 'round' from all the different angles. It flows into whole interior once its in paint
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 07:19 PM
Gas Gauge Issue Jruex22 Scion FR-S / Toyota 86 GT86 General Forum 12 04-04-2013 11:28 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
