Old 09-27-2012, 08:09 PM   #29
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Its hard to tell from the pics, but how close is it to the exhaust?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-27-2012, 10:08 PM   #30
msile
msile's Avatar
Drives: ISF
Far away. Same as stock..
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline   Reply With Quote
The Following User Says Thank You to msile For This Useful Post:
civicdrivr (09-27-2012)
Old 09-27-2012, 10:52 PM   #31
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Driveshaft $1,100 ... But the pool table in the photograph is Priceless$
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
Alabang 86 (11-18-2012)
Old 09-27-2012, 11:55 PM   #32
msile
msile's Avatar
Drives: ISF
Busted! I wanted good lighting
Old 09-28-2012, 01:09 AM   #33
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Is it me or do you have a lift in your garage...
I'll be back!!
F3dzo is offline   Reply With Quote
Old 09-28-2012, 01:52 AM   #34
msile
msile's Avatar
Drives: ISF
I tried, but the garage doors were in the way. I would have to modify it. Too much hassle.
Old 09-28-2012, 09:55 AM   #35
phillip
Drives: 2011 135i
Originally Posted by RallySport Direct View Post
Glad you are enjoying the shaft as well, we are loving ours!
Giggity
phillip is offline   Reply With Quote
The Following 5 Users Say Thank You to phillip For This Useful Post:
bestwheelbase (11-28-2012), Freeman (11-17-2012), funwheeldrive (05-29-2015), Lakitu (06-27-2018), WallsAndFoundations (03-11-2016)
Old 09-28-2012, 12:01 PM   #36
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Never thought it was that easy to swap out. Very nice.
jadewbj is offline   Reply With Quote
Old 09-28-2012, 11:35 PM   #37
Auto-Hauss
Auto-Hauss's Avatar
Drives: 2013 Scion FR-S-Asphalt
Any max torque numbers you can putt through it? With shop already putting 380+ wtq through a stock block when they start to build them it could end up being around 600. I drift and twisting aluminum shafts is pretty common once you start getting into the higher horse power in that type of environment.
Auto-Hauss is offline   Reply With Quote
Old 09-29-2012, 12:01 AM   #38
msile
msile's Avatar
Drives: ISF
From RallySport's Thread:
The shafts are rated at over 2700lbf/tq, in other words you have to do something crazy to break it!
PST has drag cars running in the 6 second 1/4 mile using the same shaft designs.
Cool thing about carbon fiber shafts..they twist a certain degree while staying in the elastic region of the sheer stress, meaning they take up shock and spring back to original shape.
One thing that simply blew me away was that the weak point on these shafts....the metal yokes on the end, and not the carbon. If you ever manage to break the yoke, well PST can make you a billet unit for you monster when that time comes
Old 09-29-2012, 11:46 AM   #39
Auto-Hauss
Auto-Hauss's Avatar
2700 will do... haha One other good thing about the flex would be the shock savings on the half shafts. Even though I want shock going through the drive train in certain situations the flex would theoretically help prevent the half shafts from snapping at higher horse power loads and increased tire size. pretty neat.
Old 09-29-2012, 11:39 PM   #40
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
If we have enough interest for a AT unit we can get those made as well
As for Aluminum vs Carbon, this is a write up I did going over both of them. This was done on our 2011 Sti shop car as the test mule but the exact same concepts apply.
http://theattack.rallysportdirect.co...shaft-overview
If you guys have any questions dont hesitate to let us know
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
The Following 5 Users Say Thank You to RallySport Direct For This Useful Post:
Captain Insano (10-05-2012), Fly Guy (06-07-2014), Spartan65 (10-05-2012), Xanatos (10-05-2012), zoomzoomers (10-06-2012)
Old 10-01-2012, 05:11 PM   #41
RossGA
Drives: Audi S4
Originally Posted by serialk11r View Post
After the differential gear ratio reduction is taken into account, the effective moment of inertia decrease is pretty small compared to wheels. Of course, wheels can only be made so light, but their effective "moment radius" is still larger.
Absolutely true, but there is more to the physics of spinning an object and the energy involved than just the moment of inertia. Total RPM will represent an energy investment, and the higher the RPM, the higher the investment.
Gear ratios and weight savings on spinning objects do come into account, and that is one of the reasons why the best place to remove rotating mass is on the crank...it is the fastest spinning object in the power train minus the alt. The wheels my be the best spot to improve overall weight savings in the rotating objects category; but pulling 1lb off a crank that can spin 7K RPM equates to several pounds at the wheels that spin tremendously slower. So yes, the gear ratio in the rear diff will have an impact here.
So I am not disagreeing, just adding to your argument that RPM will also play a factor. Taking 10lbs off the driveline that spins 4x faster than the wheels will be as effective as removing several pounds from the wheels. Think of it this way, spin the driveline the same speed as the wheels....and increase it's diameter by 4. And redo the math. They both will offer an excellent improvement to responsiveness; and the difference of which is superior may not be as clear as it first appears.
RossGA is offline   Reply With Quote
The Following User Says Thank You to RossGA For This Useful Post:
msile (10-01-2012)
Old 10-01-2012, 08:47 PM   #42
msile
msile's Avatar
Drives: ISF
Good write up. It is as you said. I have lighter wheels, crank pulley and shaft. The combo feels very good.
PST Carbonfiber Drive Shaft In Stock and Ready To Go!! RallySport Direct Transmission and Driveline 27 11-18-2012 02:39 PM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 05:44 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 12:14 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 02:40 PM
