Old 05-22-2015, 05:55 PM   #29
karimz
Drives: 2014 Scion FR-S Monogram
I checked and can confirm the steps in the above post also disables the passenger seat belt chime
karimz is offline   Reply With Quote
Old 10-25-2016, 03:21 PM   #30
Burnswell
Drives: FRS
Originally Posted by karimz View Post
I was about to purchase the Carista app but found instructions to do it using a terminal app like hyper terminal or putty (I used putty). I got the instructions on a prius forum but I can confirm that it worked for my 2014 FR-S. I did this last night actually. You need an ELM327 to USB cable (had one laying around but they can be found on ebay fairly cheap). The instructions on the other forum said to set the baud rate to 115200 but I could only get it working at 38400. Try different baud rates if you see gibberish when you type.
Enter the following commands:
AT SH 7c0 (hit 'Send')
Returns: OK
21a7 (hit 'Send')
Returns: 61 AC C0 (meaning beep enabled)
3ba700 (hit 'Send')
21a7 (hit 'Send')
Returns: 61 AC 00 (meaning beep disabled)
That's it! The driver's side seat belt warning won't beep anymore (I haven't tested the passenger side, but I imagine there's a separate command for that). I believe the settings cycle so if you wanted to re-enable it, I imagine you'd just have to re-enter the same commands again, but don't quote me on that as I haven't tested it. You could probably follow these instructions on an android device if you have a bluetooth OBD2 adapter and a terminal app. I have an iPhone and couldn't find an app that would let me send commands.
Thank you so much for posting this!!! I purchased the cheapo (blue) bluetooth obd device from China but it wouldn't work with Carista app. Installed an app called "OBD2 Boy" and these codes removed the chime...for free!
This needs to be easier to find as I looked forever for console level code to work with.
Thanks again,
Happy (Chime Free) FRS Owner
Burnswell is offline   Reply With Quote
What's the weight on the passenger seat sensor? Iphone sets off airbag/seatbelt chime NeedsmoreCowbell Scion FR-S / Toyota 86 GT86 General Forum 67 03-28-2013 12:21 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
Red Seat Belt - where to get? MarkMash Cosmetic Modification (Interior/Exterior/Lighting) 11 06-24-2012 11:55 AM
Subaru seat belt chime chitownwrx BRZ First-Gen (2012+) — General Topics 20 05-04-2012 02:35 PM
You wish you were this seat-belt! YukiHachiRoku Off-Topic Lounge [WARNING: NO POLITICS] 13 05-03-2012 07:43 PM
